Old Jul 05, 2009, 06:58 PM
kylewoody is offline
Find More Posts by kylewoody
kylewoody's Avatar
United States, FL, Crestview
Joined Oct 2008
Modded HZ Super Cub
Hey guys,
I got a SC a while back, and flown it quite a bit - all stock. I finally decided I liked it too much to cut back on flying it just because of the stock electronics and paint job - so I souped her up!
She now has an Airtronics RDS8000 reciever, E Flite 20 ESC, two Hitec HS-55s, and 3S lipo power! Also redid her to match the L-21 aircraft. Still need the star decals (on order) and finish the wing. I think it looks good.
Anyways, I was wondering about my ESC - it's E Flites 20amp, brushed ESC which is powering my stock 480 gear drive. Will that ESC run fine on my 3S Lipo 2200mah (12C) packs? Those won't overload it, will they? The manual says it can take anywhere from 6-12 volts. It just seemed like my ESC was a bit warm when I did a static run in the living room.
As well, my ESC has the brake on it - so when you come to idle on the stick, the prop doesn't spin. Can I take the brake off on the particular ESC?
Thanks!
Kyle
kylewoody is offline Find More Posts by kylewoody
Old Jul 05, 2009, 07:02 PM
realtimerecon is offline
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
Your 1/2 the way there.Why not go w/ a Eflite 480(brushless) & 30A ESC....RTR
realtimerecon is offline Find More Posts by realtimerecon
Discussion HZ Super Cub on floats - First taxi test video FlyinLo Parkflyers 3 Dec 22, 2006 02:12 PM
Discussion Smoke grenade + HZ Super Cub with a brushless = good times TopCrest Parkflyers 1 Nov 06, 2006 03:26 AM
Discussion HZ Super Cub vs. PZ Slo-V biphfyt Beginner Training Area (Aircraft-Electric) 9 Nov 03, 2006 12:48 AM
Discussion HZ Super Cub Onboard Video HeliEddie Parkflyers 3 Sep 20, 2006 04:19 PM
Question HZ Super Cub ACT Wiring Question MikeyTG Parkflyers 0 Sep 16, 2006 07:11 AM
