Old Jun 30, 2009, 07:29 PM
The Don is offline
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Mini-HowTo
Installing the Wicked EDF motor into the Wicked EDF fan unit
Here is a quick "how to" on getting the Wicked EDF motors installed into the Wicked 60mm EDF fan unit.
Step 1:
Here are the parts you will use from the EDF unit. The housing, the rotor (either 3 blade or 5 blade), the spinner, the 3mm adapter with washer and nut, spinner screw, and the two mounting screws included with the Wicked EDF motor. The other items are not needed for the Wicked EDF motor.
The Don is offline Find More Posts by The Don
Old Jun 30, 2009, 07:47 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Instead of cutting a slot in one spot per these instruction, you can remove the entire back lip instead. The choice is up to you.
Step 2:
There are two sets of mounting holes on the EDF unit and two sets of threaded holes on the front of the motor. You want the inner set of holes on the motor and the outer set of holes on the EDF housing.
Step 3:
Push the motor into the EDF housing to line up the holes. At this point you may find that the wires on the motor are touching the back of the motor housing. If that is the case then we need to cut a small notch in the back with an X-acto. Steps 4 through 7 will show how to do this.
Step 4:
With the mounting holes lined up in the front as close as you can get, turn the unit upside down and set on the table. This will show you where the notch for the wires needs to but cut.
Step 5:
Mark the location just outside of the wires with a marker, then use an X-acto knife or single edge razor blade to cut through the thin section of the plastic. You only need to go down about 2mm.
Step 6:
Use the X-acto and and score the plastic between the two cuts you just made.
Step 7:
Use a pair of pliers and bend the plastic and it will come right off.
Old Jun 30, 2009, 07:56 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Step 8:
Install the 3mm adapter onto the motor shaft by tightening the set screws. Please make sure you use the 3mm and not the 3.17mm adapter (1/8"). If you use the wrong one the rotor will wobble and vibrate badly. You want the adapter to be about ~3mm from the front of the motor.
Step 9:
Insert the motor into the EDF housing and tighten the two black mounting screws.
Step 10:
Place the rotor onto the adapter then the washer then the nut and tighten down. Not spin the rotor with your hand to make sure it moves freely. You may need to fine tune the position of the adapter on the motor shaft or the motor position to get equal clearance on all the blades.
Step 11:
Install the spinner then tighten the small spinner screw down to hold the spinner on.
Old Jun 30, 2009, 08:09 PM
The Don is offline
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Tip:
One thing I do to help me balance a fan is to mark the spinner location. I then run the fan and if needed rotate the spinner to get the best location. A small mark lets you know where you started. Once balanced I then mark the new spot with a different color or rub off the old mark. This way if I ever take off the spinner, I know where to place the spinner again. If rotating the spinner does not get the vibrations out, then I cut small squares of black electrical tape, about 1/4" square. Then I put one on the inside of the spinner then test run to find the best spot. Then mark the spinner position again.
Hope this helps!
Don
Discussion Help In selecting the EDF fan unit ashtasky Electric Ducted Fan Jet Talk 2 Aug 02, 2007 06:21 AM
Discussion Balancing an HET-RC 6904 EDF fan unit David A Electric Ducted Fan Jet Talk 13 Nov 17, 2006 12:56 PM
Wanted WTB: Kamdax EDF fan unit Dukester Aircraft - Electric - Power Systems (FS/W) 2 Jan 28, 2006 03:25 PM
Wanted Wanted: Kamdax EDF fan unit for Mig/Mirage Dukester Aircraft - Electric - Airplanes (FS/W) 3 Sep 04, 2005 11:49 AM
Question Kyosho EDF Fan Unit dbl8ts Electric Ducted Fan Jet Talk 17 Oct 02, 2004 09:52 PM
