I think all of these except for the cooling air will be very similar to the F4U and T-28 |
Anyone else remember the double-nut that you had to put on the FW-190? Then again, these 1:1 scale shapes balanced because of the monstrous engines in the nose. I suppose we can't fault them for cheating with some nose weight. Anyway, I suspect that many competing in a speed contest will be looking into higher kv motors and therefore will have a different set of prop concerns. |
Does anyone know if I'm correct in that the mounting holes for the Park 480 and the Power 10 are exactly the same?
I have some E-Flite planes that call for the Park 480, but I opted for the Power 10 instead. If the stock motor on this Mustang is the same as the E-Flite Park 480, I might consider replacing it with a Power 10, new ESC, prop, lipo, etc which would have the potential to really scream! |
LOL!! Glassing would be interesting to try! But, if anything, I'll probably just add a little bit of carbon fiber on the wings and maybe tail. I'm just not ambitious enough to glass.
By the way, I'm definitely IN on the speed contest. Heck, maybe I'll epoxy a couple of EDF fans on the back end of this baby. LOL!!
Minneapolis
Joined May 2009
if the p51 doesnt have the same size thingy as the f4u, im assuming the motor shaft will be the same diameter, cause its the same motor, in which case i can switch out the spinner/prop thingy. |
Mike. |
The Mustang has the PARKZONE 480 motor in it - the same as the T-28 and the F4u. It is not the same as the Park 480. However, from past posts, I know that the Power 10 is a drop in replacement for the Parkzone 480, so you should be able to put a Power 10 in it no problem. |
See 2nd post in this thread.
http://www.rcgroups.com/forums/showt...9#post12536519 Matt Andren Hobbyzone/Parkzone product development Horizon Hobby |
97 MPH!!! SWEEEEEEEEET!!!! I'm all in. |
| Thread Tools | |
| Question Release date for the Parkzone P-51 Gunfighter? | ugly john | Electric Warbirds | 41 | Jun 27, 2009 02:51 PM |
| For Sale Parkzone P-51 3 flights--like new! | Artsloper | Aircraft - Electric - Airplanes (FS/W) | 2 | Oct 12, 2006 06:06 PM |
| Sold ParkZone P-51 Horz Tail Assebly - New | Spid | Aircraft - Electric - Miscellaneous (FS/W) | 1 | Aug 30, 2006 10:04 AM |
| Sold Like new Parkzone P-51 FS | ncrego | Aircraft - Electric - Airplanes (FS/W) | 8 | Apr 23, 2006 08:36 AM |
| New FMS Alpha8 ParkZone P-51 | ggunners | Simulators | 1 | Jun 02, 2005 10:10 PM |
