Old Jun 26, 2009, 07:02 PM
xdrive is offline
Find More Posts by xdrive
Joined Jun 2009
Something broke already?
Gee, don't tell me it's another flying egg crate
xdrive is offline Find More Posts by xdrive
Old Jun 26, 2009, 07:42 PM
xlrDALLAS is offline
Find More Posts by xlrDALLAS
Going broke, dam this hobby
xlrDALLAS's Avatar
cleveland oh
Joined Mar 2009
is there a place that shows all tx,s that will work with the bind and fly version i have a e-flite MLP4DSM TX I WANTED TO KNOW IF THIS WOULD WORK
THANKS for the help
xlrDALLAS is offline Find More Posts by xlrDALLAS
Old Jun 26, 2009, 07:43 PM
Skyking213 is offline
Find More Posts by Skyking213
out of the western sky...
Skyking213's Avatar
Harbor City, CA
Joined Jul 2003
Flew my BnF today! Installed a HS-55 for rudder, REALLY easy! Flys GREAT!
No problems! Goes vertical! Faster than Scale... Flys slow, too! Gentle stall, too!
Will NOT spin or snap roll, I tried! 10 minutes easy with stock 1300 3s pack, if you can resist WFO most of the time! Easy overhand and underhand toss launch at about 75% throttle!! The rudder is not terribly effective (like the T28) but at least I don't feel dumb when I use the left stick out of habit! Like I do on my ALFAs! Glides well, lands slow and steady like a butterfly on the grass. No drama here!
I might play with a different prop, if I ever break this one.
Great job PZ!
Skyking213 is offline Find More Posts by Skyking213
Old Jun 26, 2009, 07:46 PM
Skyking213's Avatar
Harbor City, CA
Joined Jul 2003
Hi!
Thats the one from the Blade MCX, right?
That is a very low power, short range Tx!
Get a DX5e for about $59!
ScottB
THANKS for the help
Old Jun 26, 2009, 07:53 PM
xlrDALLAS's Avatar
cleveland oh
Joined Mar 2009
thanks skyking
Old Jun 26, 2009, 07:55 PM
LunaRendezvous is offline
Find More Posts by LunaRendezvous
Registered Drug Free
LunaRendezvous's Avatar
Joined Jan 2009
What are the dimensions of the spinner? Particularly the diameter where it meets the fuse? Might see if I can locate a suitable replacement.
LunaRendezvous is offline Find More Posts by LunaRendezvous
Old Jun 26, 2009, 08:30 PM
Ping is offline
Find More Posts by Ping
Ping's Avatar
Indianapolis
Joined Aug 2004
Lets get this party started. Hopefully the stock motor can handle a 9x9...
This is my first parkzone plane, my first foam aircraft, and my first P51 after nearly 17 years in the hobby.
My initial impressions:
-The stock prop is a joke that thing is going right in the trash
-18 amp ESC and 1300 mah pack are disappointing but I'm sure it will fly fine stock. I guess I'll never know.......
-Not including a rudder is the silliest decision ever. The servos are probably less then a dollar at actual cost. They really can't throw one in?
-The RTF includes an RF 3channel radio after the Corsair included a DX5. Again silly, charge more and throw in the DX5. Hell even design a 3 channel single stick DSM radio I bet that would be a big hit.
On with the build, I'm going to be using a 30 amp E-Flite ESC, a Hitec HS55, and a T-28 prop or 9x9 depending on amp draw. Zippy 30c 3S 2200 packs for power
Ping is offline Find More Posts by Ping
Old Jun 26, 2009, 08:39 PM
ronin4740 is offline
Find More Posts by ronin4740
Wandering IT geek
ronin4740's Avatar
United States, NV, Reno
Joined Aug 2005
Dratted work - I've not been able to get home to get mine installed. I'm also going to go with Zippy 2200's if they fit and the P-51 will balance with them. Curious to see how you make out with them in yours Ping!
ronin4740 is offline Find More Posts by ronin4740
Old Jun 26, 2009, 08:43 PM
eli5539 is offline
Find More Posts by eli5539
eli5539's Avatar
Western New York
Joined Dec 2007
I also found you need to cut out the fire wall to get a 2200 battery to fit. Plus if you are going to use an adapter to get a larger prop to work
eli5539 is offline Find More Posts by eli5539
Old Jun 26, 2009, 09:24 PM
grimace308 is offline
Find More Posts by grimace308
wormburner
Minneapolis
Joined May 2009
the outside of the flange that holds the nosecone is about 1 15/16".
the front of the engine housing is about 2 17/32"
the gap between the thingy and the housing is 1/4" mine, but i have a 1/16" washer in there so its probably 3/16" stock.
i said screw it and slapped on a corsair spinner, as ill probably go through a thousand nosecones otherwise. it doesnt look too bad, but i dont care at all about looks...or all that much
grimace308 is offline Find More Posts by grimace308
Old Jun 26, 2009, 09:37 PM
Ping is offline
Ping's Avatar
Indianapolis
Joined Aug 2004
The spinner is pretty bad, I'll have to look around for a replacement. A T-28 prop will fit without modifications. APC-E props will not.
Old Jun 26, 2009, 09:38 PM
wormburner
Minneapolis
Joined May 2009
to maintain balance, i cut backwards into the body, not forward into the firewall. if ihad a brain, i probably would have dug out some of the canopy instead of trying to dig out the body. there is a nice 11/16" wide 1/2" deep rib that would have shaved out nicely.
the t-28/corsair prop is has a larger diameter hole than the p-51, a coned washer is needed.
Old Jun 26, 2009, 09:42 PM
Joined Jan 2009
thx grimace...
some thing like this might fit...
http://www.truturn.com/cgi-bin/store...exact_match=on
Expensive but imho the best Aluminium spinner available!
Old Jun 26, 2009, 09:45 PM
dude_109 is offline
Find More Posts by dude_109
dude_109's Avatar
Houston, TX
Skyking213,
Which Alfa(s) do you have? How would you compare this P-51 in terms of slow handling abilities?
My prime flying site is slightly small, 400ft x 150ft, more than enough for helicopters but I can't have these planes going very fast.
dude_109 is offline Find More Posts by dude_109
Old Jun 26, 2009, 10:11 PM
Ping is offline
Ping's Avatar
Indianapolis
Joined Aug 2004
Do you guys really just tape the stab into place on these things? Not sure I would trust the elevator hinges either....
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Alert Parkzone P 51 Mustang peiviper Electric Plane Talk 35 Sep 14, 2009 12:48 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
For Sale Parkzone P-51 Mustang argarre Aircraft - Electric - Airplanes (FS/W) 9 Sep 20, 2005 10:57 AM
Parkzone P-51 Mustang wattman Parkflyers 453 Feb 20, 2005 12:48 AM
