Go Back   RC Groups > Vendors > Don's RC
This thread is privately moderated by turbored21, who may elect to delete unwanted replies.
Old Jun 24, 2009, 06:40 PM   #1
Equation for figuring the thrust tube on an edf?... FSA?!
Help Don!
Calling on the expert!
.. just as the title reads.. im building a kamdax mig15 into an Electric im using a hobby people F16 fan and housing.. i want to make a proper exit tube for it need to know what to measure and how to do the math to get the most out of this little bugger!
thanks in advance
turbored21 is offline Find More Posts by turbored21   Reply With Quote
Old Jun 25, 2009, 06:51 PM   #2
Wonderfully Wicked
Bronze Member
The Don's Avatar
I always us 80% of the fan sweep area (FSA). The fan sweep area is the doughnut shaped ring that the fan blades push air through. You need to measure the diameters on the fan you are using. The calculate the exit diameter is easy the simplest way to do is like this:
De= sqrt(.80) * sqrt(D*D - d*d)
De= diameter for 80% FSA
D= rotor diameter
d= diameter of rotor spinner/motor (depends on fan used)
.80 = 80% FSA
I will post a photo and do an example.
Don
The Don is offline Find More Posts by The Don   Reply With Quote
Old Jun 25, 2009, 11:50 PM   #3
hey don thanks alot!... that will be awesome i wanna get this figured out so i can get the most out of this little guy
Old Jun 26, 2009, 12:03 AM   #4
Wonderfully Wicked
Bronze Member
The Don's Avatar
Are you using the stock HP 3 blade fan/rotor?
Don
Old Jun 27, 2009, 01:54 AM   #5
yes don i will be
Old Jun 27, 2009, 08:59 PM   #6
Wonderfully Wicked
Bronze Member
The Don's Avatar
OK here we go.
D= rotor diameter
.80 = 80% FSA
Measuring the fan we get:
D= 56 mm
d= 24 mm
De= sqrt(.80) * sqrt(56*56 - 24*24)
De= .8944 * sqrt(3136-576)
De= .8944 * sqrt(2560)
De= .8944 * 50.596
De= 45.25mm = 1.78 "
  • Name: DSCF7177.JPG
  • Name: DSCF7178.JPG
Old Jun 27, 2009, 09:13 PM   #7
awesome don.. thanks!
Old Jul 14, 2009, 05:07 PM   #8
Dukester's Avatar
Here's a related question, does the exit have to be round? I know its probably the easiest to form, but could the duct exit be oval or some other shape without sacrificing too much performance?
Dukester is offline Find More Posts by Dukester   Reply With Quote
Old Jul 14, 2009, 05:12 PM   #9
Wonderfully Wicked
Bronze Member
The Don's Avatar
I have used slightly oval at times but round I believe is the best as it distributes the airflow evenly. The EDF F117 I had had long rectangular slots and it worked great but they also had a nice gradual transition from round to rectangle to reduce losses as much as possible.
Don
Discussion Learning on an EDF pearcem Electric Ducted Fan Jet Talk 6 Oct 10, 2008 11:32 PM
Discussion Questions on an EDF concept irish_lord99 The Builders Workshop 2 Jul 23, 2007 09:05 AM
Graupner Ultra 930-7 on an EDF, Overvoltage? Ron Cox Power Systems 1 Aug 26, 2004 05:22 PM
electrajet on an EDF-75? Demolisher Electric Ducted Fan Jet Talk 49 Aug 24, 2004 01:43 PM
Axis for Gyro on an Eco 8 Haro Electric Heli Talk 2 Oct 30, 2001 03:42 PM
Bored? Want to fight?
Join the RCGroups clan!
