This thread is privately moderated by tailslide5_0, who may elect to delete unwanted replies.
Old Aug 13, 2009, 05:27 AM
tailslide5_0 is offline
Find More Posts by tailslide5_0
Hangar queen hoarder
tailslide5_0's Avatar
Denver, CO
Joined Jul 2006
Originally Posted by G-Forse
Tailerons look good. I believe I may use ball links off the control horns to keep the push rods straight. ---Are the control horns thru bolted with a back plate or glued in like Funjet?
They're epoxied to the tailerons. The control horns' studs were cut shorter so they still had a couple 'threads' on them but not so long that they would go through the taileron; I cut out a square in the covering and epoxied them in.
tailslide5_0 is offline Find More Posts by tailslide5_0
Old Sep 28, 2009, 12:09 PM
Frisk151 is offline
Find More Posts by Frisk151
The Toy Man
Frisk151's Avatar
United States, TX, The Woodlands
Joined Aug 2004
Hi Glenn,
Thanks for posting a build thread for your F-16. Any chance you will post the parts specs for your Miss Bud, including the ESC, Fan, Motor, Batteries, etc?
I have a stock P3 F-16 and have wanted to build a new screamer for some time.
David
Frisk151 is offline Find More Posts by Frisk151
Old Sep 28, 2009, 03:24 PM
Denver, CO
Joined Jul 2006
I've posted the specs before but I guess I forgot to include them in this thread; I used a CC 125 ESC, HET 6904 fan, ARC 28-48-1 (special version of a 28-47-1) w/ a custom heatsink, TPX V2 3300 5s, CC BEC, HS-65MG's, AR6000 Rx w/ DX-7.
Old Sep 28, 2009, 03:47 PM
Frisk151 is offline
The Toy Man
Frisk151's Avatar
Joined Aug 2004
Thanks for the info, Glenn.
Do you have any thoughts on ARC's 28-58-1 and HET 6904 Fan in this airframe?
Old Sep 28, 2009, 10:06 PM
Denver, CO
Joined Jul 2006
Dave from ARC asked me if I wanted to test a 28-58-1 but I declined because the kv is too low for my taste. The motor is on the heavy side, and you would need 5s or maybe even 6s to get similar performance to a 47-1 on 4s.
Old Feb 09, 2015, 06:53 PM
syfaz777 is offline
Find More Posts by syfaz777
United States, NV, Las Vegas
Joined Nov 2009
more specs.
tailslide i know it was 5 years ago but, i want to know the weight of miss bud with the battery . and also how much thrust did she have, did you ever measure it? because i know for sure if you open up the stock exhaust from 53mm to 63mm you will get another 150 grams of thrust. so maybe you might be able to hit 185 mph if you did that. ............... on my current setup i have 1350 grams of thrust on 900 watts doing about 125mph.
syfaz777 is offline Find More Posts by syfaz777
Old May 18, 2015, 03:09 AM
Denver, CO
Joined Jul 2006
Hey syfaz777, sorry for the late response. Haven't been on here in awhile.
I don't think I ever measured the thrust output in grams, to be honest, but I think it was around 2 to 1 when the jet weighed about 42 oz RTF if I remember right. And I was going for the highest velocity, afterall, as the airframe was so sleek that it needed speed in the form of air velocity rate, not raw power...at least that was my thinking. The intake was designed really small for that purpose, too. And I believe I had the outlet at 54 mm, but maybe not, it's been so long.
The thing crashed back in 2010 doing 205 in a fat dive here in Denver. I'd show you the video, but I lost it because of a crashed hard drive plus a youtube account dropped thanks to google plus...
Cheers,
Glen
Discussion RC Lander F 16 build thread VA174 Foamy EDFs 2915 May 16, 2016 01:18 AM
Build Log F-16 Build Thread Thomas Nelson Foamy EDFs 598 Oct 14, 2015 10:22 AM
Discussion New F-16 build-This should be on H-J's F-16 Thread electriceye Pusher Prop Jet Models 2 Aug 28, 2006 02:45 PM
Flying Styro F-16 Building Thread drbird Foamies (Kits) 91 Apr 25, 2004 01:29 AM
Flying Styro F-16 build and power questions G1K@home Electric Ducted Fan Jet Talk 2 May 29, 2003 03:53 PM
