Old Jun 28, 2009, 09:10 PM
Fossil1977 is offline
Find More Posts by Fossil1977
Flying Extraordinaire
United States, FL, Fort Myers
Joined May 2006
Horten 229 V3 EDF plans
I was watching the National Geographic Channel about Hitlers Horten 229 V3 that may have had stealth ability and did a search for plans of this aircraft here on RCgroups.com. I found several folks that had built one of these plans but no one that offered any plans for a smaller EDF version. Anyone know where I could find a set of plans to build one of these magnificent planes?
Thanks in advance
Fossil1977 is offline Find More Posts by Fossil1977
Old Jun 28, 2009, 09:27 PM
LBJ is offline
LBJ
Find More Posts by LBJ
LBJ
Fort Worth, Texas
Joined Nov 2007
I have a set of plans by RC Model World by Chris Golds for A Horten IX with 68.5 inch span ands twin WeMoTec 480 fans. Plan MW 2668. Electric Flight International. Looks like a nice set of plans, although I have not built it yet.
LBJ is offline Find More Posts by LBJ
Old Jun 29, 2009, 02:42 AM
salat is offline
Find More Posts by salat
Trying To Takeoff
salat's Avatar
Novosibirsk, Siberia
Joined Dec 2006
Is there any video of Chris Golds plane flying?
Kostya
salat is offline Find More Posts by salat
Old Jun 29, 2009, 03:42 AM
John Wright is offline
Find More Posts by John Wright
United Kingdom, Harleston
Joined May 2004
If you want to build a Horten the best option would be Gary's kit
http://www.wingsontheweb.com/ho229/index.php
This is scale and has been well developed and can be seen flying in videos on Youtube
John
John Wright is offline Find More Posts by John Wright
Old Jun 29, 2009, 11:45 AM
Stripe is offline
Find More Posts by Stripe
Joined Jan 2009
Fossil I saw that NG piece last night as well and I couldn't tear myself away from the tube I enjoyed that very much.
John thanks that for the link to that kit it looks very impressive
Stripe is offline Find More Posts by Stripe
Old Jun 29, 2009, 03:48 PM
Joined May 2006
John
Wow, that is great, I am going to definitely order a kit. I will start a build log when I begin to build this one. My only concern is that it would be nice to have a little smaller version. Maybe I will see about scaling it down.
Old Jun 29, 2009, 08:23 PM
salat is offline
Trying To Takeoff
salat's Avatar
Joined Dec 2006
John
Yes, I know that Chris Golds' one is not so scale as Gary's. But it flies without external tubes. I do not like idea of thrust tubes.
Kostya
Old Jun 30, 2009, 01:56 PM
brett1984 is offline
Find More Posts by brett1984
RC Airliner Man
brett1984's Avatar
United Kingdom, Dudley
Joined May 2007
horten v229
hi, hope this helps its a plan for a horten v229 pss. soarer you could convert it to edf i surpose???
ive tield it too.....
brett1984 is offline Find More Posts by brett1984
Old Jun 30, 2009, 02:36 PM
heiner is offline
Find More Posts by heiner
Joined Jun 2007
@ Kostya,
also the Chris Golds' Horten needs tube extension, or minimum a little fin under the tail section.
It's just a matter of speed you are planning to go. As long as you are going like a park flyer, it will work without. I know no EDF Horten 229 V3 that will go safe without.
I have built 3 different Horten 229 V2 and V3, they all need at higher speed tube extension. And my Hortens are not from Gary. So the problem you will get with EDF thrust is not the wing profile. It may be the outer design of the Horten wing. Interesting, a real jet Horten will have less problems with airflow at the tail section.
We are almost testing 4 years to get quit of that tubes, but nothing helped until now......
Heiner
heiner is offline Find More Posts by heiner
Old Jun 30, 2009, 02:42 PM
salat is offline
Trying To Takeoff
salat's Avatar
Joined Dec 2006
Gary's Horten flies with deflector tubes only. I'd sacrifice some scale truth in favor of absence of them. And his plane also will not come through my doorway. I'd like something in 50"-60" range.
Old Jun 30, 2009, 02:50 PM
salat is offline
Trying To Takeoff
salat's Avatar
Joined Dec 2006
Hello Heiner!
Did you try to lower wing loading even more? Looking at woodwork of all Hortens I'd not say they are lightly built.
Please clarify what you mean saying parkflyer speed. Am I correctly understanding that at high speed, say at dive, it doesn't suffer from DF thrust? If the plane would be lighter - it would allow to lower take off speed and EDF thrust needed.
I also bit messed up with all Horten models. Can you please summarize a list of all Horten models you know?
Thank you,
Kostya
Originally Posted by heiner
@ Kostya,
Heiner
Old Jul 01, 2009, 04:56 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
wonder what the effects would be if one overscaled a tad and had by pass air around ducting to act as tubes?
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jul 01, 2009, 09:50 AM
heiner is offline
Joined Jun 2007
I can't list them all, but I think there are 4 or 5 different design of HORTEN 229 V3 wings, all with the same problem. Without EDF-thrust you can dive even fast, no problem at all. Using EDF-thrust and going over 60 - 75 mph the problem will start ......
Use plastic tubes as an extension, then you will not see them during flight.
Additional information at rcscalebuilder.com
Heiner
Old Jul 01, 2009, 10:57 AM
salat is offline
Trying To Takeoff
salat's Avatar
Joined Dec 2006
Heiner, what are level and stall speeds for Go229?
What you can comment about Imel plans?
Thank you,
Kostya
Old Jul 13, 2013, 12:45 AM
tedreiher is offline
Find More Posts by tedreiher
tedreiher
Australia, VIC, Sunshine North
Joined Jul 2012
I am building a Horten III Flying Wing glider from an English plan supplied by Nexus Plans,who seem to have gone out of business.
The glider has a wingspan of 131inches and has elevons, landing flaps and drag rudders.
For me it is proving to be both a challenging and stimulating build!
If anybody is interested I would welcome any input.
Regards
Edward(Ted) Reiher
tedreiher is offline Find More Posts by tedreiher
FS - MiG29 EDF plans Haldor Aircraft - Electric - Airplanes (FS/W) 0 Jul 25, 2002 10:02 PM
EDF Plans JetMang Electric Ducted Fan Jet Talk 5 Feb 22, 2002 10:46 AM
FS:EDF plans from Offshore Electronic and other darmar Aircraft - Electric - Airplanes (FS/W) 8 Dec 06, 2001 11:02 PM
Cessna Citation EDF plans Voyager E Aircraft - Electric - Airplanes (FS/W) 0 Nov 06, 2001 12:09 AM
Horten 229 Project Mark Nankivil Electric Ducted Fan Jet Talk 3 Aug 07, 2001 09:03 PM
