![]() right now I have to spend $2000 getting my truck fixed. ![]() So I'm thinking 2-3 months. ![]()
Read the posts carefully, especially those like Dad_Roman and I TOBAR, who have provided some excellent un-biased advice over the years. Love the engine, love the plane - best of luck if you go forward with it! |
Like I said in my first post, new to gas engines.
I'm trying to find the best airframe for this motor, would like to go with a spit, what would you recomend? How about this one: http://ak-models.com/mm5/merchant.mv...egory_Code=CMP |
Personally would love to get my hands on an FG14 for my 1/6 L4. One concern for these small engines is the prop clearance. By the time you find a small enough model for the power, they may not be able to swing the best prop. (currently have this issue with my L4 and a Saito 65, not sure how to fit the FG18 - but I still want to!) Keep in mind, I don't think anyone said don't do it, just be aware of the challenges and plan to meet them. Heck it would be awesome to hear how it worked great. I think we're just trying to point out the gotchas so you can make the best of it. As far as your last link, as a small fiberglass pre-built, I'm guessing heavier than a balsa at this size - but I'd defer to those with more experience. You will want to be as light a wing loading as possible, like a larger scale but stripped down for weight savings. *shrug* it's really hard to find the perfect plane for an engine. I always seem to fall in love and get an engine, then start thinking about what to put it in. I have three engines needing projects right now sitting around from that same method! FG36 , FG20 (actually in a plane, I just don't like it!) & YS 1.10 |
Heck, the right prop and a nice build may be great with your first kit choice. I'll stop going off on the subject, it's just that I've 'been there and done' that several times over the years. |
A gas 4s 82 would be suitable for a 40 sized airframe. But a 40 sized airframe will be small when you try to house the ignition module, ignition battery, etc. It can be done on SOME 40 sized airframes, but it's shoehorn fit. The extra weight/bulk could be offset by the much smaller gas tank that would be required.
A 60 size would be better as far as room for components, but the FG82 would be very marginal for a 60 size. For the life of me, I don't know why Saito bothered W/such a small engine for gas. I think the bottom limit should be around 1.00 cu in (16cc) for 4s gas, 1.20 (20cc) would be more practical. |
Use a seperate battery pack for the ignition W/it's own switch/charging jack. You can use a NiMh 650Ma 4.8v pack if you remember to recharge after every other 10 minute flight. A 650ma pack should run the CDI for about 40 minutes max, 20 minutes run time betweenj charges gives you a safety margine. For the throttle linkage utilize a nylon pushrod such as a Sullivan Goldenrod to minimize the chance of RF from the ingnition being conducted near any servos or the Rx. It does look like a good match sizewise as long as eveyrthing fits into that small, narrow nose. Something W/a "round engine" like a P-47,or Focke Wulf FW190A might make it a little easier to get all that equipment stuffed into the nose. If the OP is not an experienced pilot, the narrow maingear on the Spitfire might be a bit challenging too. That would also make the P-47 or FW190 better choices. My "English" wing loading calc comes out to 29.4oz per sq ft. Does that sound reasonable? I used 3.937" per decimeter. |
Hey guys,
Thank you all for helping educate me, with no experience with gas, it's better to ask people with the experience I lack. I have been flying for some time, I may not be Top Gun, but I feel competent with my skills. This seems to be an odd size engine, at least for what I was hoping to do with it. Understanding that the engine is a little under powered for the TF Spit, I thought the 2nd choice to be more of a usable size, however the weight was more because of the fuse being fiberglass. Also, the nose being narrower, it would be harder to fit the module in. So the idea of a FW190 or a P-47 sounds pretty good if the Spit won't have enough space for the gear I need to run. I prefer the idea of a P-47 because of the wider wing chord, although the FW190 sure has a classic look to it. Any suggestions guys? |
You seemingly used a length in inches of one tenth of one meter (one decimeter)... It is an area ratio, not a length ratio! One square foot is .3048 m by .3048 m. A square decimeter is .10 m by .10 m. So, a sq. ft. is 9.290304 sq. decimeter. An ounce is 28.3495231 grams, so 81-90 grams in ounces is equal to 2.857-3.175. So, the specified wing loading in imperial units, is 26.54 to 29.49 oz/sq. ft.. |
| Thread Tools | |
| Composites Forum on RC Groups? | TGoodwin | Composites Fabrication | 9 | Oct 01, 2004 03:49 AM |
| PLEASE KILL ACTIVE X on RC Groups. | windsurfer | Site Chat | 7 | Apr 19, 2004 02:16 PM |
| Help! Large font on RC Groups! | Lenny970 | Site Chat | 4 | Mar 20, 2004 10:52 PM |
