Old Jun 30, 2009, 12:02 PM
scrubs is offline
Find More Posts by scrubs
scrubs's Avatar
Rio Rancho NM
Joined Dec 2004
wing loading on small stuff
I've got a number of kits and plans for OT stuff at 30". Kits of the Sniffer, Viking and Buzzard Bombshell. I also scaled plans for the Coronet and Wedgy. Originally I thought I'd do them for CO2 or electric FF. But I'm having problems chasing FF since a knee operation. So I may do a few as RC assit FF. Not so bad really, just use the Tx to shut down the motor and bring it back to me after it comes down.
What would be a good weight / wing loading to shoot for on these? They're around 150 sq inches give or take.
I'm also sorry to see most of the simple GWS brushed setups getting harder to find. The long can LPS A would have been ideal. The IPS seems a little heavy altho I will be needing nose weight on something like a Wedgy.
bill
scrubs is offline Find More Posts by scrubs
Old Jun 30, 2009, 02:25 PM
Snorks is offline
Find More Posts by Snorks
Africa
Joined Jan 2005
Scrubs I've built a few 36'' span models around 210 sq inches & always ended up with about 6.8 - 7.5oz. per sq ft. I think with electric you could get it lower but it all depends on how much wind you have at your flying field. I find that below that it doesnt penetrate even in a moderate breeze ends up floating backwards ...then again I was flying ic so didnt have the luxury of applying a little power to bring them home.
I never built the KK slicker mite (32''?)simply because I crunched the numbers again & again and could get a satifactory loading.
cheers
Simon
Snorks is offline Find More Posts by Snorks
Old Jun 30, 2009, 02:46 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
One reason the GWS IPS systems are dissapearing is because some really neat TINY brushless motors are showing up.
GWS "A" IPS motor + gearbox = appx 29 grams.
Add appx 7 grams for the ESC+ wire...
2Dog RC had (might still have) a 15 gram brushless outrunner that turns the same prop appx 30% higher RPM.
Appx 9 grams for the brushless ESC + wire...
36 grams for brushed...
24 grams brushless...
Significant weight saving and significantly increased power. Put the weight saving into a bigger battery if you want...
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Jun 30, 2009, 03:38 PM
Franny B is offline
Find More Posts by Franny B
Stupid Gravity!
Franny B's Avatar
Arvada, Co
Joined Feb 2006
Hi Bill,
I e-converted a Goldberg 1/2A Blazer and High-Thrust Viking and they are lots of fun. The Viking flies the best and is completely unique on a usual Sunday outing at the club, I agree about the brushless. They are the way to go for weight and power. The Viking is about 15oz so a little heavy, but will climb out of sight in 40 seconds or so. Wind is a big factor though.
Franny
Franny B is offline Find More Posts by Franny B
Old Jun 30, 2009, 03:41 PM
scrubs is offline
scrubs's Avatar
Rio Rancho NM
Joined Dec 2004
Thanks guys.
Simon,
I agree on the wind my tiny 24" stuff just gets blown off the field if I try it fly it as RC assist FF.
FHH,
Yeah the future is brushless & I've got one of those little 10 gm gems too. But I was hoping to use some brushed esc's I have. Cheap is as cheap does.
bill
Old Jun 30, 2009, 04:01 PM
Redbaron25 is offline
Find More Posts by Redbaron25
North East England
Joined Feb 2004
I've built a few 30" span models, both sports and WW1 scale, and although I never weigh them (got no scales), if they're balsa/ply construction and built in the free flight manner they fly just fine.
One in the pic is a 30" version of the 'Little Ship'; 1500kv outrunner, 2s 540 LiPo, 5 gm servos. Very light - you can see the construction through the Litespan covering.
30" is a nice size; big enough to see but handy for storage and transport.
Steve
Redbaron25 is offline Find More Posts by Redbaron25
Old Jun 30, 2009, 06:25 PM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
A rough guide which works quite well, for scaling a known model up or down is to multiply the wing loading by the scale factor. In this manner, the flight behaviour (could be called the "character") of the original size model is maintained, albeit at a lower speed.
Going into more detail:
- Size is proportional to scale factor
- Wing area is proportional the square of the scale factor = (Scale Factor)
- Weight is proportional the cube of the scale facto= (Scale Factor)
- Power required is is proportional to the 3.5 power of the scale factor(Scale Factor)^3.5
- Flight speed is proportional the square root of the scale factor.
These are guidelines which were spelled out long ago by Bob Boucher (Mr. AstroFlight) and others
As an example, a half-size model would obviously see its dimensions halved.
