Old Oct 13, 2012, 09:39 AM
Buffythesaint is online now
Find More Posts by Buffythesaint
Joined Feb 2005
I put some video gear on my Squall and had a couple of FPV flights. It was a blast to fly this way. I did my first FPV aerobatics
Phase3 Squall FPV (12 min 13 sec)
Buffythesaint is online now Find More Posts by Buffythesaint
Old Oct 13, 2012, 12:56 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
wild , what is the receiver screen in your setup , goggles?
chas650r is offline Find More Posts by chas650r
Old Oct 13, 2012, 02:25 PM
Joined Feb 2005
I use a 19" led TV powered from a power wheels 12v battery and inverter. It's all in a Pelican case for easy setup. The sun shield is just three pieces of foam board, interlocked together.
Old Oct 13, 2012, 09:21 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
cool, thanks , i dont know much re. fpv but it's intriguing . some guys i slope soar w/ use a goggle system , wild , cant imagine using something like that on a fast plane as it looks like orientation would be a problem . do u look directly at the plane much? and was that tree as close as it looked ?
chuck.
Old Oct 14, 2012, 08:48 AM
Joined Feb 2005
chuck.
I was alone, so I hand launch and then I sit down and fly from the monitor. I didn't look at the plane for the whole flights, all flying from the monitor. It's just like a flight sim.
Old Oct 14, 2012, 12:48 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Awesome vids - thanks for sharing. I've always dreamed of having an FPV setup - haven't pulled the trigger yet though. Could you give an estimate of how much that setup cost?
Thx,
Josh
Oh, almost forgot - that first batt looked like it got a bit beat up (10v at the end of the flight). Did it come down super puffy?
jgalexander is offline Find More Posts by jgalexander
Old Oct 14, 2012, 12:49 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
i noticed that also 2.5v / cell under load
Old Oct 14, 2012, 04:00 PM
Joined Feb 2005
Thx,
Josh
The bats are pooch. They are the ones for this EDF and have been sitting around , at half charge, for two years. I wasn't expecting much. I saw the voltage drop off right away on the first flight so to heck with landing, just run it down. The second bat was a bit better but they both are labelled NFG now and off to be re-cycled. I just ordered some new ones from HK.
My FPV gear, I've collected over the last 4 years. ReadymadeRC have rtf packages for fpv that are good. My Squall setup is a 400mw 1280 vtx-$40-$45, 5v ImmersionRC 922 camera-$75, TBS Core psu/osd(supplies 5v/12v for vtx, 5v/12v for camera and osd if you want to enable)-$79. For the ground station all you need is a vrx and google/monitor. This is just a basic setup. I have two vrxs and antennas, Oracle diversity controller(picks best video signal), DVR for recording and my monitor setup.
Old Oct 28, 2012, 12:32 AM
Joined Feb 2005
My new bats arrived and I was able to get two FPV flights tonight. This is a blast to fly FPV.
Phase 3 Squall FPV Aerobatics (5 min 53 sec)
Old Oct 28, 2012, 01:56 PM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Maiden
Nice Video,
Going to maiden with VT today. It'll be the first EDF I've flown with thrust vectoring. Kind of sucks that the stock unit is hard wired and can't put on a switch.
We'll See!.
2350kv 70MM 7 blade fan w/60A ESC & 14.8V 4s 2200mAh 65C LiPo.
P.S. If you look, you'll see the foam around the tail and a little of the wing is eaten up. CA kicker will do it
Kevin
kmdunnster is offline Find More Posts by kmdunnster
Old Oct 31, 2012, 02:36 PM
jredz71 is offline
Find More Posts by jredz71
jredz71's Avatar
United States, VA, Dublin
Joined Jul 2012
I want to go 140 MPH!
This is my Squall. What kind of speed can I expect with this setup on 4 cells?
The intake has been fiberglassed and the airframe has been covered in Ultracote.
Het 6904 Fan Unit
Castle Creations Phoenix Ice Lite 100 25V ESC
Velocity RC/EDF hobbies 4200kv
Features:
kv: 4200
No load current: 5A
Internal res: .013ohms
Max current: 100 (burst 120)
Max efficiency: 80%
Power: 1400w on 4s / 1800w on 5s
Diameter: 28mm
Length: 60mm
Weight: 140g (with 4 1/2 inch long wires)
Shaft Dia: 4.0mm
FlightPower LiPo Pro50 4S 14.8V 2550mAh 50C
jredz71 is offline Find More Posts by jredz71
Old Nov 01, 2012, 10:05 AM
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Maiden Thursday
I KNOW mine doesn't do 140, but I got it to checkout the Vectored Thrust. Pretty twitchy on the maiden flight in the video, so I changed the expo from 30% to 60%. That seemed to settle it down.
More to come...
Kevin
Squall Thrust Vectoring Maiden (2 min 0 sec)
Old Nov 01, 2012, 12:46 PM
jredz71 is offline
jredz71's Avatar
Joined Jul 2012
More to come...
Kevin
http://www.youtube.com/watch?v=yN_9c5oz8e0
kmdunnster, I said I wanted to do 140, if you can read? If you want to fly 3D you can buy one of these instead of using your squall....
Old Nov 01, 2012, 01:24 PM
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Originally Posted by jredz71 View Post
kmdunnster, I said I wanted to do 140, if you can read? ....
Whoa, what's up with your'e attitude. Did I offend you?
Kevin
Old Nov 01, 2012, 02:04 PM
jredz71 is offline
jredz71's Avatar
Joined Jul 2012
Kevin
You did get under my skin some. I'm not on here to poke fun of what someone is trying or accomplish.. Peace!!!
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
