Old Feb 16, 2013, 10:15 AM
Bugbitten is offline
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
The 1100Kv works great with the Trojan prop.
I use the 810Kv in my PZ Corsair with a 4 blade prop.
Bugbitten is offline Find More Posts by Bugbitten
Old Feb 16, 2013, 03:33 PM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
Originally Posted by Sammy70 View Post
Mine goes 70-80mph and 4 rectangles of heavy duty clear 3M packing tape (instead of the provided tape) have worked perfectly...
+1 and that is what I now use on all the Parkzone planes. Here is a picture of what the Corsair looked like the day after the maiden flight. Good thing my pre-flight check caught it. The glue on the stock tape had completely let go after less than 24 hours, and an in-flight disaster was narrowly avoided. I didn't just slap that tape on there, but applied it carefully and pressed it down.
nageotte
To answer your question about the popularity of the P51 and if there was ever anything as popular...the answer is yes. One is the Radian (not Pro) and another is the Corsair.
Jovanx is offline Find More Posts by Jovanx
Old Feb 17, 2013, 05:09 AM
Just Fly is offline
Find More Posts by Just Fly
Canada, ON, Toronto
Joined Jul 2012
Thanks to all that posted, with the great info
Think I am gonna get the 1100kv
cheers and Happy Landings!
Just Fly is offline Find More Posts by Just Fly
Old Feb 17, 2013, 06:15 AM
LICobra is offline
Find More Posts by LICobra
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
Originally Posted by Buster1000 View Post
Thanks for this important data. Do you have the data for using a 4 cell 2200? Thank
Buster....No data on 4S...I like to use a 10X9 4 blade prop and 4S would put the amp draw way over the motors capabilities.
LICobra is offline Find More Posts by LICobra
Old Feb 17, 2013, 06:57 AM
nageotte is offline
Find More Posts by nageotte
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
What prop is that?
nageotte is offline Find More Posts by nageotte
Old Feb 18, 2013, 07:56 AM
LICobra is offline
Warbird Enthusiast
LICobra's Avatar
Long Island, NY
Originally Posted by nageotte View Post
What prop is that?
It's an 11X9 apc 4 blade glo prop, that I cut the diameter down to 10". I cut it down to lessen the amp draw and raise the rpms a bit....
If I had to do it all over again, I would probably use the Durafly P-51 4 blade from hobbyking....it's the right size and looks so much better...just not as durable.
Old Feb 18, 2013, 08:28 AM
hootowl is offline
Find More Posts by hootowl
Fanboy
Joined Apr 2006
Originally Posted by Jovanx View Post
I was awakened by the title of your post "My 2 cents", and was struck by this thought. Today is the day that Canada made the penny obsolete, and has told all businesses to round to the nearest nickel.
May I suggest a 9.5 x 7.5 prop more commonly known as a T28 prop. It is awesome with either the stock motor or the Power 10. The 9x6 pales in comparison.
Pennies mean nothing when using electronic payment.
hootowl is offline Find More Posts by hootowl
Old Feb 18, 2013, 10:13 AM
jdwolters is offline
Find More Posts by jdwolters
Fly, be free! (splat)
United States, CA, Danville
Originally Posted by GBLynden View Post
Do any of you guys own a Wildcat too? If so, how do the mustang and the Wildcat compare?
Originally Posted by 19000rpm View Post
The Mustang is a tad quicker and more maneuverable than the Wildcat if you added rudder. Rolls in particular are nicer with the P-51.
Both planes are great candidates for upgrades. I have power 10's in both model types. Flaps and retracts on one P-51.
+1. I've got both and I alternate between them. My mustang is souped up for speed and unlimited vertical while my Wildcat is stock except for a T28 prop and higher-C batteries. The mustang is fast an maneuverable while the wildcat is more relaxing and floaty on landing. Both are really well behaved have a gentle stall.
jdwolters is offline Find More Posts by jdwolters
Old Feb 18, 2013, 03:34 PM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
You can get the prop decals from Callie. They make that APC prop really acceptable. I have it.
Old Feb 19, 2013, 02:02 AM
foamyflyerr is online now
Find More Posts by foamyflyerr
Joined Jun 2012
how did you do the retracts on your P51 ?
foamyflyerr is online now Find More Posts by foamyflyerr
Old Feb 19, 2013, 06:36 AM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Read the Gunfighter Mod forum.
This was my first one. Since then I use servoless retracts. Cheap Chinese ones that will fit better.
http://www.rcgroups.com/forums/showt...1091109&page=5
http://www.youtube.com/my_videos_edi...RUqa9EMvM&ns=1
Old Feb 19, 2013, 06:46 AM
nageotte is offline
I can fix it.
nageotte's Avatar
Cochranton, Pa.
Joined Nov 2005
Double post. I have to figure out out to delete these!!
Old Feb 19, 2013, 07:07 AM
19000rpm is offline
Find More Posts by 19000rpm
Joined Aug 2009
I use the Eflite 10-15 retracts. I installed them right where the panel lines are for the retracts on the bottom of the wing. I cut the foam out for the retract mechanism to within 1/16" of the top surface to make them almost flush when retracted. I epoxied the inside with ply mounting pieces. On the top of the wing I place a plastic panel over the retract to reinforce the surface. The wheel cutouts are right about 2" and I use foam wheels off of the HZ Super Cub. The cutout of the wheels touch on the fiberglass wing spar. I added a CF spar in the wing.
I also added flaps and a Power 10. It's been repainted in a Korean war tribute scheme. I've enjoyed flying the plane since 2010.
19000rpm is offline Find More Posts by 19000rpm
Old Feb 19, 2013, 09:18 AM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
How does it fly with the added weight of those retracts? I want to put retracts on mine as well. I'm just worried about too much weight and it making the plane "fly heavy".
Hit N Run is offline Find More Posts by Hit N Run
Old Feb 19, 2013, 11:03 AM
19000rpm is offline
Joined Aug 2009
Actually, the added wing loading makes it fly more like a full size with a Power 10.
I highly recommend adding the flaps also since, being heavier, the model has a higher landing speed with out flaps. With flaps the plane will easily do 3 pointers with practice and a smidge of headwind.
Here's a link to the whole wing mod.
http://i845.photobucket.com/albums/a...51%203/001.jpg
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Alert Parkzone P 51 Mustang peiviper Electric Plane Talk 35 Sep 14, 2009 12:48 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
For Sale Parkzone P-51 Mustang argarre Aircraft - Electric - Airplanes (FS/W) 9 Sep 20, 2005 10:57 AM
Parkzone P-51 Mustang wattman Parkflyers 453 Feb 20, 2005 12:48 AM
