Brett, thanks for checking in. Your concern is a common one, in fact I'm surprised the skeptism/doubt took so long.
This is a tried and true method having driven surfaces on models much larger than this. The beauty is that there is ZERO slop in the surfaces. If there is slop then there is a reason for it, and it's in the set up: 1. There’s slop in the servo gears. 2. The surface itself is flimsy or flexible. 3. The flat is convex. 4. Setscrews are not well seated. 5. The servo or its mount is loose. 6. The shaft used is too springy. 7. Hinging allows play between the fixed & moving surface. 8. The servo screw is not fully seated allowing the adapter to slip on the gear. 9. An adapter may seem to fit, but is the wrong one & allows slippage. 10. The pocket is wiggling around in the surface. 11. The pocket has split. 12. The shaft is not laterally restrained. Here's some information on the set up: http://augiemckibben.tripod.com/site...ive_system.pdf And if you really have doubts on the physics behind it, check this link out: http://www.hauninger.gmxhome.de/hobb...g/RDS/RDS.html |
Perth Western Australia
Joined Apr 2005
Thanks for the info
Ive been doing a bit more reseach on RDS system and there seems to be quite alot of info on the subject. Thanks for bringing it to our attention. I think ill give it a go on a wing im about to start building for a bizjet. I like the look of these heavy duty couplers. Check them out http://www.servocity.com/html/servo_..._couplers.html |
I believe you're right about Ed being helpful, the man is a pleasure to deal with, and quick to respond too. Just curious what is your guess as to the AUW? My initial guess was 16 lbs, but decided to go with a lighter weight when i ordered my gear from ED...BTW i sent those PDFs to you.
Build and Post |
Mark,
I think your estimate of 16 lbs should be pretty good. I was thinking 17-ish. At the moment as you see it sitting in these pics with all the claptrap that I know will be in there I'm at 230 oz. (14.375 lbs). What wasn't weighed was the misc tubing, wire, control horns, final paint, and balance weight. Everything else (fan, batteries, servos, tank, switch, valve, etc etc) was included in my weight above. Got the pdf, thanks! |
Sean,
You're welcome, and thank you for posting your build progress. You do some amazing stuff with your builds (A-7, F-18, P-51). I figured I would err on the lighter side with 15, and if it came in much heavier i could adjust. I know you plan on flying mostly from grass, I have a couple fields that I fly from that are asphalt only, so not overly concerned with the spring weight if it does come in heavier. Mark |
| Thread Tools | |
| 1/10 scale f-18 | jg1501 | Electric Ducted Fan Jet Talk | 2 | Dec 06, 2009 10:20 AM |
| For Sale NewBright R/C International Outlaw CXT 1/10 scale | lv2soar | Cars - Trucks and Parts (FS/W) | 0 | Jan 08, 2009 02:23 AM |
| Discussion C-119 Retracts 1/10 scale | 2M86 | Scale Fuel Planes | 1 | Oct 01, 2008 04:52 PM |
| Help! 1/10 scale foam F-18 with Midifan question. | X-spec | Foamy EDFs | 22 | Feb 11, 2007 01:20 PM |
| Davie's 1/10 Scale C-17 Flew!! | Hawker | Electric Ducted Fan Jet Talk | 16 | Jun 19, 2004 04:41 PM |
