Old Oct 22, 2012, 05:27 AM
Gary Cee is offline
Find More Posts by Gary Cee
Censor yourself
Gary Cee's Avatar
Joined Apr 2010
Yes , 1 1/2 times the diameter is the rule of thumb . The thread pitch and material hardness are other factors . Fine threads in soft materials do not hold as well as coarse threads . If the thread pitch is 0.5 MM , 6 threads would be 3 mm . Rules of thumb , like thumbs are often broken. There is little need for a lot of tension on the backplate cover so this is not a maximum clamping force application .
Studs rather than screws at any rate are a safer bet as they square up better and allow full thread purchase. . If you are using a bushing , by the time you allow for an inside and an outside thread it would seem that just using a larger screw could be a better option . If the screw in use is a 3 MM , the 3.5 mm screw or even a 6-32 could be an option as they are smaller than 4 MM .
Gary Cee is offline Find More Posts by Gary Cee
Old Oct 22, 2012, 09:07 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
As long as the clearance hole for a 4mm screw leaves enough material on the lug of the backplate, that's the easiest way to go.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Oct 22, 2012, 09:21 AM
Gary Cee is offline
Censor yourself
Gary Cee's Avatar
Joined Apr 2010
Greg
Of course,
The 3.5 MM and 6-32 were given as options in the event the 4 MM (preferred) was too large . However , a 4 MM threaded bushing would not have sufficient meat to adequately accept a 3 MM internal thread .
Old Oct 22, 2012, 09:24 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Greg
I'll look at that tonight when I get home. In my mind right now it seems that lug on the back plate is not very big. If I do go the bushing route I would be able to keep all the screws the same size. I hate it when I need a different tool for one out of four bolts. I would like the repair to look "professional" instead of a cobbled up repair. Not that a larger screw would looked cobbled, it just doesn't match.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my other senator
Old Oct 22, 2012, 11:52 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
I would use a helical thread insert.
Greg
That's what I suggested, safest way. Or send the casting to Clarence Lee if you do'nt want to risk your engine.
Reginald is offline Find More Posts by Reginald
Old Oct 22, 2012, 08:28 PM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
delete
gregory.da is offline Find More Posts by gregory.da
Old Oct 22, 2012, 08:42 PM
williame3590 is offline
Find More Posts by williame3590
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
I just bought this model, video is from John the previous owner.
Saito 300 on C&H
Saito 300 on CH Ignition and 1/3rd Sopwith Pup Assembly (12 min 7 sec)
Bill
williame3590 is offline Find More Posts by williame3590
Old Oct 23, 2012, 06:23 AM
SrTelemaster is offline
Find More Posts by SrTelemaster
I HATE GLOW PLUGS!
SrTelemaster's Avatar
United States, NY, St Lawrence
Joined Feb 2012
Saito 300 on C&H
http://www.youtube.com/watch?v=I9_saL9qVTo
Bill
A 300T on C&H CDI is a dream to operate.
Stay W/a full synthetic oil for best results.
SrTelemaster is offline Find More Posts by SrTelemaster
Old Oct 23, 2012, 09:08 PM
sparkx38 is offline
Find More Posts by sparkx38
Livin ta fly
sparkx38's Avatar
United States, LA, Shreveport
Joined Apr 2011
OK I am glad I found this site dedicated to Saito's. I have a Saito 82 mounted on a tiger 60 upright. I broke it in per the manual and have gotten numerous good flights out of it (a couple of gallons if that much). Then it started back firing and at the time I didn't relize that a rich high end would cause this. I adjusted the valves with the supplied guage and the back firing stopped (best of my memory). Now I cant get it to run up to full RPM by needle adjustment to save my life. Its extremely sloppy on the top end and I cant get it out with the needles. Could it be the Valves I adjusted? So anyway I could use some help getting everything set back to a good starting point. I can't find the valve guage so I geuss I need to know what this should be set at and second a good starting point on the needle settings. And anything else I might be missing or need to consider.
sparkx38 is offline Find More Posts by sparkx38
Old Oct 23, 2012, 09:09 PM
sparkx38 is offline
Livin ta fly
sparkx38's Avatar
Joined Apr 2011
Saito 300 on C&H
Bill
Awesome model!
Old Oct 24, 2012, 08:35 PM
Gary Cee is offline
Censor yourself
Gary Cee's Avatar
Joined Apr 2010
Yes,understood. A Helicoil will still be a 4 mm OD,depending on pitchh. A bushing much larger than 4mm. The options are limited by space at times.
Old Oct 24, 2012, 08:45 PM
sparkx38 is offline
Livin ta fly
sparkx38's Avatar
Joined Apr 2011
Hmmmm thought this forum would be a little more helpfull!
Old Oct 24, 2012, 09:03 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Sometimes people are busy. Idle needle is flush with the throttle arm and the main 2.5turns out for basic setting. If you can't turn in the main needle enough to lean the engine it's possible the needle seat or needle are damaged. Valve clearance is .0015-.004". The manual is on the Horizon site for the product if you've lost yours.
Greg
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
delete
Old Oct 24, 2012, 09:10 PM
sparkx38 is offline
Livin ta fly
sparkx38's Avatar
Joined Apr 2011
Greg
Sorry! Didn't mean to sound pushy or rude. How can you tell if the needle or seat are bad?
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 03:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 02:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 10:52 PM
