Old Oct 03, 2012, 09:27 PM
dennisjm is online now
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
LOL.. was in jest she's happy.
dennisjm is online now Find More Posts by dennisjm
Old Oct 09, 2012, 03:59 PM
FLY_NAVY is online now
Find More Posts by FLY_NAVY
FLY_NAVY's Avatar
United States, VT, Shelburne
Joined Jan 2012
Originally Posted by Ken Lapointe View Post
My plane is still in the box, waiting for vacation to start it.
for those needing some inspiration get your F/A-18 hornet fix here, some great photos for screen wallpaper
http://www.zone-five.net/showthread.php?t=21
nice shots !!!
FLY_NAVY is online now Find More Posts by FLY_NAVY
Old Oct 26, 2012, 02:13 PM
Proud RC Addict
Joined Nov 2009
So...
Z-Poxy as instructions say.. except after putting the FB cloth on you then put over an additional layer of polyester. Then when it's nice and dry you peel back the polyester. Result is sanding is much easier. Right?
FB cloth comes in very thin,medium, and thick. I imagine for this you want the thin stuff right? This is my 1st experience with FB. I'll practice on some scrap balsa before I start applying on wings and stuff. I think I got the general concepts down.
Also, I noted way back in the thread to use Hysol for Balsa to fuse areas. A while back the fuse was all fiberglass it seems. Now it appears they're moulded plastic. Glue choice still stands? Tamjets the only place to get that? I saw some comments about mixing FB with epoxy too.
Anyway, I'm finishing up another couple projects but I'm collecting knowledge and material to start this build. I think I still am missing a few points on the best gluing practices.
Old Oct 26, 2012, 03:11 PM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Tamjets is where I buy Hysol too. Didn't find it anywhere else. Don't know why, as it is a Locktite product...
I used light (0.75) fiberglass cloth for the rudders and elevators, and heavy (2) for the wings.
The current fuse is made of plastic??? I don't know if that's good or bad...
ysolomon is offline Find More Posts by ysolomon
Old Oct 26, 2012, 03:19 PM
Proud RC Addict
Joined Nov 2009
Yeah, plastic it is.... so that's why I'm a little curious if Hysol is the correct solution still.
I'm thinking of heading back over to the LHS. About how much FB cloth did you require. Is a couple yd^2 enough to do the wings?
Old Oct 26, 2012, 05:00 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
That fuse is still epoxy it is finished a bit which looks plastic but its glass. Hysol will be fine regardless of the material, just make sure you rough up the bonding area and clean it with alcohol first!
bri6672 is offline Find More Posts by bri6672
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
Other Hysol venders
http://dreamworksrc.com/catalog/hysol-glue-p-113.html
http://www.mcmaster.com/#loctite-hysol/=jw60h2
Get the kit with the gun and a few extra long nozzles.
You can also use a good epoxy glue mixed with milled fiberglass if you dont want to get the hysol
Are you sure its plastic? From the outside it may look like that, but inside you should see fiberglass weave
You want finishing resin epoxy for glassing. Zpoxy or West systems work pretty well. You do not want standard epoxy glue.
I used 2 layers of the 3/4 glass on my wings and tail. Everyone has their favorite technique
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Oct 26, 2012, 05:04 PM
Proud RC Addict
Joined Nov 2009
Good info. I'll look closer at the fuse. It may indeed be glass but just looked plastic. I have an older FB fuse kit and it's most definitely glass and this one looked a lot more like plastic. Could be I just didn't take a close enough look though.
There is a local store around here that carries Hysol too. An industrial supply outlet.
Old Oct 26, 2012, 05:05 PM
bri6672 is offline
bri6672's Avatar
San Diego
Joined Jul 2009
Post pics because I want to see this "plastic" That model is designed to handle a turbine, plastic would not cut it!
Old Oct 26, 2012, 05:54 PM
Narragansett, RI
Joined Oct 2000
The grey fuse does kinda look like plastic from the outside
Old Oct 26, 2012, 08:18 PM
Proud RC Addict
Joined Nov 2009
Yeah I inspected closer when I got home this evening. It's very plastic appearing but you can see the weave of the FB on the inside. Either way I still need to grab some Hysol.
Old Oct 27, 2012, 07:40 AM
Proud RC Addict
Joined Nov 2009
Was reading the FB post again.. He used .56 for tail and .56-1.5 for wings. Only 1/2 oz stuff I found was from Hangar 9. The idea is to save weight with lighter and add more strength with heavier right? I'm thinking just using the .75 all around.
Old Oct 27, 2012, 02:07 PM
Narragansett, RI
Joined Oct 2000
Glass cloth
http://www.cstsales.com/sale.html
Old Oct 27, 2012, 02:55 PM
Proud RC Addict
Joined Nov 2009
Hey there you go. Good prices per yard. How many yards did you guys use?
Old Oct 30, 2012, 06:59 AM
Proud RC Addict
Joined Nov 2009
Any reason not to just go with the .6 oz all the way around? Perhaps a reason to go heavier on the wings? I'm thinking heavier cloth is better for moulding or strengthening parts but I'm not guessing the wings need that. But I see some are using heaving cloth there. Does it matter that much? Easier to finish one way or another?
EDIT: I reviewed the instructions actually. They do call for 1.5 oz on the wings.
1/10 scale f-18 jg1501 Electric Ducted Fan Jet Talk 2 Dec 06, 2009 10:20 AM
For Sale NewBright R/C International Outlaw CXT 1/10 scale lv2soar Cars - Trucks and Parts (FS/W) 0 Jan 08, 2009 02:23 AM
Discussion C-119 Retracts 1/10 scale 2M86 Scale Fuel Planes 1 Oct 01, 2008 04:52 PM
Help! 1/10 scale foam F-18 with Midifan question. X-spec Foamy EDFs 22 Feb 11, 2007 01:20 PM
Davie's 1/10 Scale C-17 Flew!! Hawker Electric Ducted Fan Jet Talk 16 Jun 19, 2004 04:41 PM
