Nov 11, 2011, 06:56 AM
Space Coast
Joined Oct 2000
See if you have a 2 pin male connector that will fit into 2 adjacent holes in the balance connector. If not, use 2 pieces of solid wire that will fit into the holes.
Add wires to the pins you have selected, red for +, black for minus and connect them to your charger.
Assuming you have a 4 pin connector, the black wire will be the starting point.
Cell#1 = Black wire is neg, #2 hole is +
Cell #2 = #2 hole is -, #3 hole is +
Cell #3 = #3 hole is -, #4 hole is +
You should check that with a voltmeter just to be sure. Be careful not to touch the voltmeter leads together or you'll short the cell.
Now push the neg pin into hole #2 and the positive into hole #3. Set the charger for 1s and 1A and charge.
But before you do all this, recheck the voltage of each cell. You said they were 4.25, 3.91, 4.25 I think. What are they today? If that middle cell has dropped more than the others it may not be worth the time to try to recover the pack.
BTW, 4.25V is too high.....4.2V is max and 4.15V is even better for long cycle life. Check those with a good voltmeter to be sure.
