Old Jul 03, 2009, 06:50 AM
Joel-3D is offline
Find More Posts by Joel-3D
Joel-3D's Avatar
P.R.
Joined Nov 2003
Question about soldering inside the room
Pretty much what the tittle say Im wondering if soldering in the room with the window open and a small fan pushing the fumes to the window would it start the smoke detector alarm.
I have the novak silver solder it say is lead free with 3% silver and environment friendly
thanks.
Joel-3D is offline Find More Posts by Joel-3D
Old Jul 03, 2009, 06:59 AM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
I solder inside my hobby room all the time, and have never set off a fire alarm. I just keep a fan running to disperse the fumes (not even a window open). You should be fine.
habitforming is offline Find More Posts by habitforming
Old Jul 03, 2009, 07:01 AM
Inflexo is offline
Find More Posts by Inflexo
Magicsmoke maker
Inflexo's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
If you do soldering 'more frequently', then consider investing in a proper extractor. For my workshop I use a 24V 120mm fan about 100mm from the job, it pulls away the flux fumes and takes them outside. The smoke is burning flux (plant resin) so while it's annoying it's not explicitly fatal, that said, always best to keep all forms of smoke well clear of you.
Paul.
Inflexo is offline Find More Posts by Inflexo
Old Jul 03, 2009, 08:30 AM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
I set off my smoke detector (which is right over my work bench...on purpose) about 20% of the time. It's annoying, but sure will come in handy if any of my LiPo's catch fire.
It's the epoxy fumes I worry about in my 14'X12' hobby room. I've got no windows (basement) and those fumes seem to hang around for a day or so...
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Jul 03, 2009, 10:39 AM
Joel-3D is offline
Joel-3D's Avatar
P.R.
Joined Nov 2003
I wont be doing it all the time just for some lipo pack and the ESC motor connectors since I move and now im in a 6floor apartment I was wondering.
the extractor thing sound really good it might be hard for me to find one out here.
thanks alot guys it seem I dont have to worry so much, but still I be cautious
Old Jul 03, 2009, 10:54 AM
TLyttle is offline
Find More Posts by TLyttle
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
Sign of the times, I guess. I have been soldering stuff since I bought my first iron 50 years ago, including a full radio kit, and re-plumbing my house using a torch. All the yowling about "lead poisoning" etc is just hype; ask any old-time TV tech. You are in far more danger doing a fiberglassing job.
My buddy and I used to build in his 8x12 room, doping and all; we are still just fine after 55 years.
A little common sense goes a long way in decisions like this!
TLyttle is offline Find More Posts by TLyttle
Old Jul 03, 2009, 11:07 AM
maverick06 is offline
Find More Posts by maverick06
Go Navy!
maverick06's Avatar
USA, PA, Media
Joined Apr 2005
don't worry much about the smoke alarm... but do ventilate, its defintely not good for you, and is very annoying (to me anyways) Target sells some nice tiny fans that would help (4" dia) good for the desk. Provided the alarm is REALLY close, i think you will not be able to tolerate it before the alarm trips.
maverick06 is offline Find More Posts by maverick06
Old Jul 03, 2009, 11:27 AM
mt_100 is offline
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
Keep in mind that there is also lead fumes in the smoke. Not a lot but enough that if you solder enough you should at least have a fan.
mt_100 is offline Find More Posts by mt_100
Old Jul 03, 2009, 12:03 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
FYI that solder will eat your tips!
I've gone through 3 different tips with that solder
Xpress.. is online now Find More Posts by Xpress..
Old Jul 03, 2009, 12:45 PM
LanceMc is offline
Find More Posts by LanceMc
Certified Wingnut
LanceMc's Avatar
Delta BC
Joined Jul 2008
I've been told that lead doesn't turn to a gas until 1000 deg F. No soldering irons get this hot.
Lance
LanceMc is offline Find More Posts by LanceMc
Old Jul 03, 2009, 02:00 PM
mt_100 is offline
I have no friends
Joined Dec 1996
Found interesting article. Evidently there is a negligible amount of lead in the smoke.
http://www.garypalamara.com/Articles_Solder_Smoke.htm
Even negligible, I's still have a fan or ventilation as the smoke is bad.
Old Jul 03, 2009, 02:26 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
If you live in an apartment you can solder at the bathroom cabinet with the fart fan on and it should take care of the fumes. Crack a window while you do it.
Chuck
Chuck is offline Find More Posts by Chuck
Old Jul 03, 2009, 08:39 PM
LBJ is offline
LBJ
Find More Posts by LBJ
LBJ
Fort Worth, Texas
Joined Nov 2007
Solder smoke and Butyrate thinner are two of my favorite highs! Hahahaha. I been doing that kind of hobby work for decades and feel it has no ill effects. However, with thinnner, you do need some fresh air along with it. Wouldn't recommend smoking around it either. LBJ
LBJ is offline Find More Posts by LBJ
Old Jul 03, 2009, 09:59 PM
Joel-3D is offline
Joel-3D's Avatar
P.R.
Joined Nov 2003
so even that it say lead free it still have some lead when you solder?
thanks for letting me know about that solder eating the tip that way I just do it all on the same day, dont have access right now to other brands
then it seems that the answer is soldering wont make the alarm go off
Old Jul 05, 2009, 12:23 AM
caseih is offline
Find More Posts by caseih
Joined May 2005
I usually use the old standard 60/40 tin/lead solder. The lead-free solders require a really high temperature and just don't work as well for home soldering jobs. I simply try not to breath the fumes (if you see the fumes too much you're probably using too high a temperature). I have never set off my smoke detector. Whether you're using lead solder or lead-free, invest in a good soldering station with an adjustable temperature. I bought a really nice digital one from circuit specialists for about $50.
caseih is offline Find More Posts by caseih
Discussion Just a newbie question about soldering lipo tabs bambino Batteries and Chargers 1 May 01, 2008 07:49 PM
Discussion Question about soldering Gunky Power Systems 5 Sep 06, 2007 07:17 PM
Question About Soldering Bullet Connectors on Himax and ESC grantorino Beginner Training Area (Aircraft-Electric) 8 Jan 27, 2006 11:35 AM
question about soldering ESC&Motor GTOVR4 Electric Heli Talk 2 May 28, 2004 02:14 AM
