Old Jan 29, 2012, 03:37 PM
chiefw is offline
Find More Posts by chiefw
Joined Jan 2012
Saito 62 Help
I have a Saito 62 now in the hangar for a massave fuel leak around the cam housing. In reading another post, it stated to install the connecting rod with the dimple facing the backplate and the short piston boss towards the intake port. Having NOT removed the rod and purchasing the engine new, the dimple faces the prop and not the backplate. Is this correct? Will I still install the shorter piston boss towards the dimple? Also asking for information on cam installation and timing.
chiefw is offline Find More Posts by chiefw
Old Jan 29, 2012, 06:47 PM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Chief, the rod should face the direction that puts this flair next to the flywheel. forget about the dot.
I TOBOR is offline Find More Posts by I TOBOR
Old Jan 29, 2012, 07:11 PM
chiefw is offline
Joined Jan 2012
By looking at the conrod, not sure what the flair is?? Will it matter which way the piston is installed? Appreciate the help here
Old Jan 29, 2012, 07:21 PM
I TOBOR is offline
I TOBOR's Avatar
Joined Feb 2007
If you didn't take the rod out of the piston it has to go back correct, the flair is clearly visible on the bronze bushing, the other side is flat, this side is flaired or chamfered, I don't know which word is correct.There is a matching filet on the crankpin, (next to the counter weight) to avoid a square cut which might let the crankpin snap off. The extra bright spot on the bushing is part of the flair.
PS, the flair is a short inward taper like a funnel.
Old Jan 29, 2012, 07:44 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Chamfer is the word we're looking for.
gkamysz is offline Find More Posts by gkamysz
Old Jan 30, 2012, 09:24 AM
hutchinstuff is offline
Find More Posts by hutchinstuff
Hutch
hutchinstuff's Avatar
United States, Mt, Bozeman
Joined Jan 2012
Hello all,
I found myself what I believe to be an older 72, and am going to be rebuilding the carb with the HH carb kit. Anyone have a nice link to steps/advice on the rebuild? It seems like it should be easy......
hutchinstuff is offline Find More Posts by hutchinstuff
Old Jan 30, 2012, 03:55 PM
I TOBOR is offline
I TOBOR's Avatar
Joined Feb 2007
Hutch, if you have this spraybar the tiny slit goes upward toward the engine, on the .72 it may not be as easy to see as this one. Your pseudo needle valve will slide in and out over it like this one.
Old Jan 30, 2012, 05:02 PM
Hutch
Joined Jan 2012
thanks! does the spray bar just press through the carb assembly and out the other side? (I've got the barrel removed....)
Old Jan 30, 2012, 05:30 PM
I TOBOR is offline
I TOBOR's Avatar
Joined Feb 2007
Yes, it pushes in through the carb body.
Old Jan 30, 2012, 05:42 PM
Hutch
Joined Jan 2012
Got it, a fair bit of junk had built up in the spray bar assembly hole.. someone had put a fair bit of sealant crap on the fuel nipple threads. Is any of that sealant necessary?
Old Jan 30, 2012, 07:31 PM
MikeMcChiken is offline
Find More Posts by MikeMcChiken
Fly'em like you Stole'em
MikeMcChiken's Avatar
The Gehto,Ca.
Joined Jun 2008
Well , I got a e-mail from Horizon . It said my stuff shipped above the front bearing but the rear said still pending . We'll see if they both come . I figured they would wait till they had both but , oh well .
MikeMcChiken is offline Find More Posts by MikeMcChiken
Old Jan 31, 2012, 07:26 PM
I TOBOR is offline
I TOBOR's Avatar
Joined Feb 2007
No sir, the threads do just fine.
Old Feb 08, 2012, 10:10 PM
Dad_Roman is offline
Find More Posts by Dad_Roman
Twistaholic AMA 134406
Dad_Roman's Avatar
USA, TX, Teague
Joined Jul 2007
Hey Gents. I need a crankshaft for a 65. Lemme know if you have one you would part with please. I could use a rod too. Thanks
.....and how do I know if I need a short or long?
http://www.horizonhobby.com/products...t-g-h-SAI65148
http://www.horizonhobby.com/products...ng-4--SAI6523B
Dad_Roman is offline Find More Posts by Dad_Roman
Old Feb 10, 2012, 10:45 AM
lesliehowell is offline
Find More Posts by lesliehowell
LesterPester
Des Plaines IL
Joined Aug 2007
Sait 56 CAD drawing
Is this where somebody posted a CAD drawing of the Saito 56? I surewould like a good scale drawing of it.
Les
lesliehowell is offline Find More Posts by lesliehowell
Old Feb 10, 2012, 03:31 PM
Hutch
Joined Jan 2012
Hey Guys, I know I might be able to find this info somewhere... but wondering if I'll keep breaking the plastic Spinners (Great Planes) on my 72? I'm tempted to throw down for a tru turn, but the GP ones from tower are $3 each and match my color scheme! Is there something as good as tru turn but cheaper??? I've been starting with chicken stick, i'm not worried about starting with Electrons.
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 03:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 02:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 10:52 PM
