Old May 04, 2011, 06:07 PM
mt_flyer is offline
Find More Posts by mt_flyer
Montana Transplant
mt_flyer's Avatar
United States, TX, Sealy
Joined Aug 2005
Turbo Header test 1 is in;
Amb temp: 96*
1240 msl
Magnum .91 well used
APC 13 X 8
Stock Muffler
10750 lean to peak
10500 3 clicks to rich
2650-2700 idle
EGT 425* peak is 460*
CHT 248*
TH Muffler
10850 lean to peak
10600 3 clicks to rich (HSN is a 1 click leaner than stock muffler peak)
EGT 400* peak is 430*
CHT 240*
2200-2400 idle (not as rough)
looks like it will run cooler at a leaner mixture, higher RPM, smoother and slower idle... throttle response seems quicker with no hesitation. May have to go to a larger prop now.
mt_flyer is offline Find More Posts by mt_flyer
Old May 05, 2011, 08:37 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
Saitos are good, but they do require maintenance. Mine is roughly 3 years old and I have had to replace the bearings, and clean up a sticky exhaust valve. I am pretty hard on it though.
Sent from my ADR6300 using Tapatalk
teookie is offline Find More Posts by teookie
Old May 05, 2011, 10:12 PM
mt_flyer is offline
Montana Transplant
mt_flyer's Avatar
Joined Aug 2005
Amb temp: 96*
1240 msl
APC 13 X 8
Stock Muffler
10750 lean to peak
2650-2700 idle
CHT 248*
TH Muffler
10850 lean to peak
CHT 240*
UPDATE:
flight report...
throttle response is much better...
with factory muffler I flew for 10 min and had an average of 1 oz left in the 12oz tank..
TH muffler I flew for 10 min and had average of 3.5 oz left...
this was the average of 3 flights stock and 3 flights TH, flying the same pattern...
As far as I am concerned this is a good quality product with quality workmanship and savings/ performance benefits... and 4 more flights per gallon
Old May 06, 2011, 06:32 AM
GCplane is offline
Find More Posts by GCplane
GCplane's Avatar
Manassas, Virginia
Joined May 2008
MT, Which muffler has a better sound in the air? I mean sound more like a real plane or are they about the same? Which one is quieter?
GCplane is offline Find More Posts by GCplane
Old May 06, 2011, 08:16 AM
Jimmy Hoffa is offline
Find More Posts by Jimmy Hoffa
Jimmy Hoffa's Avatar
Orlando, FL
Joined Jul 2004
Castor will cause that.
Jimmy Hoffa is offline Find More Posts by Jimmy Hoffa
Old May 06, 2011, 09:30 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
MT, how did you measure the temperatures, specifically EGT?
Greg
gkamysz is offline Find More Posts by gkamysz
Old May 06, 2011, 10:17 AM
mt_flyer is offline
Montana Transplant
mt_flyer's Avatar
Joined Aug 2005
Old May 06, 2011, 10:20 AM
mt_flyer is offline
Montana Transplant
mt_flyer's Avatar
Joined Aug 2005
On this motor there was very little sound change.. I can't check db... by ear the TH is a little louder at high throttle.... can't hear any difference at idle..
Greg
I have temp probes... CHT uses a temp band that I put arount the cyl head in between the cooling fins...
EGT uses a long probe that I put into the exhaust about a 1/2" from the head
I back these up with an infrared gun... the cht has been right on.. egt slight difference reading the outside of the exhaust pipe at the head..
You could use a gun to get CHT and EGT for peak settings.
I have guest for the next week.. I will be testing the Saito 150 and a new Saito 100 once they leave...
Old May 09, 2011, 04:19 PM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Are the temps that you list pretty typical for a properly tuned engine?
Does the shiny aluminum on the cylinder influence the reading with an IR gun?
u2builder is online now Find More Posts by u2builder
Old May 10, 2011, 10:04 AM
mt_flyer is offline
Montana Transplant
mt_flyer's Avatar
Joined Aug 2005
the CHT is at a properly tuned 3-500 rpm richer than peak... I don't run them long enough at peak RPM to measure peak CHT as this can lead to motor damage.. (takes too long for head to get hot and cool down)
the EGT is at lean peak. egt will go down as mixture is richened...usually about 75-100*
IR gun will read any surface... very accurate.. +/- 3* difference than probe on mine
Old May 10, 2011, 12:15 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Read the manual on your IR sensor. Some can be switched to read polished surfaces some can't. Typically there is enough dirt on the engine to get a reasonable reading with any IR sensor.
EGT seems low to me, but it depends on where it's read. I'll be doing some measurements myself soon.
Greg
Old May 21, 2011, 07:51 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Hey Saito guru's, can someone help me with why my Saito 125 backfired when I went to start it.
It is a used Saito, but looks very new and was represented as being fairly new. It seems to have good compression. I adjusted the valves when I got it.
I set the needle at 5 turns out as per the manual. I did not adjust the low speed, assuming, perhaps incorrectly, that the previous Owner had it set properly.
Before I started it I cleared the prop by turning it a few revolutions.
When I put the electric started on it there was a violent backfire that removed the propnut, which I had tightened pretty well, as well as the prop nut, prop, and spinner.
It was a little scary with the prop flying off like that. Does anyone have any suggestions as to what I should do and/or check before I try to start it again. Thanks.
Old May 21, 2011, 07:59 PM
mt_flyer is offline
Montana Transplant
mt_flyer's Avatar
Joined Aug 2005
start it with the throttle almost closed.. barely above idle... too much throttle can cause that...also a lean mix... but it sounds like you have it rich...
hopefully someone else will jump in too..
Old May 22, 2011, 06:57 PM
CRFan1 is offline
Find More Posts by CRFan1
Northwest Indiana
Joined Feb 2011
Actually that is usually caused by a rich low end.....lean it out a it and hat will stop.
I do have a question for you guys though. I have a new Saito 100 in my new aeroworks extra 300 . It is broken in well but it seems to hang at a high idle when when you put the throttle all the way down and then it settles. Is that caused typically by a lean low end?
CRFan1 is offline Find More Posts by CRFan1
Old May 22, 2011, 08:08 PM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
U2, when using an electric starter do not prime it first. Let it pick up the fuel on its own.
I TOBOR is offline Find More Posts by I TOBOR
Composites Forum on RC Groups? TGoodwin Composites Fabrication 9 Oct 01, 2004 03:49 AM
PLEASE KILL ACTIVE X on RC Groups. windsurfer Site Chat 7 Apr 19, 2004 02:16 PM
Help! Large font on RC Groups! Lenny970 Site Chat 4 Mar 20, 2004 10:52 PM
