Old Jul 05, 2009, 08:54 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Contest
2S 2200s at 44A (20c) & 30C (66Amps)
So how do some of the current 2S LiPolys stack up / compare at 20C?
I am not going to answer a bunch of questions or express a lot of opinions as I did not run these test but I will say they came from what I consider an extremely reliable source.
I have other Threads on 3S versions of these LiPolys and test results posted in those threads should answer most questions.
Charles
Old Jul 05, 2009, 06:50 PM
Southern Pride
2S 2200 at 30C (66A) discharge.
Wonder what happens when you push these a little harder? 30C seems reasonable for LiPolys rated 30-40C. I have never been interested in 1-1/2 minute flights myself but some use LiPolys in LMR events,pylon racing, extreme heli 3D and EDF so there are those who feel the need for extreme power.
Note TP ProPower is rated 30C ,Hyperion G3 VX is rated 35C and SMC is rated 40C.
Charles
Old Jul 05, 2009, 07:56 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
Another item in those plots which would be interesting is the integral--the area underneath the curves. It represents the energy (watt-hours) that is delivered out of the cells. Clearly the Thunderpower wins.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Jul 05, 2009, 08:17 PM
Southern Pride
CBA II Pro has the ability to display whatt hrs. instead of amp. Hr.
Greater volts under load at same amps. equals more watts,greater capacity delived in addation equals even more more watt hours delivered.
Charles
Old Jul 05, 2009, 08:25 PM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Charles, I have numerous lipo's incuding thunder power, The thunder power batteries out perform, charge quicker, ballance equally than all my other batteries, What have thunder power lipo's got what others haven't?
wellington53 is offline Find More Posts by wellington53
Old Jul 05, 2009, 08:38 PM
Southern Pride
Second sentence of post here
http://www.rcgroups.com/forums/showp...44&postcount=2
covers it I believe.
Note that post was in jest to the OP in that thread but in fact there are some who are never content with their current products and are always seeking improvements.
I have been reamed on other forums for even posting graphs of the ProPower 40s due to the simple fact that they are not available to the general population. This delay was not intentional and will be corrected ASAP but that could still prove to be a while yet. In the mean time PP 30s are available and not that far behind the 40s in performance.
Charles
Old Jul 07, 2009, 12:53 PM
write2dgray is offline
Find More Posts by write2dgray
write2dgray's Avatar
United States, NJ, Princeton
Joined Dec 2006
Funny how the packs stack up in reverse chronological order by C rating. That is the 30C is on top, followed by the 35C, then the 40C. Kinda throws that whole manufacturer C rating out the window.
- David
write2dgray is offline Find More Posts by write2dgray
Site Sponsor
Question Charging 2 x 2S packs at once Terry Rigden Batteries and Chargers 5 Nov 06, 2007 04:31 PM
Sold 2x 2s Hyperion Litestrom Vx 20c 7.40 2100'S $75 SHIPPED FASTBEN Aircraft - Electric - Batteries & Chargers (FS/W) 9 Oct 10, 2007 07:49 PM
Wanted 3600+ 2s (7.4v) packs 20c jerrit1 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 26, 2007 01:18 PM
Wanted POLYQUEST 2S/2100 or 2500mah (20C) PACK jazz8388 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 01, 2006 01:41 PM
Kokam 2s high discharge 340 (20c) katana1211 Aircraft - Electric - Airplanes (FS/W) 2 Nov 21, 2004 08:23 PM
