Old Oct 24, 2012, 10:46 PM
Brutus1967 is offline
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
You can visually inspect the needle for damage on the tapered part and straightness. Usually if the needle is damaged, the seat will be also, but that is no guarantee.
Don't know what your background is with model engines, but you have to be very careful when adjusting valves, as the spring pressure is not that high, and it is very easy to push open the valves with the feeler gauge and consequently adjust the valves too tight.
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Oct 25, 2012, 12:50 AM
the pope is online now
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
I have a TT 54 which had seat damage . You could wind it in and still not lean it out , also if you put a bit fuel tube on the nipple and blow into it even when the needle is wound in it will still let air past . Cheers the pope
the pope is online now Find More Posts by the pope
Old Oct 26, 2012, 12:26 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
No one mentionned it but it is also very important that the needle is absolutely perfectly centered inside the holder, even more true with the old glows and diesels. If not the spray does not work correctly. I have seen engines where the needle did touch the side of the spraybar.
Reginald is offline Find More Posts by Reginald
Old Oct 26, 2012, 09:59 PM
skypup is offline
Find More Posts by skypup
san antonio, texas
Joined Mar 2002
saito 60 twin
I've searched this thread with few results. Is anyone running the saito 60 twin? I bought one today on ebay which looks to be in good condition with little use. It would be nice to hear from someone who has experience with this little gem. Thanks.
skypup is offline Find More Posts by skypup
Old Nov 04, 2012, 07:56 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I just saw that Saito is also offering a FG-33R3. That is a 33cc 3 cylinder radial.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Nov 05, 2012, 04:47 PM
cherokeenut is offline
Find More Posts by cherokeenut
United States, CO, Dacono
Joined Nov 2010
Ok Club Saito here's a question, I have two FA -80's one has a large diameter chrome exhaust and the other has a smaller diameter black exhaust. Are these just early and late models, is one more powerful than the other?
cherokeenut is offline Find More Posts by cherokeenut
Old Nov 05, 2012, 08:29 PM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
Greg
Sounds like a gasoline version of the 200R3.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Nov 06, 2012, 12:56 AM
old_dan is offline
Find More Posts by old_dan
Cognito, Ergo Imbibo
old_dan's Avatar
Morgan Hill, CA
Joined Sep 2007
Can you post a pic of the two engines? I have a couple of FA-80's. One came with a straight muffler. When it broke off from age, the replacement is the current design which is bell shaped. My other one has an aftermarket exhaust....I bought the engine used, so I never saw the factory exhaust.
Dan
old_dan is offline Find More Posts by old_dan
Old Nov 06, 2012, 02:31 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
There were two versions of the FA-80, but I'm unsure if the mufflers coincided with the different pistons. The early FA-80 had a domed piston. This can be seen in Clarence Lees review in 1987. When Americans had problems with detonation using glow fuel containing nitromethane, Saito changed to a flat top piston to reduce the compression ratio a bit.
Greg
Old Nov 06, 2012, 03:23 PM
Joined Nov 2010
I wonder it the one with the small pipe is the early, we have to run a 12-8 prop because anything bigger it starts knocking badly and will spit the prop.
Old Nov 06, 2012, 03:33 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I have one with the skinny aluminum muffler and it's a flat top piston. With an engine potentially 25 years old and unknown history, its' anyone's guess. The importers also offered cylinder shims to reduce compression ratio.
Greg
Old Nov 06, 2012, 06:29 PM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
I bought a second hand FA-80 today. Hope it works! it has a dented left pushrod cover and the rubber boots are split. This should fix it. But how do I go about fitting the parts?
Saito -nuubby
Wing-span is offline Find More Posts by Wing-span
Old Nov 07, 2012, 11:27 AM
I HATE GLOW PLUGS!
Joined Feb 2012
Saito -nuubby
1st you will need to remove the rocker covers to access the rocker/pushrod interface.
Loosen & remove the cylinder base screws & W/the piston @ TDC raise the cylinder just enough to remove the tubes & pushrods. Try not to mix up the pushrods & do not get them flipped end for end.
Place the new tubes/seals W/the pushrods in them & lower the cylinder into its proper place all the while making sure that the pushrods/seals/tubes are installed correctly.
After tightening the base screws, check the valve lash & set it @ .4mm (.0015").
Install the rocker covers & you are done.
Old Nov 07, 2012, 03:40 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Thank you.
Seems simple but I will have to work out how to set the .4mm tolerance as I do not have a gauge or tool to do this, yet. I'm not sure what you mean by 'valve lash' is this a reference to the timing of the valves?
Old Nov 08, 2012, 07:01 AM
I HATE GLOW PLUGS!
Joined Feb 2012
Thank you.
With the piston on TDC & both valves completley closed (on the EX/IN TDC they will both be slightly opened) there must be slight clearance. (lash)
You can get a feeler guage @ any well stocked auto parts store or Sears. Make sure it has a .0015" gauge. A .002" will work.
Loosen the locknuts on the adjusting screws & adjust the lash so that a slight drag is felt when the gauge is withdrawn. Double check after tightening the locknut as lash tends to increase or sometimes decreases when the locknut is tightened.
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 03:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 02:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 10:52 PM
