Old Jul 15, 2009, 09:32 PM
Dale Thompson is online now
Find More Posts by Dale Thompson
F3J-F3K-F3F- What to Fly??
Dale Thompson's Avatar
Cupertino CA
Joined Aug 2005
Originally Posted by mr_editor
A small off topic question, what are those locking components on the aileron L-bends called? They'd be perfect on a 'servos in the tail' install on my 60"
Du Bro EZ link's
Dale Thompson is online now Find More Posts by Dale Thompson
Old Jul 16, 2009, 03:17 AM
mr_editor is offline
Find More Posts by mr_editor
Biting ankles since '53
No Pants Island
Joined Feb 2007
Thanks. Maybe next year I'll be in a position to get a D40 to stick some on.
mr_editor is offline Find More Posts by mr_editor
Old Jul 23, 2009, 07:32 AM
Kahnx is online now
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
Joe
Planning my build and have a couple of questions:
1. You used a JR DS285MG servo for the elevator. Will a D47 or D60 do the job or are they too big? Any others you'd recommend that were successfully used on the blem batch?
2. What configuration of battery will fit? Brick, block, star or end-to-end pairs? AA or AAA? I cant get end-to-end pairs here and may have to roll my own - ugh!
3. How much nose-weight does it require to balance? What did you use? Melted lead or other? Suggestions?
Thanks in advance
Roger.
Kahnx is online now Find More Posts by Kahnx
Old Jul 23, 2009, 09:22 AM
joe manor is offline
Find More Posts by joe manor
Stay in it!!!!
Riverside, California, United States
Joined Aug 2004
Originally Posted by Kahnx
Joe
Thanks in advance
Roger.
I have used D47's for the elevator but they are a bit spongey for my taste. As of right now, I wouldn't go with anything but the JR285MG. There are probably other servos that would fit but I dont have any experience with them. The JR is a pretty tight servo.
I have been able to fit end to end pairs of AA's in there but they become stuck in the nose unless you mount your elevator servo really far back. That's not easy to do if your using the JR servo. If your going with the D47 it's no problem. Honestly, unless your planning on getting this plane a ways past 200MPH the D47 is a fine servo for it and they are very inexpensive. Im going to try to use the D47's in my next wing. I think they will do just fine. Just need to keep the link all the way down close to the output shaft of the servo. That goes for the elevator servo as well.
I have used shot as well as chunks of lead to balance these planes. I remember it taking 2.5oz. of lead when using a 4 cell AA pack. I prefer to use a 4 cell AAA pack but since Im going to use D47's in the next wing I will be using a 5 cell AAA pack. The AAA packs give a bit of extra room for your switch and receiver. It is possible (easily done) to position your receiver behind the elevator servo under the wing bolt and still have access to it. Not all receivers work but many do and some I just take the case off to make fit. Basically, there are many setup options available. Hope that helps.
Joe
joe manor is offline Find More Posts by joe manor
Old Jul 28, 2009, 10:07 AM
Dennis Everett is online now
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
Roger , what i do for nose weight is to find out how much you need , get the finest lead shot you can find , mix epoxy and shot together , pour into nose , use a bit less than you need so you can fine tune...Dennis
Dennis Everett is online now Find More Posts by Dennis Everett
Old Jul 29, 2009, 11:03 PM
Pismo is offline
Find More Posts by Pismo
Jim in San Diego
Pismo's Avatar
United States, CA, San Diego
Joined Nov 2002
Just don't over heat the nose and mess up the finish. I think people have suggested setting the fuse up to keep it in water to dissapate the heat.
Last plane I did that trick on I set it down flat to go do something else and forgot that lead shot mixed with epoxy doesn't like to stay in the nose unless you keep the nose down. D'OH! Nothing like a lead belly
Jim
Pismo is offline Find More Posts by Pismo
Old Aug 14, 2009, 04:38 PM
Kahnx is online now
Registered DSer
Kahnx's Avatar
Joined Mar 2003
Joe
A build question.
Can you please measure and advise the deflections (both ways) of the surfaces at the root of the ailerons and at the tips of the elevator. I want to program starting deflections into my dynamic build.
Thanks and Cheers
Roger.
Old Aug 19, 2009, 05:37 AM
Conwy-Soarer is offline
Find More Posts by Conwy-Soarer
Conwy-Soarer's Avatar
Great Orme
Joined Aug 2003
This is a real cool looking model, are they available in the UK and if so do you know how much including the shipping?
