Old Oct 29, 2009, 08:36 PM
Hobbycentral is offline
Find More Posts by Hobbycentral
Hobbycentral's Avatar
Santa barbara
Joined Aug 2009
Hi all just thought you would get a kick out of this We finally finished the p-82
Check out the thread http://www.rcgroups.com/forums/showt...095175&page=36
Hobbycentral is offline Find More Posts by Hobbycentral
Old Oct 29, 2009, 08:37 PM
DogFly. is offline
Find More Posts by DogFly.
sKrude up, Rejected!
DogFly.'s Avatar
United States, FL, St Augustine
Joined Jun 2008
Steering
Check my P-82 thread, I did internal steering on the Twin Mustang!
I just noticed Hobbycity posted the link right before me.
DogFly. is offline Find More Posts by DogFly.
hannibal202us is offline
Find More Posts by hannibal202us
*Go Fast Fly Low Turn Left*
Abq, NM
Joined Apr 2009
Hows it fly? What power sets did you use? Tell us please!!?!
hannibal202us is offline Find More Posts by hannibal202us
Old Oct 29, 2009, 08:38 PM View Post
yanan
A moderator felt this post violated the following rule: Excessive Advertising (Spam). It is temporarily hidden while yanan edits it. Show it to me anyway.
Old Oct 29, 2009, 08:39 PM
DogFly. is offline
DogFly.'s Avatar
Joined Jun 2008
Not flown yet, check the thread link above!
Old Oct 29, 2009, 09:33 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Looks GREAT Dogfly!!
Sammy70 is offline Find More Posts by Sammy70
Old Oct 29, 2009, 09:52 PM
Abq, NM
Joined Apr 2009
Hi All... I just wanted to see what Peoples thoughts were on the ar500 receiver they put in the Stock p51 and others too. Has anyone else had interference or loss of signal issues? I am unfortunately -1 in my fleet because I had issues. I'm not saying it was receiver or pilot error, I'm just wondering if anybody else has had problems with the receiver likewise?
Old Oct 29, 2009, 10:42 PM
Moonbeam is offline
Find More Posts by Moonbeam
352nd FG Association
Moonbeam's Avatar
United States, GA, Decatur
Joined Mar 2004
Originally Posted by Tram View Post
Ok, I've got two questions..
First, Thought some of you Mustang experts might know - Anyone know how long the drop tanks on the real P-51 were?
Second, does anyone know where I might be able to find the manual for the stock 18A esc? Trying to turn the brake on and cannot find a manual.. Nothing is said in the P-51 manual..
Couldn't find any info on dimensions, but here's some stuff: The first is the paper tanks they used.
Moonbeam is offline Find More Posts by Moonbeam
Old Oct 29, 2009, 10:48 PM
Moonbeam is offline
Moonbeam's Avatar
Joined Mar 2004
Yes. Both my Mustangs experienced the same thing. My "Hell-er Bust" had one on the 37th flight. Complete loss of everything right after it left my hand, crashed in the tall weeds. My "The West By Gawd Virginian" had the exact same thing on it's 3rd flight, right at launch, but came back in 2 1/2 seconds and I was able to land it safely.
I made a new rule. First flight of the day, just go ahead and rebind the Rx to the Tx. Just to cover your butt. Since I've started doing that, haven't had anymore problems.
Old Oct 29, 2009, 11:31 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Thanks.. I think I am going to go with some that look like the metal ones they used.. Gonna snag some 7 5/8" tanks from Sparky, I think..
Tram is offline Find More Posts by Tram
Old Oct 30, 2009, 12:01 AM
Tony A. is offline
Find More Posts by Tony A.
Did ya'll see that?!?
Tony A.'s Avatar
Elizabethtown, NC
Joined Mar 2009
I found a post in a forum for Hot Rod builders where a guy bought a P-51 tank to build a hot rod out of. He lists it as "about 7' long" so I guess 19000RPM's scaling was pretty accurate.
Attached is the pic that the guy at the hot rod forum posted.
Tony A. is offline Find More Posts by Tony A.
Old Oct 30, 2009, 12:09 AM
mfpage is offline
Find More Posts by mfpage
NORDPAC S3
mfpage's Avatar
United States, OR, Estacada
Joined Jan 2009
Yes, AR500 problems
After several problems from high altitude with several AR500's with several planes, I have decided it's not the receivers, it's the TXR, so I am retiring my DX6i and changing to an Aurora 9 transmitter. Yes, the DX6i was sent to Horizon.
Mfpage
mfpage is offline Find More Posts by mfpage
Old Oct 30, 2009, 04:19 AM
pauljohnston is offline
Find More Posts by pauljohnston
Winston Hills, Sydney
Joined Apr 2009
Hi Nageotte,
Nice job on the retracts and steerable tail wheel.
Thinking of doing the same. Can I ask if you land on grass or concrete?
Our field is grass which we try to keep fairly well cut but it's not
a lawn by any means. Have you had any problems landing?
Approx how much of an angle do you have between the bottom of wing and
wheel struts?
Knowing what you know now, would you do anything different if you had
to do it again?
thanks
Paul
pauljohnston is offline Find More Posts by pauljohnston
Old Oct 30, 2009, 12:41 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I have had several problems with the AR6100's. Lost two planes with them. Ever since I quit using the and went to AR500's and AR6200's I have had no problems.
I would go with all full range receivers unless you have a spektrum receiver on the outside of a foamie. Ar500's are solid, no worries.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Oct 30, 2009, 01:27 PM
xraydoc is offline
Find More Posts by xraydoc
xraydoc's Avatar
Little Rock, AR
Joined Apr 2009
Prop upgrade to corsair - t28 prop BIG dissapointment
I was looking for some more speed from the mustang so I got a 30A esc and the 9.5x7.5 corsair\t28 prop
using the stock motor
mesurements as follows
Stock 9x6 prop with 1550mah 30c rhino pack
208w
17.5a
11.6v
9.5x7.5 corsair\t28 prop with 1550mah 30c rhino pack
213w
18.1a
11.6v
Also tried a master airscrew prop 11x8 with 1550mah 30c rhino pack
274w
23.4a
11.6v
only thing I can figure is the stock 9x6 prop is more of a "slow fly" shape which always seem to pull more that a similar apc style prop
Just didn't see how a gain of 5w from the corsair prop was worth messing with.
QUESTION: can the STOCK MOTOR handle the 274w\23.4a using the 11x8 prop - I fly a lot at WOT
xraydoc is offline Find More Posts by xraydoc
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Alert Parkzone P 51 Mustang peiviper Electric Plane Talk 35 Sep 14, 2009 12:48 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
For Sale Parkzone P-51 Mustang argarre Aircraft - Electric - Airplanes (FS/W) 9 Sep 20, 2005 10:57 AM
Parkzone P-51 Mustang wattman Parkflyers 453 Feb 20, 2005 12:48 AM
