Old Aug 26, 2009, 05:44 PM
Matt Howard is offline
Find More Posts by Matt Howard
Dyess AFB
Joined Apr 2009
Maidened my Petie 2nd tonight, what a nice flying plane. I think it needed one click of aileron and she was tracking dead straight. I have a park 480 on a MAS 10x7 and it's pretty quick, not blistering fast, but just about right for me. After dinner I'm gonna go put another couple packs through her.
Matt Howard is offline Find More Posts by Matt Howard
Old Aug 26, 2009, 05:49 PM
Olias is offline
Find More Posts by Olias
Pushin' the Limits
Olias's Avatar
Bellingham,WA.
Matt...are you referring to an E-Flite Park 480 1020KV? Just curious because I have one laying around and am thinking of starting with that when my Stang gets here. Will probably use a MAS 10x7 as well. This is my set up on my E-Flite P-47 and it's just about perfect.
Also, if it is the E-Flite 480 how are you mounting it? With a whole different mount or just some sort of adaptor onto the Stang's mount? Thanks
Bryan
Olias is offline Find More Posts by Olias
Old Aug 26, 2009, 05:54 PM
Dyess AFB
Joined Apr 2009
Bryan
There's actually two park 480's, the 1020KV one that you have, and I have the 910KV one. I had to buy a motor mount off of ebay to mount it, cost $20 shipped.
Old Aug 26, 2009, 06:06 PM
anti-gravity is offline
Find More Posts by anti-gravity
In the 20' glider range
anti-gravity's Avatar
Boise, Idaho
Joined Jul 2009
whats the difference between the 1020KV and the 910KV?
anti-gravity is offline Find More Posts by anti-gravity
Old Aug 26, 2009, 06:30 PM
LunaRendezvous is offline
Find More Posts by LunaRendezvous
Registered Drug Free
LunaRendezvous's Avatar
Joined Jan 2009
If you power up the two motors without a prop with an 11.1volt battery...
then the 910KV motor will spin to 910 x 11.1 = 10101RPM
The 1020KV motor will spin to 1020 x 11.1 = 11322RPM
So if you put the same propeller on, then the 1020KV would produce more thrust, but consume much more power.
Itís not quite a perfect equation but its close.... KV x Volts = RPM (unloaded)
Mike.
LunaRendezvous is offline Find More Posts by LunaRendezvous
Old Aug 26, 2009, 06:35 PM
Boise, Idaho
Joined Jul 2009
ohh thanks mike
what is a brushed 480park motor rated at?
Old Aug 26, 2009, 06:49 PM
Ickarusmelt is offline
Find More Posts by Ickarusmelt
old pilot
Ickarusmelt's Avatar
Rapid City SD
Joined Dec 2007
According to advertising, the brushless Park 480 910kv does 250watts and the 480 1020kv does 275watts. The brushless 480 they put in the PZ Trojan, Corsair and P51 Gunslinger is a 960kv and is apparently somewhere in between. (They probably do stuff like that so guys spend more to do a conversion .)
My flat wing aileron HZSC has the Park 480 1020kv (Rocket Cub) and seems to do stronger vertical than my stock PZ Corsair. Looks like wing and tail drag would be similar, but Corsair nose and fuse is a lot wider. I have another SC for training with smaller Park 450 890kv and it still does pretty strong vertical. Of course it also depends on what prop you do.
If you have a 480 1080kv laying around getting lonesome, it's probably worth the tinkering to put it on the more streamlined P51 gunslinger. Of course, you could get a power 10 or equivalent .
Icky
Ickarusmelt is offline Find More Posts by Ickarusmelt
Old Aug 26, 2009, 06:54 PM
old pilot
Rapid City SD
Joined Dec 2007
And also the brushed 480 inrunner plus gearbox they put in the stock HZSC (and older PZ P51, Focke 190 and Spitfire) does about 60 watts and with a 3 lipo does about 90 watts.
Old Aug 26, 2009, 07:03 PM
old pilot
Rapid City SD
Joined Dec 2007
Gotta add my instructor buddy (40yrs RC and now doing exclusively electrics) has some advice. He says stock power is okay, more power is better, and way too much power is just right. However, he loves he new stock P51 Gunslinger Icky
Old Aug 26, 2009, 08:55 PM
Olias is offline
Pushin' the Limits
Olias's Avatar
Bellingham,WA.
Thanks Matt. If you don't mind me asking, which mount? I'm aware of the aluminum ones that this guy makes for the Corsair (and I think Trojan) as well as the Super Cub but never knew there was one that would work for this particular ParkZone P-51. Do you have a link? Thanks
Bryan
Old Aug 26, 2009, 09:03 PM
skydve76 is online now
Find More Posts by skydve76
More jets than a carburetor
skydve76's Avatar
United States, NE, Omaha
Joined Sep 2008
I'm going to put a 12X6 prop on it and try it out on the stock motor with the 30A esc,
Wish me luck.
skydve76 is online now Find More Posts by skydve76
robbyvaughn9 is offline
Find More Posts by robbyvaughn9
spartanburg, S.C. (US)
Joined Jul 2009
i new here & going 2 install a Scorpion 3014-1220 SII 640 Watt Brushless Motor to fly on 4s. can someone let me know how this is going to work ??/
tanks robby
robbyvaughn9 is offline Find More Posts by robbyvaughn9
Old Aug 26, 2009, 09:06 PM
Nickbm3 is offline
Find More Posts by Nickbm3
Joined Jun 2009
here ya go Olias-
http://cgi.ebay.com/Parkzone-T-28-Co...d=p3286.c0.m14
works pretty good, still uses stock motor mount, if your using the stock spinner you can use the spacers it comes with... i put on a great planes spinner, so i had to push my motor back and use 1/8th inch spacers instead of what the mount comes with.
Nickbm3 is offline Find More Posts by Nickbm3
Old Aug 26, 2009, 09:15 PM
Joined Jul 2009
what prop would be good ???
robby
Old Aug 26, 2009, 09:35 PM
Joined Jan 2009
tanks robby
I would say 4s is a little too much for that motor unless you plan on running 8" and lower props, 4S and a APC 9x6E will draw 48A and the motor is only rated for 46A download the scorp calc and or check out their prop charts
Mike.
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Alert Parkzone P 51 Mustang peiviper Electric Plane Talk 35 Sep 14, 2009 12:48 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
For Sale Parkzone P-51 Mustang argarre Aircraft - Electric - Airplanes (FS/W) 9 Sep 20, 2005 10:57 AM
Parkzone P-51 Mustang wattman Parkflyers 453 Feb 20, 2005 12:48 AM
