Old Sep 18, 2009, 04:52 PM
MaverickP-51D is offline
Find More Posts by MaverickP-51D
MaverickP-51D's Avatar
United States, TX, Palestine
Joined Dec 2007
ran a 14x8 MA on my 100
mid nines....
MaverickP-51D is offline Find More Posts by MaverickP-51D
Old Sep 18, 2009, 04:54 PM
Joined Dec 2007
only difference between the 82 and the 82GK is the paint
STACK ON!!!!!
Old Sep 18, 2009, 05:05 PM
rodneygt is online now
Find More Posts by rodneygt
Registered User Wannabe
rodneygt's Avatar
Southwest Mississippi, USA
Originally Posted by MikeMcChiken
Hows that RodneyGT , I assume you were talking about I Tober's tip .
I mean just block and copy the link in your browser window on page 20 of this thread. Then go back to your original post, hit edit and add it at the bottom. I just thought it would be easy to find that way - like an internal sticky. I Tobor's break-in procedure is contained in those links that I posted in post #290 plus other related discussion. Linking the whole page will provide those links that have his procedure plus the discussion about it that is also on page 20.
rodneygt is online now Find More Posts by rodneygt
Old Sep 18, 2009, 05:09 PM
flyinghigh is offline
Find More Posts by flyinghigh
TDI Abuser
flyinghigh's Avatar
Joined Sep 2002
Good Idea !
flyinghigh is offline Find More Posts by flyinghigh
Old Sep 18, 2009, 05:17 PM
MikeMcChiken is offline
Find More Posts by MikeMcChiken
Fly'em like you Stole'em
MikeMcChiken's Avatar
The Gehto,Ca.
Joined Jun 2008
My bad Rodney , Forgot your links . Check'r out now .
MikeMcChiken is offline Find More Posts by MikeMcChiken
Old Sep 19, 2009, 08:31 AM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Originally Posted by I TOBOR
Hey there DR, I tend to prop the .50 and over Saitos in the mid nines and the .45 and under at about 10,000, the little .30s really shine at about 10,100 on a Graupner 10x6 or 10.5x5.
Ditto...
I prop some in the 10,500 range for 3D but you have to start being careful of your rev's on the downlines...
...starts to make stuff inside unhappy
Dad_Roman is offline Find More Posts by Dad_Roman
Old Sep 19, 2009, 03:28 PM
airboss/oc is offline
Find More Posts by airboss/oc
California Style
airboss/oc's Avatar
United States, CA, El Mirage
Joined May 2007
virgin Saito
my very first ever 4st got to say F yeah ! where the hek have I been hiding ? this engine was great , started and ran 1 tank on the bench then closed the needle a bit and flew the crap out of it what a first class peice of engineering its been a pleasure to own so far and after tomorow will have burned 3 gallons.
question; can I run 30/23 heli fuel ?
OMP fusionX/Saito115
and A really bad morning for the big boys
airboss/oc is offline Find More Posts by airboss/oc
Old Sep 19, 2009, 03:57 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
So guys, I got my new Saito 82 today. Beautiful piece I must say. Getting ready to mount on Primo, but how do I reverse the carb? I might as well get some advice rather than plow ahead and mess something up? Thanks.
u2builder is offline Find More Posts by u2builder
Old Sep 19, 2009, 04:14 PM
I TOBOR is online now
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Eazy Peazy, remove the two screws that hold the carb to the backplate, swing the carb out to the side rotate 180 and put back. Make sure the pipe does not come out of the head, if it does, pull the pipe out all the way, put the O-ring in the recess in the head and slide the pipe back into the O-ring. The O-ring will not go back into the recess with the pipe in it.
I TOBOR is online now Find More Posts by I TOBOR
Old Sep 19, 2009, 04:29 PM
California Style
airboss/oc's Avatar
Joined May 2007
FA115/fusionX
what about that goofy pipe/muffler combo that comes with the engine?
can I run it without the baffle ?
will it increase the power or just add noise ?
does anyone make a cool header/pipe for these engines ?
Old Sep 19, 2009, 05:41 PM
I TOBOR's Avatar
Joined Feb 2007
http://rcspecialties.net/
Check this out
Old Sep 19, 2009, 05:56 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Thanks. Got the carb reversed. Easy. Should I use Locktite on the ends of the Muffler connector pipe or are the locknuts all that is necessary?
Old Sep 19, 2009, 06:07 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I do recommend that you squeeze a good amount of oil into the crankcase (through the breather) before you run the engine up and that you lift the rocker covers so as to put a few drops there as well.
This for Xjet. What type of oil? I have a bottle of medicinal Castor oil. Should I use some of that?
Old Sep 19, 2009, 06:14 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I've probably never paid enough attention to this with my 2 strokes, but what position should the "top" of the prop be as you begin to feel compression? 11 o'clock? or something else?
Old Sep 19, 2009, 07:05 PM
I TOBOR's Avatar
Joined Feb 2007
U, the Saitos have a black grease already in place to lube the engine on the initial start up. The first oil that comes out of the vent will have black streaks like this. It scares some guys to death who don't know what it is.
About two o-clock on the prop flipping position..
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 03:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 02:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 10:52 PM
