Go Back   RC Groups > Aircraft - Electric - Helis > Mini Helis
Old Jul 03, 2009, 04:01 AM   #31
VTEC just kicked in, YO!
Speed Stick 3D's Avatar
Send a message via AIM to Speed Stick 3D Send a message via MSN to Speed Stick 3D Send a message via Yahoo to Speed Stick 3D
Sure will! 5mm Main shaft, 120 deg CCPM
Devin
Speed Stick 3D is offline Find More Posts by Speed Stick 3D   Reply With Quote
Old Jul 03, 2009, 04:25 AM   #32
/bin/ksh
Steve_C's Avatar
Not w/o mods. Swash is larger diameter so the A/R arm needs to move back on the V2 frame, aside from that front cyclic servos will need to be mounted with tabs on the outside of the frame for proper geometry. Also the main shaft length is longer, I hear that you can install the main shaft upside down to get pitch right, and phasing will be off.
Steve_C is offline Find More Posts by Steve_C   Reply With Quote
Old Jul 03, 2009, 04:47 AM   #33
Thanks Steve! Seems to me it would work though! I will look at it this weekend at the field if Alan is there!
Devin
Old Jul 03, 2009, 05:05 AM   #34
/bin/ksh
Steve_C's Avatar
I'd be interested in what you find, I want to put the pro head block on my SA, I see mostly that there are issues like phasing interactions etc with the full pro head mounted to v2 rex's
Old Jul 03, 2009, 05:21 AM   #35
Team Mulikow
Gino CP's Avatar
Wouldn't a V3 rotor hub, spindle, and fixed links make a V2 into a virtual Pro rotor?
Gino CP is offline Find More Posts by Gino CP   Reply With Quote
Old Jul 03, 2009, 05:23 AM   #36
The only problem with the V2 head is the sloppy blade grips! So yes, if you just put a pro head block and blade grips on it "should work"!! I will talk with Alan if he is at the field this weekend or not about this matter!
Devin
Old Jul 03, 2009, 11:21 AM   #37
Nano
Dylwad's Avatar
Ive been trying to figure out too if the pro grips will work with the V3 head block, as I dont think the V2 flybar seesaw will fit on the pro head block. They should fit, because the feathering shaft is the same length for the Pro and V3....
So the Beam swash is a direct fit for the V2 but better than Align so I hear?
Dylwad is offline Find More Posts by Dylwad   Reply With Quote
Old Jul 03, 2009, 02:44 PM   #38
muda's Avatar
Beam swash is serviceable and fits trex. So you can change ball bearing if it has too much play, what you could not do with Align swash.
muda is offline Find More Posts by muda   Reply With Quote
Old Jul 03, 2009, 04:36 PM   #39
I use the original V1 swash, but the new revised version that does not seperate! It has Align silk screened on the front of it and still has no play after 400 hard 3D flights!
Devin
Old Jul 03, 2009, 05:06 PM   #40
Nano
Dylwad's Avatar
So you mean the V2 swash?
V1 http://www.readyheli.com/HS1111_eCCP...e_p/hs1111.htm
V2 http://www.readyheli.com/HS1111_84_A.../hs1111-84.htm
Old Jul 03, 2009, 05:10 PM   #41
Nano
Dylwad's Avatar
http://www.align.com.tw/shop/product...oducts_id=2706 V1
http://www.align.com.tw/shop/product...oducts_id=2705
V2
Is the only difference the color? they are both hs1111, but the V2 is hs1111-84
Old Jul 03, 2009, 05:13 PM   #42
I run the V1 color one! Light blue and says Align on it! The v2 swash is good too! same thing! But the old V1 swash that has no name on it is the one that seperates! So stay away from those!
Devin
Old Jul 03, 2009, 05:17 PM   #43
Nano
Dylwad's Avatar
Gotcha! thats what I thought.
Old Jul 03, 2009, 08:18 PM   #44
Originally Posted by L0stS0ul
to bad, I would have hoped align had gotten rid of the step down gear and gone with a direct tail belt drive system. I really dislike the step down.
I agree 10,000 percent.
Don
don_87 is offline Find More Posts by don_87   Reply With Quote
Old Jul 03, 2009, 09:24 PM   #45
I'd like some more info on that 250 v2
ForceFedDSM is online now Find More Posts by ForceFedDSM   Reply With Quote
Very promising new micro? "T-Rex 450" Xnaron Mini Helis 344 May 31, 2008 01:00 AM
Sold new t rex 450 xl ccpm 007 Aircraft - Electric - Helis (FS/W) 4 Feb 25, 2006 06:28 PM
Sold Brand new T-REX 450 XL CDE NEW NEW NEW scottb Aircraft - Electric - Helis (FS/W) 7 Nov 18, 2005 09:10 PM
New T-rex 450............The X-400! skyhawk Mini Helis 73 Mar 16, 2005 08:52 AM
Cool FW : T-Rex 450 New video from TW --- 3D?! HKAero-Nuts Mini Helis 17 Sep 24, 2004 02:32 PM
Bored? Want to fight?
Join the RCGroups clan!
