Old Jan 09, 2013, 09:10 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Originally Posted by I TOBOR View Post
Dar, you left out one important aspect of living DownUnder, that is when you gain weight you get lighter.
And the the Aussies begin to float and fall off the planet???
DarZeelon is offline Find More Posts by DarZeelon
Old Jan 15, 2013, 11:57 PM
old_dan is offline
Find More Posts by old_dan
Cognito, Ergo Imbibo
old_dan's Avatar
Morgan Hill, CA
Joined Sep 2007
Originally Posted by Dale 813 View Post
Question. Saito 1.50 is the compression suppose to get stronger as the throttle goes higher? I can seem to start mine unless its at idle. I have a heavy duty starter and it won't turn it unless its at idle. Also. It shuts down abruptly at around 30% throttle ?? I edited this after doing some thinking. I have convinced myself that it must be rich. And I must be chasing needles.
When the throttle is closed or nearly closed, very little fuel/air mixture enters the cylinder. The effective compression ratio is much lower, so the engine is easier to turn.
If you think it's rich, try a couple of things to verify before you start turning needles...first, get it running (at 30% throttle if necessary). Take note of what happens when you un-hook the glow driver. If it is way rich, you'll notice an RPM drop when you take the driver off. Once you have the glow driver unhooked, try a pinch test on the fuel line. With it running as slow as you can get it, pinch off the fuel line. If it revs up before it dies, it is rich. You want it a little rich, so once it's adjusted correctly, it will rev up a small amount and then die. If it drops off without revving up, it is probably lean.
Keep in mind that on most of the Saito carbs, the idle screw and the high speed screw oppose each other...so one will affect the other. If it's way to rich at the high end, it will be rich at idle too. If you lean the high end, you'll need to re-visit the idle mixture.
On a just assembled carb, I would start at the high end, then work the idle. Part of setting the idle up well is getting it rich enough so that it will transition well to the high end. Too rich at idle and it will load up while you taxi out to the runway.
Dan
old_dan is offline Find More Posts by old_dan
Old Jan 16, 2013, 10:37 AM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Dan, I've said this before but, since the High Speed needle operates in a fixed seat, setting it first eliminates one variable. As you hinted at, setting the HS needle rich will only lead to chasing the LS needle all over the place. We see this quite often when someone says,"I messed with both needles to no avail." Everything works better with a plan. Willy nilly tweaking leads to great frustration.
I TOBOR is offline Find More Posts by I TOBOR
Old Jan 19, 2013, 08:15 AM
paulinfrance is online now
Find More Posts by paulinfrance
Living in the south of France
paulinfrance's Avatar
Joined Aug 2011
I ran my saito 90 Ts for the first time yesterday in my Fokker Eindecker, boy is she sweet,,,
paulinfrance is online now Find More Posts by paulinfrance
Old Jan 21, 2013, 10:14 PM
hutchinstuff is offline
Find More Posts by hutchinstuff
Hutch
hutchinstuff's Avatar
United States, Mt, Bozeman
Joined Jan 2012
Anyone have a 65 piston/cylinder just collecting dust?
hutchinstuff is offline Find More Posts by hutchinstuff
Old Jan 23, 2013, 12:20 PM
DogFly. is offline
Find More Posts by DogFly.
sKrude up, Rejected!
DogFly.'s Avatar
United States, FL, St Augustine
Joined Jun 2008
Hey guys,
I have a saito fg14b, I'm new to rc gas engines.
So I'm trying to figure out what size airframe will work with this plane.
I would like to get a Spitfire, would like to get an arf, I'm trying to figure out if this engine will power a 60 size spit ie: TF 60 Spit.
Can anybody help steer me in the right direction?
DogFly. is offline Find More Posts by DogFly.
Old Jan 23, 2013, 04:19 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
I went down this path about a year ago. Tried and tried to find a parts motors and thier just were'nt any to be had. Finally hooked up with and Aussie who had a torn up head and needed my broken bottom end. He was a nice guy so I sent mine to him so that at least ONE of us in the world could have a motor out of it.
Those were the last two broke 65's in the whole world....sorry
Originally Posted by DogFly. View Post
Hey guys,
Since that equates to an 84 sized engine....is that enough for you?
I would say it will do the job but your flights are liable to be VERY scale.
Its handicapped going on a fighter airframe and then being a 4 banger. My guess would be for a Saito you would want something closer to a 1.00 to 1.10 class motor which would set you in the 20-23 range on FG sizing.
.....but thats just me
Dad_Roman is offline Find More Posts by Dad_Roman
Old Jan 23, 2013, 04:47 PM
DogFly. is offline
DogFly.'s Avatar
Joined Jun 2008
Thanks Dad_Roman,
I think I found the right plane!
It's the TF Spitfire IX Gold Edition, looks like my motor will fit this one just right.
And I'm part of the Saito engine club.
Old Jan 23, 2013, 05:00 PM
SrTelemaster is online now
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
The gas makes 15% less power as a rule, so it would run more like a 70 glow 4-stroke..
SrTelemaster is online now Find More Posts by SrTelemaster
Old Jan 23, 2013, 06:10 PM
DogFly. is offline
DogFly.'s Avatar
Joined Jun 2008
Looks like I my try to build a kit plane, that's half the fun!
Top Flite Spitfire MK IX Gold Edition Kit TOPA0140
Requires:
4-6 Channel Radio w/5-7 Servos
1-Y-Harness for ailerons
1-Servo Extension for Ailerons
.61-.75 2-stroke or .70-.91 4-stroke engine
Looks like my Saito will work in this one.
Old Jan 23, 2013, 06:30 PM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
My point exactly. Then you put it on a fighter airframe, high wing loading, low aspect ratio, etc, etc.
Dogfly...welcome to the group. All we are saying is that it is fairly marginal. Does the kit say ok?...yes. But notice its the absolute very BOTTOM of the recomendation.
It will fly it. Just going to be scale like, no R/C airplane yankin and bankin, long rollouts on take off, no floating in on final, no flyin on the prop, and (if) when the wing stalls, it dies.
I actually enjoy and appreciate a scale type of flying, but Im also very aware of the limitations of this in our sport. Most seem to enjoy the availablity of extra power our sport can (easily) provide us.
Nice combo, I wish you the best and it should be fine. Keep us apprised
Old Jan 23, 2013, 06:36 PM
DogFly. is offline
DogFly.'s Avatar
Joined Jun 2008
Dad_Roman,
If you look at the specs:
The FG14 is an 82 if I've been learning right, so that's right between a 70 -91.
Old Jan 23, 2013, 06:40 PM
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Yes, of course your correct. Just used to most guys. When going 4 stroke they usually go with the upper end or bigger. (except me)
Old Jan 23, 2013, 06:44 PM
DogFly. is offline
DogFly.'s Avatar
Joined Jun 2008
I think the 82 should work fine, not too fast, but not maxed out either.
Old Jan 23, 2013, 06:49 PM
I HATE GLOW PLUGS!
Joined Feb 2012
Mines about as big as it needs to be.
A 1.80 CDI 4-stroke single that will spin an 18x8 @ 8850 & idle @ 1100.
Gets better fuel economy than a stock FA180 on GI.
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 04:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 03:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 11:52 PM
