Old Jun 30, 2009, 06:07 AM
Scarey is offline
Find More Posts by Scarey
Registered EDF abuser
Scarey's Avatar
Michigan
Joined Jan 2006
New Product
ARC 36-65-1 (Kv 2080) 36-75-1 (Kv 1680)
LightFlight RC has these two long canned 36mm motors available now. Has anyone tested these in a 90mm fan?
Scarey
Scarey is offline Find More Posts by Scarey
Old Jun 30, 2009, 07:15 AM
tallyho is offline
Find More Posts by tallyho
Epping, Essex
Joined Nov 2002
Hi Scarey,
Have a look at Carls' testing thread, on the first post, are tests of the 75mm motor.
http://www.rcgroups.com/forums/showp...82&postcount=1
Cheers
Matthew
tallyho is offline Find More Posts by tallyho
Old Jun 30, 2009, 11:56 PM
Scarey is offline
Scarey's Avatar
Michigan
Joined Jan 2006
"ARC 36-75-1 1680kv 75mm long motor, 12.7 oz w/ connectors
No load Kv test,
11.43v, 1.98A, 22.0W, 19,225 RPM, 1682 no load Kv
Installed in Midi fan
6s 7700ma (3850+3850) heated to 104F
24.95v dropping to 22.38v, 70.7A, 88.1oz T, 1589.5 W, 34,450 rpm 1536kv under load, 165mph eflux
7s 7700ma 106F, 29.1v-26.1v, 94.4A, 118.3oz T, 2475 W, 39,225 rpm, 1501 kv under load, 194 mph eflux"
I wonder if the 75mm 36-75-1 could go to 8S ?
Amps would probally be 100+
Old Jul 01, 2009, 10:46 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
No load Kv test,
tailslide is running one on a midi fan and 8S XPS cells. 3.2kw if i remember correctly, and 111 amps.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Jul 01, 2009, 10:58 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i think the 65mm 2080 kv would work well in a HW609 fan (75mm) what do you guys think?
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jul 01, 2009, 09:11 PM
Scarey is offline
Scarey's Avatar
Michigan
Joined Jan 2006
Went with the HET 6905 with the 36-75-1 for 8S. Suppose to be softer then the Midi. The HW 609 with the 36-65-1 should be good with 7-8 S.
Scarey
Old Jul 01, 2009, 11:31 PM
kelvin is offline
Find More Posts by kelvin
Involuntary Beta Tester
Joined Jan 2002
I'm looking at a 6s Midi setup in a Fly Fly Mirage. I looked through the 36mm Arc Motor thread and found a post that Carl Rich posted testing the 36-55-1.5 with Midi on 6s
6s Zippy 3500 30C packs that are much newer. Heated to 102F
25.0v-21.41v, 79.94 amps, 95.5T (5lbs 15.5oz), 1716W, 34850rpm, Kv under
full load was 1617, efflux velocity 176mph
Now the longer can motor:
No load Kv test,
The 36-55-1.5 is 1850kv and the 36-75-1 is 1680kv. I was expecting the 1680kv to pull less amps.
Should I go with the 36-55-1.5 and save about 4 oz in weight. There is only a 9 amp difference. Would the larger motor stay cooler?
Thanks for any advice
Kelvin
kelvin is offline Find More Posts by kelvin
Old Jul 13, 2009, 06:44 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
I got to fly my 75-1t on 8s in a Midifan Pro yesterday. I was using XPS 5000mah cells (two 4s packs). The final amp draw on fresh packs was about 95amps and the volts were holding at about 29v, so that`s about 2750watts.
9s sounds tempting.
I got in two flights with it. The temps at the field were over 100 F and the motor performed like a champ. I didn`t get any video, but might get out to the field one evening this week and shoot some vid.
A turbine pilot at the field said he thought that it looked like it was going 200mph. I assured him that it was probably much closer to 150 than 200.
The plane has wings from my old Falcon 25 with a custom fuselage that I made for them after the orig fuse was lost in a crash. The nose wheel is retractable and it has two 1/8" wire skids for the main gear. It`s a pretty slick little plane with a span of 44" and an AUW of 7lbs , it would be 6.5lbs, but I had to add 8oz of nose-weight to get it to balance.
I`ll post a pic of it.
PS.. one word of caution... I did have the back-plate on the motor come loose while running it on the bench. Luckily I caught it before any damage was done to the motor.
While I had the back-plate off, I made a little mod to the motor leads. I`ll include a pic. Dave, I think that this would be a good mod for future batches of motors. All of those wires coming out of one hole creates a lot of heat between the three wires at higher amp levels. Keeping them separate helps with the heat. Also they are already in position to exit through separate holes so it should be slightly easier to do at the factory.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jul 14, 2009, 01:58 AM
Scarey is offline
Scarey's Avatar
Michigan
Joined Jan 2006
Lee - Good idea with the motor wires. Now I will have to check my back plate.
Old Oct 30, 2009, 01:41 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Was just checking out my ARC 36-75-1t and can't figure out how the back plate is removed. I too believe the wires would be best exiting from seperate holes in the motor.
Madmax1965 is offline Find More Posts by Madmax1965
Old Oct 30, 2009, 02:21 PM
Sniper.308 is offline
Find More Posts by Sniper.308
I'm a lead farmer Mother ^%$^%
Sniper.308's Avatar
Lakeland, Fl.
Joined Apr 2007
I've been running the 1T in a edf trainer from nitroplanes now for about 6 months now. Fantastic motor, can easily handle 8S. Granted my plane is no speed demon, but I more efficient fan than the 100mm fan would show more promise.
Sniper.308 is offline Find More Posts by Sniper.308
Old Nov 01, 2009, 09:16 PM
kelvin is offline
Joined Jan 2002
I just ran up my 36-75-1 on 7s Rhino 25c 4900, 3s + 4s. 85 amps.
Old Nov 02, 2009, 07:34 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I think that is the sweet spot for this motor. Notice in Carl's test he preheated the packs to 104F and saw almost 10 more amps. I have this motor and a Midifan that will be going into an old HOB Sabre. Thanks for posting your results kelvin. Were you running with or without the heatsink?
SteveC68 is offline Find More Posts by SteveC68
Old Nov 02, 2009, 12:14 PM
kelvin is offline
Joined Jan 2002
I just ran a short burst to test for amps. I'm not using a heat sink. I haven't flown the model yet, a FlyFly Mirage. I'm in the middle of glassng the airframe. I just bench tested my power system this weekend. I wish the amps were lower.
Kelvin
Old Nov 03, 2009, 12:30 PM
MJB9 is offline
Find More Posts by MJB9
ARMY ATC (93C)
MJB9's Avatar
United States, TX, Keller
Joined Jan 2005
What fan did you use with that setup?
MJB9 is offline Find More Posts by MJB9
Discussion Arc 36-55-1.5 / Midifan kevin Electric Ducted Fan Jet Talk 49 Jun 03, 2009 09:47 PM
For Sale arc 36-55-1.5t 55$ kremecheze Aircraft - Electric - Power Systems (FS/W) 1 Mar 24, 2009 09:36 AM
Sold nib arc 36-55-1.5t motor kremecheze Aircraft - Electric - Jets (FS/W) 0 Mar 21, 2009 07:05 PM
Video ARC 36-75-1T/Midifan powered Falcon25 Wing Knife Liddle Electric Plane Talk 7 Aug 26, 2008 10:32 AM
Discussion RcWorks Sickles 36" ARC Powered 2847 1.5T / 2T catahuladave Flying Wings 29 Nov 21, 2007 11:31 AM