The wing area would be divided by 4
The weight would be divide by 8
The wing loading would be halved;
Flight speed would be 0.7 of the original;
Power required (or IC engine capacity) would be divided by 11 (= 2 to the power 3.5).
Say the original flew with a .60 engine, then the half-size model would fly in a similar manner with a .049 or .060 engine.
Another example : The original model uses a .15 engine. Say I want to build a smaller replica for an .020 engine. What scale factor? Answer : root 3.5 of (.020/.15) = 0.56 or 56%
A replica for an .049 would be scaled 73%, etc...
The same reasoning equally applies to electric powered models.
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Jun 30, 2009, 06:36 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I believe that the smaller 150 sq inch replicas flew well at between 4 to 5 oz for free flight. With the need to ride even the lightest lift somewhat taken away and a more sport flying style role I would not be bothered by having the weight of them go to around 6.5 to 7 oz. But obviously the lighter the better if you wish to retain that free flight look to their flying.
There are some amazing little 9 to 13 gram brushless motors out there these days. Those with the ultra light Berg Rx and a couple of 3.6 gram servos and a small ESC and there's no reason why an RC version can't come in well under 7 oz since the 5'ish oz free flight versions were keeping that light with a TeeDee .020 and a heavy Tatone fuel timer on board.
BMatthews is online now Find More Posts by BMatthews
Old Jun 30, 2009, 09:10 PM
scrubs is offline
scrubs's Avatar
Rio Rancho NM
Joined Dec 2004
That's what I was hoping to hear Bruce. The 24" RC sport models I've built came in a hair over 3 oz. A 24" SE5A was about 4 1/2 oz. So I should be able to do 5 oz on a 30" replica, especially with good balsa and esaki covering.
bill
Old Jun 30, 2009, 11:36 PM
Joined Mar 2005
A use for the old brushed ESCs... Put em on a switched channel and put lights on the plane.
Old Jun 30, 2009, 11:54 PM
Warren B is online now
Find More Posts by Warren B
Warren B's Avatar
Mt Evelyn, Melbourne, OZ
Joined Dec 2008
I've been having lots of fun with this little DH02.
20" span, Schlosser 0.25 and weighs about 8 oz.
Under power it can handle a moderate breeze, loops rolls all good fun.
Gets about 3 1/2 minutes on 2cc of fuel (and that's long enough on this little beasty).
It glides very well if I leave it alone on it's favourite glide slope.
If I pull up to slow it down it falls out of the sky.
Warren B is online now Find More Posts by Warren B
Old Jul 01, 2009, 02:20 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Warren, your DH02 had easily twice the wing chord of the OT replica models we're talking about. Plus with these much of the fun is to glide for thermals following motor shutdown. Different requirements......
Old Jul 01, 2009, 02:23 AM
Snorks is offline
Africa
Joined Jan 2005
Very interesting JMP. Does it work the same in reverse? ie as in scaling up?
Old Jul 01, 2009, 02:53 AM
Joined Mar 2005
Yes... the scaling factors work well in both directions.
Old Jul 01, 2009, 03:05 AM
Joined Mar 2005
Depending on the model...
The RC system might add amazingly little weight now. Consider the Parkzone Vapor. You can take its radio and motor system and make an AMA "Cub" into an RC model.
The new ultra-micro Sukhoi's RX and a micro brushless power system would allow 5 channel operation of a Guillows 18 inch span P-40. Possibly 6 channels! Just a matter of designing the tiny retracts.
1.5 gram servos are wonderful things.
AR6300 RX at 2 grams and there are 2.5 gram servos available to use with it for under $10 each.
I wished this kind of stuff was available when I was a kid....
The Electric power system + RC system COMBINED could weigh very close to the original rubber power syetem...
Aim for the rubber power FF's design weight.
Discussion Wing loading on the Frog? Lammergier Foamies (Kits) 6 Feb 11, 2006 02:50 PM
43oz wing loading on Bob-E-CAT jared salbato Electric Ducted Fan Jet Talk 34 Feb 03, 2005 06:41 PM
Wing loading on airliner (737-400) SkynetAir Scale Kit/Scratch Built 29 May 02, 2004 08:46 PM
Any Hobby Dealer with Low Shipping on Small Stuff? Veedubber Vendor Talk 12 Nov 15, 2002 12:47 AM
0.6 oz/sq ft wing loading on home built indoor flier!! Hodgepodge Scratchbuilt Indoor and Micro Models 5 Mar 31, 2002 11:15 AM