Conwy-Soarer is offline Find More Posts by Conwy-Soarer
Old Aug 19, 2009, 06:01 AM
Geo420 is offline
Find More Posts by Geo420
Mach 0.261 ... Hiccup of Wiggy
Geo420's Avatar
Wiggy Poo, England!
Joined Mar 2006
They are only available from Joe direct... I think / Hope its funding his huge ds plane habit... : )
$300 + $47 shipping + Vat was my cost.
Get one dude they rock!
George
Geo420 is offline Find More Posts by Geo420
Old Aug 19, 2009, 10:10 AM
KurtMc is offline
Find More Posts by KurtMc
KurtMc's Avatar
Sacramento, CA
Joined Sep 2003
What receivers have you guys been using in this plane? Will a Hitec Electron 6 fit the bill? Peace
KurtMc is offline Find More Posts by KurtMc
Old Aug 19, 2009, 11:14 AM
GreggB is offline
Find More Posts by GreggB
GreggB's Avatar
Temecula
Joined Dec 2007
Most have been using the Neutron 6. Either in front or behind the wing saddle area. Try to keep at least 1 inch area clear at the cg for ballast. Mine is fit snug slid back under the wing holddown bolt. Antenna is wrapped around the bobbin, with 10" hanging out the back. Hope that helps.
GreggB is offline Find More Posts by GreggB
Old Aug 19, 2009, 11:23 AM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
BTW: Neutrons are on sale at Hobby Peeps for $35.99.
1000MPH is offline Find More Posts by 1000MPH
Old Aug 30, 2009, 06:10 AM
Matt Galland is offline
Find More Posts by Matt Galland
Volare!
Matt Galland's Avatar
San Franciso Bay Area
Joined Dec 2005
Getting close to finishing mine.
I'm building a HEAVY D40. I added 5oz lead in wingtips and used an inline 4 cell AAA to load into the boom. Switch aft too. Elevator servo mounted in center of saddle area with epoxy putty. In the saddle area, I've got about 1.5" fore and aft for ballast. The nose will house my Rx and... you guessed it... more ballast.
What's the heaviest D40 build youíve heard of?
Of the fastest D40ís, what where their weights?
Any caveats for settings, C/G or flight behavior with heavy D40's? I'm gussing I won't throw unless it is at least 25-30.
Other ideas? D40-heavy observations?
-Matt
Matt Galland is offline Find More Posts by Matt Galland
Old Aug 30, 2009, 11:33 AM
Indubitably is offline
Find More Posts by Indubitably
Just Fly it
USA, CA, Bakersfield
Joined Jul 2006
color
It must be visible, and top from bottom distinguashable. Fluorescent paint or tape. Block on the bottom, angle on top - or what ever it takes to see it and know what its doing.
Indubitably is offline Find More Posts by Indubitably
Old Aug 30, 2009, 12:14 PM
daboz is offline
Find More Posts by daboz
daboz's Avatar
HB cali
Joined Apr 2006
Flew mine for the first time yesterday, Flew great at Grass Mtn!
24oz - flew in 10-15mph no problem. Radared a dive in at 129mph!! Fast little sucker! Estimated DS speed was a little faster.
Small throws maybe a little over 1/8 up Ail, little over 1/16 down.
About 1/8 on the elevator.
Three D47's as Joe told me, JR 790 fits great, 5 cell AAA (2 on the belly and three above fit perfect!) You have to slide it into the nose vertical, then rotate it 90deg and pull it back into the wing saddle nice and snug!
What a great plane, so much fun to DS, fast, good to speed up ur thumbs!!!
daboz is offline Find More Posts by daboz
Discussion Hangar 9 Tango 40 Official Build Thread januszczak 3D / Fun Fly Fuel Planes 59 Feb 22, 2013 08:31 PM
Mini-Review Page Aviation 40" Super Cub Build Thread Bill K. Scale Kit/Scratch Built 268 Sep 03, 2009 08:55 AM
Discussion 100" Hollow Molded Dynamic Build Thread joe manor Slope 74 Dec 07, 2007 04:47 PM
80" Dynamic Build Thread joe manor Slope 497 Jun 05, 2006 09:25 PM
.40 size Ziroli P47 build thread. RyanPSU21 Scale Kit/Scratch Built 130 May 09, 2005 08:03 PM
