Old Aug 20, 2009, 01:22 AM
carguy671 is offline
Find More Posts by carguy671
Excuse me , I speak Jive...
carguy671's Avatar
United States, OH, Dayton
Joined Jun 2008
Callie is supposed to be making decals for Cripes-a-mighty 3rd, but she has not posted them yet.
carguy671 is offline Find More Posts by carguy671
Old Aug 20, 2009, 01:39 AM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
So how many Bluenosers are we going to have at SEFF 2010?
Moonbeam is offline Find More Posts by Moonbeam
Old Aug 20, 2009, 01:43 AM
carguy671's Avatar
Joined Jun 2008
My airframe kit will be a bluenose in the next few days. Where is the best place to get the tamiya paint that you used Moonbeam ? I was either going to do Cripes the 3rd or Big Beautiful Doll. The checker board nose on BBD would be pretty hard to do though.
Old Aug 20, 2009, 02:11 AM
LunaRendezvous is offline
Find More Posts by LunaRendezvous
Registered Drug Free
LunaRendezvous's Avatar
Joined Jan 2009
Oh there is a line there that I so want to use, but I'd have to report myself then.
LunaRendezvous is offline Find More Posts by LunaRendezvous
Old Aug 20, 2009, 02:20 AM
DogFly. is offline
Find More Posts by DogFly.
sKrude up, Rejected!
DogFly.'s Avatar
United States, FL, St Augustine
Joined Jun 2008
Where you refering to the "Brown noses"?
Dave.
DogFly. is offline Find More Posts by DogFly.
Old Aug 20, 2009, 09:25 AM
Moonbeam is offline
Moonbeam's Avatar
Joined Mar 2004
I've picked up mine at 4 different hobby shops including Hobbytown USA.
What would be cool, is when everybody gets their paint schemes done, is have a post that displays them by group. 357th, 352nd, 361st, etc.
Old Aug 20, 2009, 09:59 AM
Moonbeam is offline
Moonbeam's Avatar
Joined Mar 2004
Baby Mustang!!!!
Hehe, look what I found!!!!
http://www.parkzone.com/Products/Def...ProdID=PKZ3680
Old Aug 20, 2009, 10:27 AM
carguy671's Avatar
Joined Jun 2008
We have three gunfighters and they should all be in different schemes.
Old Aug 20, 2009, 11:15 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by DogFly.
Mike,
I can't argue the stats, the TGY35-36c will definitely make it scream!
But the TGY SK35-36 910kv might be a little tamer, if your just starting out.
Dave.
Consensus on the SK 910 motor in the T-28 forum is it is lacking on power. A report on the 1400kv is better but needs a smaller prop.
robj is offline Find More Posts by robj
Old Aug 20, 2009, 11:21 AM
okiedoak is offline
Find More Posts by okiedoak
manassas Va
Joined Aug 2009
Hey everyone, that a great thread, I read all of them..
Question, has anyone played with the stock esc programming
okiedoak is offline Find More Posts by okiedoak
Old Aug 20, 2009, 11:26 AM
robj is offline
robj's Avatar
Joined Nov 2008
I find the mustang a real handful at slow speeds, yet once you get it above 40MPH it handles very nicely, in fact the faster you go the better it handles. I think the OP may need to add a little more info on what he's trying to achieve, as you're well aware there is no "best" motor.
Mike.
I guess same plane to different people. One thing I really enjoy about my p-51 is now nice it flys and a real slow speed. like 1/4 throttle. I like to make some real slow passes doing a wing rock, then point it up and go vertical from that slow speed, I get a shot of that in my video I posted. It'll go up fast and as high as I want(it's not stock).
If you are having control speeds at slow speeds, might check your COG, I have mine back about 3" to 3 1/8" from the LE. Nice flat inverteds.
It does fly well at high speeds to!
Old Aug 20, 2009, 11:32 AM
losifanatic is offline
Find More Posts by losifanatic
Sippin the Koolaid!
losifanatic's Avatar
United States, NC, Hertford
Joined Oct 2007
Mine came in stock with a auw of 23.4 oz. The slow speed handleing was great. I have since crashed and did lots of repairs adding to the weight. Its now 26.9oz. It has hurt the slow speed flyabilaty of it some but still flys well. My brother corsair is now flying a little slower than mine(where as before the mustang would fly slower)
I would check the CG if you are having slower speed issues?????
losifanatic is offline Find More Posts by losifanatic
Old Aug 20, 2009, 11:48 AM
robj is offline
robj's Avatar
Joined Nov 2008
Here is a simple drawing of the mount. Basically a traced stock motor mount, with a little more added on top for the X mount. I centered the X mount over the center motor hole of the stock mount, then marked the X mount holes. The #4 marked holes are so you can put a screwdriver through them to attach the motor to the X mount after you have the screws mostly adjusted. The 6-32 machine screws are pretty close to the motor. The #5 marked holes are just a few I put in to lighten the mount some. In another mount I made for a friend I put even more of the lighten holes.
You could also purchase and use the gold turnigy mount, the X mount hole pattern is larger but it gives you more room to work with the nuts. The aluminum is 3/16 thick, cut out with a simple hack saw and rounded off on a grinder. Then sanded smooth on some 220g sandpaper. I've got it down to about 15 minutes to make one.
Rob
Old Aug 20, 2009, 11:52 AM
robj is offline
robj's Avatar
Joined Nov 2008
I built up an airframe kit so I don't have the stock esc. But on my Turnigy 40a esc I did set the brake. I found on other planes it will help save a prop or 2. If you can figure out how..I would set the brake.
Old Aug 20, 2009, 11:55 AM
robj is offline
robj's Avatar
Joined Nov 2008
GREAT!!!! JUST WHAT I NEED!!!! ANOTHER PLANE!! Wanna buy a lightly used Sukhoi?
Actually think I can hold off on this one unless I can sell the Sukhoi. this might have been more what I was looking for, looks a little heavier and faster than the sukhoi though. Interested in the flight reports, looks like you can't buy them yet...Backordered on the HH site.
I really want to hold of for the larger Sukhoi 480 that's brand new.
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 12:22 PM
Alert Parkzone P 51 Mustang peiviper Electric Plane Talk 35 Sep 14, 2009 01:48 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 10:02 PM
For Sale Parkzone P-51 Mustang argarre Aircraft - Electric - Airplanes (FS/W) 9 Sep 20, 2005 11:57 AM
Parkzone P-51 Mustang wattman Parkflyers 453 Feb 20, 2005 01:48 AM
