Old Jan 25, 2013, 09:47 AM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
Originally Posted by DarZeelon View Post
It is not, Sr., as far as your conversion ratio goes; although you eventually did reach a right final result...
You seemingly used a length in inches of one tenth of one meter (one decimeter)...
It is an area ratio, not a length ratio!
One square foot is .3048 m by .3048 m.
A square decimeter is .10 m by .10 m.
So, a sq. ft. is 9.290304 sq. decimeter.
An ounce is 28.3495231 grams, so 81-90 grams in ounces is equal to 2.857-3.175.
So, the specified wing loading in imperial units, is 26.54 to 29.49 oz/sq. ft..
Man you just can't leave well enough alone.
I used decimeters as that is what the area is spec'ed. I didn't have a formula for square decimeter to square feet handy & since I once made my living W/math, I just used what values were known, 1 decimeter = 3.937".
You like spllitting hairs so much you should be a barber. So I missed it by 1/10oz per sq ft, so what?That's les than .3%. It's an estimate. I used to estimate for a living only it was in 100s of 1000s of $$$$ & sq ft was a given.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Jan 25, 2013, 10:40 AM
paulinfrance is offline
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
I ALWAYS use gms/dm2 and they all fly better for it,,,
paulinfrance is offline Find More Posts by paulinfrance
Old Jan 25, 2013, 12:38 PM
DogFly. is offline
Find More Posts by DogFly.
sKrude up, Rejected!
DogFly.'s Avatar
United States, FL, St Augustine
Joined Jun 2008
maxadventure,
Almost sounds like you and I should swap engines , then we both might have something that works.
My problem is that I check Great planes, they have a 50 size that calls for the FG14, maybe I should look at their Corsair50.
This engine size business is very confusing to somebody with no rc engine experience.
If all else fails, I might just give up, and trade this engine for something electric power.
DogFly. is offline Find More Posts by DogFly.
Old Jan 25, 2013, 02:33 PM
maxadventure is offline
Find More Posts by maxadventure
Talk soft, carry a big plane.
maxadventure's Avatar
northern colorado
Joined Jul 2007
Originally Posted by DogFly. View Post
maxadventure,
The swap is tempting, but I love my .65 too much! If you have a model rated for the FG14, you at least have a reference wing loading- just try to match that and you should have similar performance.
Really, it's not a bad idea to hold on to the FG14, bench run it to break it in and at the same go electric to at least work with the plane you want to fly.
just thinking out-loud
maxadventure is offline Find More Posts by maxadventure
Old Jan 25, 2013, 02:42 PM
DogFly. is offline
DogFly.'s Avatar
Joined Jun 2008
Hi Max,
Thanks for the response, I'll keep it, probably order the GP Corsair down the road.
I have quite a few electrics to keep me busy for now.
Old Jan 25, 2013, 03:32 PM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Dog, do your self a favor and forget about paper horse power, I long ago figured out that a same sized four stroke will fly a given plane just fine. Flying power is the name of the game and four strokes have it in spades. This Saito .30 flies a Sig LT 25 exactly the same as a Fox or Irvine .25, I use a Graupner 10.5x5 in grass that is a little long and 10x5.5 in short grass. When the 10.5x5 is used it litterally leaps off the ground.
I TOBOR is offline Find More Posts by I TOBOR
Old Jan 25, 2013, 03:43 PM
DogFly. is offline
DogFly.'s Avatar
Joined Jun 2008
I TOBOR,
Thanks for your response, as I stated in my earlier posts, I was hoping to build the TF Spitfire60 Gold Kit, to put the SaitoFG14b into, as it seems the 40 size kits would be cramped with all the necessary equipment.
Unfortunatly, I don't have the experience with gas engines to know if this engine will work with that kit.
http://www.rcplanet.com/TP_Spitfire_...p/topa0140.htm
What do you think?
Old Jan 25, 2013, 04:13 PM
I TOBOR is offline
I TOBOR's Avatar
Joined Feb 2007
Well, I am not a fan of gas, too much extra junk to accomplish the same thing, but it should work. I like the fire it up and go when using glow and Diesel.
Old Jan 25, 2013, 06:55 PM
I HATE GLOW PLUGS!
Joined Feb 2012
There's also a significant power loss too.
That size GAS 82 will be down on power from a GI 82. Still plenty of power for the right size/weight airframe.
It's just too big for a 40 sized inline engined warbird, & not up to snuff for 60 sized version of same.
It would probably work great in a 60 size cub, Bird Dog, Cessna 180, etc. An 80" Fieseler Storch would be happy W/that engine.
Actually I thought the 50 size Spitfire W/the FG14 was great idea if the OP can get it all stuffed in & he can handle the wing loading W/the narrow maingear.
I would probably give it a try if iI wanted to give an FG14 a home.
Actually, I would probably get a methanol carb/manifold & then it would have a bit more power.
Old Jan 25, 2013, 11:39 PM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
As I wrote, Sr., I do tend to cross my 't's, dot my 'i's and see others are doing the same.
The correct factor to covert from grams/sq. dm. to ounces/sq. ft., is 3.05 (close enough), by which you need to divide the former to get the latter.
DarZeelon is offline Find More Posts by DarZeelon
Old Jan 26, 2013, 02:28 AM
Joined Aug 2011
Yes quite right forget the figeres, i was flying the P40
http://www.rcplanet.com/TP_P_40E_War...p/topa0120.htm
in the 90's with retracts, flaps (a waste of time and weight) on an OS .70 surpass, although they recommend a .90 to .120,,,, so this Topflight spit look like it's for you , i am currently fly a Marutaka Spitfire from the 90's with an Enya .90 4 stroke, retracts and plug warmer and Grossly over weight and it's fine.
ps Tobor,, how does the engine run with your fuel tank setup
Old Jan 26, 2013, 07:36 AM
I TOBOR is offline
I TOBOR's Avatar
Joined Feb 2007
Hey Paul, thanks for asking. That is my 3rd LT 25, the 2nd had a nose gear, I set this one up originally for an Irvine .25 Diesel conversion, But the little .30 begged me to use it again, I leaned the engine over to get the Irvine muffler outside the fuse so I stayed with that theme.
Old Jan 26, 2013, 08:28 AM
I HATE GLOW PLUGS!
Joined Feb 2012
I converted inches to decimeters, then used that factor to SQUARE 3.937 for the conversion of sq decimeter to sq in.
Yes you have the correct factor for an easier conversion but I used what I had & it was correct. No i or t left un dotted or crossed.
Old Jan 26, 2013, 08:35 AM
DarZeelon's Avatar
Joined Nov 2003
OK, Sr.
Old Jan 27, 2013, 12:55 PM
Joined Aug 2011
6 and bl,,,, cold but the ronron of the Saito .90 Ts kept me warm,,,,
Fokker Eindecker 80" (4 min 8 sec)
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 03:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 02:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 10:52 PM
