Old Jun 25, 2009, 07:28 AM
Magne is offline
Find More Posts by Magne
Moss, Norway
Joined Jul 2003
Motor for 22-24 lbs 3D/IMAC model
Hello.
I am looking for a suitable motor for a 3D/IMAC model weighing 22-24 lbs.
I run electric F3A, and therefore have a number of 10s5Ah packs which I want to use as 10s2p (10 Ah)
(This is also what is commonly used in the German F3A-X class, I believe.)
1. Will the 1527-series of motor be able to deliver up to 5kW+ short term?
(e.g. the 1527-1Y, effective kv=1250/6.7=186, or the 1527-2D, effektive kv=1150/6.7=172)
2. Alternatively, would a geared 2215 be suitable for 10s?
(2215-1Y, effective kv=1440/6.7=215 which is ok, but voltage limited to 30V, I assume 35-36V under load for a 10s pack. 2215-1.5Y, effective kv=1020/6.7=152, which may be fine for 12s packs, but probably too low for 10s.)
What do you recommend?
3. What is the current delivery time for these motors?
Kind regards,
Magne
(Norway)
Magne is offline Find More Posts by Magne
Old Jun 26, 2009, 10:25 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Originally Posted by Magne
Hello.
Kind regards,
Magne
(Norway)
For a light weight system I think the 1527 size would be the way to go. Production time is in the 3-4 week range now.
Steve Neu
sneu is offline Find More Posts by sneu
Old Jun 30, 2009, 09:38 AM
Magne is offline
Moss, Norway
Joined Jul 2003
Thank you.
On a slightly larger plane, can the Neu 2230-3Y (kv=240) be used directly without a gearbox?
(on 10s3p, total 15 Ah, estimated 7-8 kW peak)
Is the 8mm shaft going to be strong enough?
Is the 8mm prop adapter strong enough?
Regards,
Magne
geared motor for 22-26oz plane rycomm Power Systems 3 Nov 19, 2005 01:03 PM
WTB Brushless motor for u-can-do 3d ep eculuke Aircraft - Electric - Airplanes (FS/W) 0 Apr 30, 2005 08:24 PM
BL Motor for the HB Elite 3D Pro pequeajim Micro Helis 7 Nov 28, 2004 11:51 AM
what motor for 16 to 18oz 3D plane? boricua 007 Power Systems 13 Nov 13, 2003 10:55 AM
OK the mega 22/30/3s not available, which hacker for 22-24 cp1700s in a midi fan birdseed Electric Ducted Fan Jet Talk 3 Aug 27, 2002 11:38 AM
