carbondale il
Joined Jan 2007
Questions: Can I use unthinned dope on tissue? What are the drawbacks? If I need thinner will laquer thinner do?
The reason I ask is because right now I'm out of dope thinner. I have plenty of dope, though. I've started on the Thomas Morse Scout build. I have the fuselage built and I'm ready to cover it with tissue. Sometimes I build this way - covering the fuse which I build first before starting on the wings frames. Anyway, I cut down the formers, main keel and side keels by half. I used light weight stringers, too, and left out some of the stringers where I didn't need them to form the tissue so it looks like the weight is 50% lighter than it would be if I built it with the kit wood and with the stock parts. For the plastic cowl I put an insert in it for a gluing surface to glue it to the front of the fuselage and made a nose block which inserts into the cowl. For the rear motor mount I'm using an aluminum tube. So far so good! I thought it would be easier if I just had my oun thread where I can post everything I'm up to and with all my questions instead of making a new thread every time. I hope no one minds. Kev |
My 2 Cents here, as no other reply has showed up:
I wouldn't advice using unthinned dope, particularily not as a first coat on the watershrinked tissue, as it might cause irregular shrinking with the obvious result, or, at best, a heavy model..... If you are out of the proper dope thinner, try to find another thinning medium, like acetone or ordinary cellulose thinner. This will most likely work just fine....
carbondale il
Joined Jan 2007
Thanks Gluehand. I'll buy some more dope thinner. I was just wondering if I could take a shortcut and save some money. I'm wondering where the Scout is going to balance. The plan says to balance at 55% back from the LE of the top wing. I've found that most of the planes I've built if not all balance farther back than the plan indication. So I'm guessing at 75% of the top wing. Does anyone have experience with WW1 bi-planes like the Thomas Morse Scout?
Kev A free flight plane flying is like riding a bicycle with no hands. Instead of using the 2" plastic wheels which came with the Scout kit, I made wheels that are laminated basswood and balsawood 1/8" thick total. I used a small thrust bearing for the hub. They are lighter. I'm thinking about drilling 4 to 8, 3/8" diameter holes in them like spokes. Will the lighter weight pay off compaired to the added drag? |
carbondale il
Joined Jan 2007
I'm going to leave the RC Groups free flight forum for awhile. I don't know if I'll be comming back. I have just not gotten the responses to my posts I hoped for. Thanks to all of you who helped me with this great hobby and good luck to all of you with your free flight planes. If anyone wants to get in touch with me, my Email address is: universecitygraphicsandart@yahoo.com
Kev |
Kevin:
You have been a prolific poster to this forum and have come a long way. Like every phase of life you may not necessarily get all the answers you want, but that is life. Your contributions are appreciated and there are several people with lots of ideas to share and they do it willingly. You are well aware of those who make priceless contributions and are only too willing to share their expertise. These are the nucleus of the group. There may be the occasional self styled expert who will try and belittle others contributions, but these people are few and can be generally ignored. You do not necessarily have to be a frequent poster, and I would hope that you remain on the group and continue to be active, both on the group and in model flying. Regards, John |
eastern pa
Joined Feb 2007
Kevin, John and Jim said what a lot of us are thinking.
Your exploits in free flight modeling are an encouragement and inspiration to many who don't post here but use your threads for information. Check this out-this thread has 53 posts but it also has over 2400 views. 2400! That's a lot of people interested in what you have going on in your hobby life. I for one like to read your columns to de-stress after work. You have more time to build than I do and I have to substitute your modeling time for mine. Many nights I sit here visualizing your problems and how you're solving them. Don't assume since no one responds that no one is interested. Think about it but I hope you decide to hang around here on rcg. |
carbondale il
Joined Jan 2007
Thanks a whole lot, guys. I just felt like I had posted too much and was boring everyone.
I made another Parlor Mite changed a little from the inspiration from a plan designed by JWFinn. This one was a bi-plane covered with condenser paper. It really tried to fly. It got stuck in the air five feet from the ground and hovered for a total flight of maybe 20 seconds. I tried more power but it arched over and crashed breaking the wing post but leaving the bottom wing in place. So I tried to fly with one wing. It didn't do bad flying at five feet again but for a little longer. I've redesigned it with only one high wing. A friend bought my PC for me. I was so thankfull for it and thankfull still. I wouldn't have gotten this far in such a short time without the help here. Thanks again. BTY, scigs is blowing me away with his abilities. I was thinking about building a smaller version of my large self-designed plane but I started thinking why when the one I have flys so well? Does anyone have any ideas where I should proceed from here - any plane choices? Maybe a Gypsy. Kev |
I am Flying!
Kevin and others. I know you won't be too impressed, but after years of following this and other forums, I finally maidened just this week.
OK, I am not much of a builder or flyer, so, I bought a Icara Butterfly. I was so happy to actually fly it around my living room. Kevin, you and some of these other guys on this forum were my inspiration. And now I have flown. And this beautiful little plane will continue to inspire me to actually build something. First, I have to fix this thing already. Noticed a few breaks. But hey... So, thanks to all for keeping me moving forward on this. |
| Thread Tools | |
| Coverting a free flight foam to rc | Trobber | Foamies (Kits) | 2 | Oct 06, 2001 04:41 PM |
| Pegas free flight foamie modified to RC | leccyflyer | Parkflyers | 10 | Oct 04, 2001 07:43 PM |
| Hand Launch Free Flight | jrgii | Electric Sailplanes | 10 | Sep 14, 2001 07:44 PM |
| Newbie - Third incident-free flight with my SKY SCOOTER PRO!! | Trent Hare | Foamies (Kits) | 10 | Jun 03, 2001 09:24 PM |
| Any E-Zoners interested in free-flight scale jets? | steve glass | Scale Electric Planes | 4 | May 24, 2001 08:00 PM |
