| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
Wonderfully Wicked
Thanks for posting the video! Something is not right though, I am only getting about 100 mph. Your rpms are higher than the HET 6904 and 2W combo but the speed is much less than the 2W combo
You dragging a parachute behind you
#47 |
Hey ya'll,watch this!
I thought I am choking exhaust,maybee I should cut some more of tail pipe open,is that black tailpipe to small for 70mm fan?OOPs! I just measured it,Exit is 55mm...LOL were are my sissors!!??
#48 |
Wonderfully Wicked
I just went an measured my 6904 fan and I get the following:
D=69mm d=32mm So for 80% FSA you want De= sqrt(.80) * sqrt(D*D - d*d) De= .894 * sqrt(69*69 -32*32) De= 54.65mm = 2.15" Your size sounds perfect. Air Sally's flight is about 120 mph on a WM480 and the HET 6904 I though was suppose to be a faster fan so I would think 120-130s would be correct. Maybe you were not giving the plane enough time to accelerate to full speed? Last edited by The Don; Jul 10, 2009 at 10:42 PM. |
#49 |
deltas are cool
Don ...mine had the wemotec 480 ...is that what you ment ? the het set up should be faster than mine .....Lucky do you have one of my inlet ducts? not that that would make up 20mph ...maybe 8-10 depending on how clean your inlet is ...i also use 2.1 -2.2 for tail pipes ...this one has a tight fit to the Air sally glass tail cone. i have some body work that needs fixing so there might be more in it ...plus we had what we call dead air today ....i dont know if it is low pressure or alt density but all of our jets where sluggish ...C/N had some proplems launching some of his stuff..my 16 was doggy on the launch too.
#50 |
150mph 90mm JHH COUGAR 3.5KW:D
don, from the video, he probably wasnt allowing enough room to get going fast enough, and he was pulling up too soon after the run.
#51 |
Hi AirSally,no,I do not have your duct,and just why is this so!!???Hmmmm???
Lets get on it,and I will overlook your actions this time!(Please pm me so we can discuss this...Joe)
#52 |
Yes,I agree,this is not the field I ussualy fly at,and was not that secure there,I will do another one at my regular flying field.Because of its power going striaght up,I dont think there is any real problem.It does sound good.
#53 | |
Wonderfully Wicked
I love it!Don |
#54 | |
Wonderfully Wicked
Are you using the 480 pro?
#55 |
Hold the phone.....My battery is no good!I just put in my test battery,ohhhh sheesh!!The battery I flew with in video has a problem,My test battery makes EDF scream!It looks like I need to purchase another battery....
#56 |
Wonderfully Wicked
What size lipo you running? I was seeing about 40.5k which is what a 4S2200 will do, a 4S4000 will get you closer to 44k.
#57 |
It was a 25c 3700! My 2650 test battery makes it look real sick!
#58 |
deltas are cool
lucky
i tried to pm you and it does not work ...what are you saying ? what did i do wrong ? ...there is something wrong with you pm
#59 |
I dont know,it was working...
You know I was just messing with you on ducts,what I was trying to say is...Yes,I would like to purchase it from you.... I will PM you...Joe
#60 | |
Wonderfully Wicked
| Thread Tools | |
| Wanted HET 2W-20 or similar for 70mm fan | Buzz Bomb | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 14, 2009 12:49 AM |
| Wanted 4s inrunner for 70mm fan | Buzz Bomb | Aircraft - Electric - Jets (FS/W) | 1 | Oct 01, 2008 10:10 PM |
| Discussion New outrunner for 70mm fan | Scarey | Foamy EDFs | 2 | Dec 08, 2007 02:34 AM |
| Wanted EJF F-106 Kit for 70mm Fan | MattinAZ | Aircraft - Electric - Jets (FS/W) | 0 | Jun 07, 2007 12:25 AM |
| Discussion Inrunner/outrunner for ducted fan | firmabs6pk | Power Systems | 4 | Feb 08, 2006 01:11 PM |
