Old Jul 02, 2009, 06:09 AM
gusmac is offline
Find More Posts by gusmac
Joined Jun 2009
Question
Super Cub Prop Help
Hi,
I ordered a Super Cub prop over the internet and received it this morning. What I got was PKZ1005 which is 10x8, however the prop that came with the plane is a 9x6
Is this a problem?
Also I purchased GWS 10x6 props which someone recommend on the internet, but it does not fit. Any suggestions here.
It is a great day today, so looking to get flying this afternoon. So a quick response would be much appreciated.
A.
gusmac is offline Find More Posts by gusmac
Old Jul 02, 2009, 06:11 AM
realtimerecon is online now
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
Your flying a stock plane w/ stock power ?
realtimerecon is online now Find More Posts by realtimerecon
Old Jul 02, 2009, 06:17 AM
Real Time Recon
smith mt. lake VA.
Joined Jan 2007
Info here... http://www.rcgroups.com/forums/searc...rchid=20193744
Old Jul 02, 2009, 06:29 AM
gusmac is offline
Joined Jun 2009
Yes. Stock Super Cub LP (Lipo).
Looking through the thread now.
Old Jul 02, 2009, 10:04 AM
Real Time Recon
smith mt. lake VA.
Joined Jan 2007
You'll love it ,wise choice
Old Jul 02, 2009, 01:13 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Yes, you need to use the 9x6 prop. The 10x8 is too much prop for that system
Xpress.. is online now Find More Posts by Xpress..
Old Jul 02, 2009, 04:06 PM
gusmac is offline
Joined Jun 2009
what is the issue with using too much prop... what is the downfall? Will it fry the plane?
Old Jul 02, 2009, 06:36 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
Hi gus,
Once we hook up a battery to a motor, there is only one thing that determines how much current we pull, and that is the prop. A small prop will pull less current than a larger prop.
Every motor has a limit as to how much current we are allowed to pull through it, before it burns up.
So, in other words, if we use too large of a prop, it will cause the motor to exceed it's current limit, and destroy the motor, and possibly the ESC, and maybe even the battery itself.
There have been lots of guys whom have experimented with the Super Cub motor on 3s Li-Pos, and the best prop you can use, which will give you great performance, while keeping the motor under it's current limit... is the GWS 10x6 DD Direct Drive prop.
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Jul 02, 2009, 06:42 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
More prop = more load on the motor = more current = more heat.
Essentially you have the opportunity to turn your airplane into an expensive fireworks display.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jul 07, 2009, 09:31 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
In addition to overheating the controller, rotational torque will be greater making the plane somewhat harder to control.
rich smith is offline Find More Posts by rich smith
Old Jul 07, 2009, 10:47 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
The OLD stock Cub is brushed and NiMh. It pulls ~10A.
Put a 3S in there and it pulls ~18-20A,
PZ publishes NO GUIDANCE or SPECS on the RX/ESC in the Cub.
Collective experience/wisdom seems to have centered on using a GWS 10x6HD or APCe 10x5. That pulls ~12-13A.
LOTS of folks go 3S and keep the stock prop. Some get away with it, some burn up the RX/ESC. The motor does wear faster but it's cheap.
The NEW LP Cub appears to be stock with a 3S.
Yesterday I asked Horizon support specifically if the RX/ESC had been redesigned for the new Cub. The 10x8 IS listed as a 'hop up' part and suggested for floats. Support said the part was redesigned and that was "allowed". He had no specs as usual for the part.
It should work, but realistically you are in unknown territory and on your own.
flydiver is offline Find More Posts by flydiver
Discussion super cub part help wishawhunk Beginner Training Area (Aircraft-Electric) 9 Feb 18, 2009 08:56 PM
Question Trouble with HZ Super Cub, need help please jive Parkflyers 9 Mar 15, 2008 06:34 PM
Help! Super Cub - Need help on engine and battery upgrade genepeele Electric Plane Talk 1 Oct 28, 2007 11:03 PM
Discussion A Super Cub prop different than the stock one Spackles94 Power Systems 2 Mar 20, 2007 12:15 PM
Discussion HobbyZone Super Cub Prop Tests CitaFly Parkflyers 1 Mar 12, 2007 05:06 PM
