Old Feb 13, 2013, 09:55 PM
Flazo is offline
Find More Posts by Flazo
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
did you have to add weight to balance with the 450kv/
Flazo is offline Find More Posts by Flazo
Old Feb 15, 2013, 12:14 AM
renwick56 is offline
Find More Posts by renwick56
United States, FL, Odessa
Joined Sep 2007
Actually I made several changes at the same time. I added heavier high speed metal gear (.08@6v) servos to all three surfaces in the rear. Added heavy hub to balance at the marked mid-point. Now, my AUW with 6s 4500 45C = 9 lbs!
Curious to know what other's electrics AUW are. Advertised weight is 7.5#'s (got to be empty tank nitro, with smallest motor.. ).
renwick56 is offline Find More Posts by renwick56
Old Feb 25, 2013, 09:59 PM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
I've been inching closer to completion on this bird for over a year now. Here a little, there a little. Thought I saw the light at the end of the tunnel until I shoved a reamer through the wing support when (without thinking) I was going to enlarge the hole for the dowel to fit. DUH! well, hole is filled, and wing support is in spray booth waiting for one more wet sand before the final coat of white and then back on track. In the meantime I made a pair of vinyl decals for the rudder. They give the bird some personality I think.
scott page is offline Find More Posts by scott page
Old Feb 26, 2013, 03:58 PM
wyo69cowboy is offline
Find More Posts by wyo69cowboy
USA, WY, Cody
I used 2 different motors in my Reactor bipe: a 5065 Turnigy 410kv (14.6oz motor weight), and then a 5055 Value Hobby 600kv (12oz motor weight). I used both 3300mah and 4000mah 6S packs. My plane came out at 7lb 5oz with my 3300mah packs, and 7lb 8oz with my 4000mah 6S packs with the heavier motor. I never had an issue with balancing it; there was plenty of room to shift the packs fore or aft as needed.
wyo69cowboy is offline Find More Posts by wyo69cowboy
Old Mar 07, 2013, 06:36 PM
rowdyjoe is offline
Find More Posts by rowdyjoe
rowdyjoe's Avatar
Arlington, TX
Joined Jul 2009
I thought I'd join the "weight" discussion and report on my Reactor Bipe with 20cc Zenoah. She weighs 8lbs 1oz with no fuel. Not bad compared to some of the weights I've seen here for electric birds.
I've installed a slightly larger fuel tank (around 450cc I think ...it's not labeled) and I should get somewhere around 20 to 30 min. flight time depending on how hard I run it. At $3.50 a gallon plus about $.75 worth of good 2 stroke oil for a 2 gallon container, that's darned cheap and whole lotta fun. She's a real rocket with this engine.
RJ
rowdyjoe is offline Find More Posts by rowdyjoe
Old Jul 16, 2013, 08:32 AM
Flazo is offline
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
Hi Just wanted to know if you upgraded you E-motor for the summer any feedback? thanks.
fred
Old Sep 06, 2013, 05:37 PM
dawhale is offline
Find More Posts by dawhale
USA, CA, Valencia
Joined Mar 2011
Working on my Reactor Bipe this last few weeks. Should be ready to fly next week.
Rimefire 80
dawhale is offline Find More Posts by dawhale
Old Oct 24, 2013, 08:43 AM
Flazo is offline
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
dawhale how is that Rimfire 80?
Old Oct 24, 2013, 10:30 AM
dawhale is offline
USA, CA, Valencia
Joined Mar 2011
I think it is a perfect fit. I easily get 8 minutes with a 5000 mah Lipo. I could go longer as I land with 30 -35% left. It will hover then unlimited climb out. The airplane has a large speed range. Looks like it has been discontinued,
Old Oct 24, 2013, 11:15 AM
Flazo is offline
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
I have the plane..nib my friend is using your motor for the Extreme Flight Edge EXP 60 inch
is a very nice looking motor. Thanks for the update
fred
Article Great Planes Revolver GP/EP Sport Aerobatic ARF Review kevin Sport Planes 753 Yesterday 10:58 AM
Question Will AXI 4120/xx fit Grate Planes Reactor .46 GP/EP T.Rex.450 3D Flying 1 Aug 23, 2008 03:05 AM
Video Great Planes Reactor Bipe Maiden moxjett Electric Plane Talk 1 Mar 28, 2008 01:48 PM
Article Great Planes Performance Series Giant Scale Cap 3D ARF Review w/ OS 160 Steve H. Fuel Plane Talk 6 Jun 28, 2006 02:56 PM
Great Planes Mfg. Fun Force EP Sport Combat Foam ARFs Dave Lauck Product Announcements 0 Aug 23, 2005 01:36 PM
