Old Sep 17, 2009, 10:02 AM
cjneal is offline
Find More Posts by cjneal
cjneal's Avatar
United States, UT, Hooper
Joined Oct 2006
Thought I'd join RCGroups Saito club. I've got a Rascal 110 with a 150, a Kadet Sr. with a 91, a PT-19 with a 65, and a four star 40 kit that may have a an old 50 in it's future...
I've also owned a couple 82's over the years in planes that are no longer in my hangar.
cjneal is offline Find More Posts by cjneal
Old Sep 17, 2009, 07:49 PM
MikeMcChiken is offline
Find More Posts by MikeMcChiken
Fly'em like you Stole'em
MikeMcChiken's Avatar
The Gehto,Ca.
Joined Jun 2008
Originally Posted by rodneygt
Mike, here's a google translation from the Japanese Saito site: http://translate.google.com/translat...ate.google.com
They call it the FG-14. You will have extra weight from the ignition and ignition batt.
If you do the currency coversion it comes to $630 . WOW !!!
Looks sweet though . I wouldn't use there mount though . It's cast not billet .
*******CJNeal , Welcome and nice birds .********
A friend in my club has a PT-19 and puts little people with parachutes in the cockpit . Then does a roll and they come out floating , if there chutes open .
MikeMcChiken is offline Find More Posts by MikeMcChiken
Old Sep 18, 2009, 05:30 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I assume my new Saito 82 is in the mail. Any tips on the break in other than follow the instructions. Any instructions I should not follow and do something else instead. How much fuel do I have to run through it before I can fly it?
u2builder is offline Find More Posts by u2builder
Old Sep 18, 2009, 07:04 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Should I put a velocity stack on the 82a? The word document by Robison mentioned earlier in this thread says they save fuel. Horizon says this one:SAI50GK93 by Saito Engines fits the Golden Knight 82a so should I assume it fits the regular 82a.
Old Sep 18, 2009, 07:14 AM
rodneygt is offline
Find More Posts by rodneygt
Registered User Wannabe
rodneygt's Avatar
Southwest Mississippi, USA
U2, here's some links where saito break-in is discussed:
http://www.rcgroups.com/forums/showt...php?p=12614516
http://www.rcgroups.com/forums/showt...php?p=12187604
http://www.rcgroups.com/forums/showp...14&postcount=3
The only difference between the golden knight 82 and the regular one is the velocity stack and the black coating/gold colored valve covers. So it will fit. The v-stacks are about $7 so I ordered one when I bought my new on-sale 82.
My GK .82 has the stack and it doesn't spit fuel like I've heard that some do. I've read but don't know that they increase fuel economy.
If mounting on a profile plane, you may have to drill out a little area on the fuse for v-stack to fit but that's no problem.
rodneygt is offline Find More Posts by rodneygt
Old Sep 18, 2009, 07:25 AM
I TOBOR is online now
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
U2, just remember that the first 10 minutes is with the throttle at 1/4 to 1/3rd open. Some have gotten confused and think that the throttle should be open all the way and the mixture so rich it will only turn 4,000. As soon as the first 10 minutes are done I lean the mixture so it will run without the glow lighter attached. That's still pretty rich.
I TOBOR is online now Find More Posts by I TOBOR
Old Sep 18, 2009, 11:25 AM
FedericoA is offline
Find More Posts by FedericoA
Italy, Sicily, Palermo
Joined Sep 2006
Hello i have a saito 115 on my new H9 HELLCAT warbird i need propeller recomandation urgent PLEASE.
The shop i buy as i asked for a three blade propeller they gave me a GRAUPNER 12,5/7 do you think is correct for that plane because phisically seems a bit small....Tomorow morning i will do my maiden so i don't want to do mistakes !
And for a two blade ?
FedericoA is offline Find More Posts by FedericoA
Old Sep 18, 2009, 11:40 AM
cjneal is offline
cjneal's Avatar
Joined Oct 2006
Federico...do you have a tachometer? This is the best way to determine the if you're using the right prop. I usually prop my saitos so that they do not run above 8500 rpm static (on the ground) when at full throttle.
Old Sep 18, 2009, 11:51 AM
Joined Sep 2006
I'm sorry i don't but i will ...for my saito 115 on the hellcat H9 what you suggest as a propeller ?
Old Sep 18, 2009, 01:01 PM
I TOBOR's Avatar
Joined Feb 2007
Type:4-stroke
Displacement:1.15 cu in (18.9cc)
Bore:1.25 in (31.7mm)
Stroke:.94 in (24mm)
Cylinders:Single cylinder
Total Weight:23.49 oz (665 g)
Engine (Only) Weight:20.6 oz (585 g)
Muffler Weight:2.89 oz (80 g)
Crankshaft Threads:M8 x 1.25mm
Benchmark Prop:APC 15 x 6 @8800 rpm
Prop Range:14 x 8 16 x 6
RPM Range:1,800 to 10,000 rpm
Fuel:10/30% nitro with synthetic/castor mix
Mounting Dimensions:115 x 60 x 110 (L x W x H) crankcase - width 40 / mounting holes - 50 OC
Muffler Type:Cast
Cylinder Type:AAC
Carb Type:2 Needle
Crank Typeual Ball Bearing
These specs direct fom Horizon and should be in your instructions.
PS, Sorry Frederico, I missed the three blade part, you may be alright with the 12.5x7 3B. My Fox .74 Diesel turns the 12x5x7 3B at about 8,300.
Old Sep 18, 2009, 01:10 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
I answered this in the other thread but here goes again, 12.5x7 will allow it to overrev big time.
Good stuff ITobor...always good to go back to the book.
Like CJ says, 8500 static is around max load on a motor.
10K static is about max static that you want.
When you get around 10,500 then you will overrev the motor in the air when it unloads.
Dad_Roman is offline Find More Posts by Dad_Roman
Old Sep 18, 2009, 01:23 PM
I TOBOR's Avatar
Joined Feb 2007
Hey there DR, I tend to prop the .50 and over Saitos in the mid nines and the .45 and under at about 10,000, the little .30s really shine at about 10,100 on a Graupner 10x6 or 10.5x5.
Old Sep 18, 2009, 01:55 PM
rodneygt is offline
rodneygt's Avatar
Mike,
Would you consider going back and editing post #1 to add a direct link to this page of the thread and maybe label it "saito break-in" or similar. It would make it much easier to find the saito break-in procedures on this page. Otherwise, this page will eventually be lost in the sea of other pages in this thread.
Thanks.
Rodney
Old Sep 18, 2009, 02:04 PM
rodneygt is offline
rodneygt's Avatar
FWIW, I was running a master airscrew 14x7 3-blade prop on my saito 1.00. It was turning around 9300-9500 static on 15% fuel.
Old Sep 18, 2009, 04:47 PM
The Gehto,Ca.
Joined Jun 2008
You might have trouble getting air in there with a stack on it . You will have to have a hole cut through the motormount on the Primo or it will be a small gap in there .
Hows that RodneyGT , I assume you were talking about I Tober's tip .
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 03:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 02:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 10:52 PM
