Closed Thread
This thread is privately moderated by Rubi_, who may elect to delete unwanted replies.
Old Jun 28, 2009, 03:08 AM
Rubi_'s Avatar
Joined Aug 2006
Trader Rating: 0
Vapor Minimum Charger
Hi Group
I built a 5* charger for my Kyosho Piper Cherokee and am very happy with it.
Charging time is about 20min.
If there is interest I would make a small production run.
Cheers
Rubi
Rubi_ is offline Find More Posts by Rubi_
Old Jun 28, 2009, 01:30 PM
flying with dx7...
futabafreak's Avatar
USA, MD, Westminster
Joined Aug 2006
Trader Rating: 28
I'm interested! what does it use as a power source and can it charge the 70-130-138mah at the same time?
futabafreak is offline Find More Posts by futabafreak
Old Jun 28, 2009, 06:01 PM
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
Trader Rating: 110
what freak said. , I want to just have a pigtail so I can run off a 5v USB OR off of 12v if possible (i'll wire it myself just tell me what one would work).
(also I need an extra little male jst connector for a lipo)
GFBurke is offline Find More Posts by GFBurke
Old Jun 29, 2009, 01:44 AM
Rubi_'s Avatar
Joined Aug 2006
Trader Rating: 0
Hi !
It uses 5V and 300mA / Stage.
So if you charge 5 Packs you would need 1.5 A .
Since any stage is independent of the others, it can charge any cell at the same time, of course the bigger the cell, the longer the charging.
I would not suggest to charge cells > than 300mah.
The connectors are JST on the power side and for the batteries the same connectors like used in the Vapor or Minimum models. Connectors are already attached.
Pricing:
12$ per stage.
So f.e. a 3 cell charger would be 36$
Cheers
Rubi
Old Jul 14, 2009, 11:23 AM
Pompano Beach, FL
Joined Jun 2006
Trader Rating: 8
I'm interested, 3 or 4 stage. Why 5v for the source?
FlaBill is offline Find More Posts by FlaBill
Old Jul 15, 2009, 02:13 PM
Rubi_'s Avatar
Joined Aug 2006
Trader Rating: 0
Hi FlaBill
I choose the 5V because of the datasheet of the IC. But you can use any power source between 5 and 7 V. Even power from the Usb bus is possible.
Cheers
Rubi
Closed Thread
Found PKZ Minimum Charger jwman Aircraft - Electric - Micro & Indoor Airplanes 1 May 04, 2008 10:27 PM
