Old Jun 26, 2009, 10:50 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
JR module/type Pinouts ?
Hello Im soon getting my JR based FlySky module 2,4ghz, and will put it in one of my old 35Mhz radios, maybee My Graupner MX-12..
Is it right the way Ive painted on the Module ?
2 more important qustions:
1) what voltage will the FlySKy module accept ?
2) IS the PPM signal from a Graupner MX-12 ready to plug in ?
Voltage in Graupner(and most TX) are the same as 8 nimh batteries = 10 volts
, but for the PPM signal I dont know...
Sebbe..
sebbe is offline Find More Posts by sebbe
Old Jun 26, 2009, 10:59 AM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
This was posted quite a while ago. Assuming your 2.4 module is specifically designed for JR transmitters there shouldn't be any problems with voltage or the PPM signal.
GBR2 is offline Find More Posts by GBR2
Old Jun 26, 2009, 01:22 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
thats right, I dont know if FlySky JR module could be put directly into a JR radio, there was something about 6 volts to ground you have to change..
But this doesent affect me, cause the Graupner MX-12 is NOT a module based radio anyway.. I have to cut the wires inside radio and connect to the FlySKy module...
What do you all say, the PPM signals-levels should be the same in all JR radios ? or ?
I know for a fact that the MX-12 signals goes directly into an Assan module, but wunder if Flysky module is as forgiving as Assan ?
JR Module Question Pookee Radios 1 May 22, 2005 05:10 PM
JR Module and Crystals for sale :) oneinnesja Aircraft - General - Radio Equipment (FS/W) 1 Mar 15, 2005 03:45 PM
f/s on ebay jr module 50 mhz band channel 50.940 mkeigwin Aircraft - General - Radio Equipment (FS/W) 0 Dec 01, 2004 11:58 AM
fs jr module net- j 50 p and and airtronics 8 ch receiver mkeigwin Aircraft - General - Radio Equipment (FS/W) 4 Nov 22, 2004 09:43 PM
JR Module retuning Kitsu Radios 0 Apr 04, 2003 03:03 PM
