Old Apr 16, 2012, 09:20 PM
AlvaSpeed is offline
Find More Posts by AlvaSpeed
Joined Oct 2009
I thought this plane was made out of EPO foam.
It is made of EPS which is to brittle for my taste.
I have a HK Mirage 4000 which now looks like a Frankestain airplane from all the glue used to repair all snall and big crashes.
My Stryker and Stinger 64 have taken similar abuse without the easy breakage.
I really like this plane.
Is there anything that can be done to make it stronger and preventing easy breakage.
Is there another plane similar to the Squall made of a stronger foam?
AlvaSpeed is offline Find More Posts by AlvaSpeed
Old Apr 16, 2012, 10:16 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
The plane is made of EPO not EPS. Earlier in the thread there are plenty of examples of how to reinforce the fuselage so it doesn't snap off the nose on a hard landing.
Below is one example of 3 CF tubes being added.
edit.... Material Is EPS not EPO, my error.
Prof100 is offline Find More Posts by Prof100
Old Apr 16, 2012, 10:22 PM
Joined Oct 2009
I was looking at the Hobby People site and the product description says EPS foam.
http://www.hobbypeople.net/index.php...motor-esc.html
Old Apr 16, 2012, 10:32 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
agreed , eps. if u want light and rigid eps is it! if u want it to bounce , this is not it.
chuck.
chas650r is offline Find More Posts by chas650r
Old Apr 17, 2012, 03:21 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Yea Professor, you gottem backwards. 2mm carbon in the leading edges and duct work are a must to make it last.
ApexAero is offline Find More Posts by ApexAero
Old Apr 17, 2012, 09:01 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I stand corrected. Brain failure,.
Old Apr 21, 2012, 04:43 PM
SLK Count is offline
Find More Posts by SLK Count
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
Originally Posted by Timewarp View Post
Well this past weekend I did run a nanotech 3s 2200 in my Squall HP without VT. It does work but you can tell she is underpowered. You need a long strait run to get up to speed once at speed you are okay but you definatley have to keep the speed up because the thrust is just not there.
At least now a I know it can be done and a 3S can be run in the 4S setup. woot woot!
Hi warp
pls stay 3S, let the Squall at home and test the parkzone Stryker--- this plane is faster and makes more fun ! Sorry to say this but I bought also a Squall 3S VT, was lucky with it up to the Stryker comes. The Stryker flies circles around the Squall and can more aerobatics in the air (Boomerang, Elevator etc.)
Now the Squall hang at the wall and has to stay at home
SLK Count is offline Find More Posts by SLK Count
Old Apr 23, 2012, 02:47 PM
kinghelichopter is offline
Find More Posts by kinghelichopter
unbreakable ? give it to me !
kinghelichopter's Avatar
Joined Oct 2010
well i was going to retire the squall its taken a bit of a bashing a few times this year
then i ordered one of these
http://www.pw-rc.com/product_info.ph...p92lcbfercohm0
and one of these
http://www.hobbyking.com/hobbyking/s...idProduct=8138
on 4s im getting 922watt with 67 amps
on 5s 1438watt and 88amps
my 5s batts have only a 20-30c rating so going to see what happens with them
my only concern is the lack of cooling to the motor as its the same length as the fan motor housing, so its not really going to get any air over to help cool it .
roll on the weekend
dave
kinghelichopter is offline Find More Posts by kinghelichopter
Old Apr 23, 2012, 07:00 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
well good luck! thats a great motor, but at 2.5 ounces, it sounds like u are asking a bit much! smoke on!
chuck.
Old Apr 28, 2012, 10:13 AM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Got a Stryker (and a UMX Stryker) and a FW F-16 with VT (and around 20 other models ). But you know what? I still miss my Squall!!!!
Such an awesome airframe and had a great presence.
Got a spare 70mm Wemo/HET setup in my parts bin at the moment........maybe its time for another Squall!!!
Goody63 is offline Find More Posts by Goody63
Old Apr 30, 2012, 01:56 AM
Joined Oct 2010
you know you need one lol , the weather here was rubbish again this weekend , so no flying at all ...
dave
Old Apr 30, 2012, 06:05 AM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
dave
That's a bummer.
Best time of the year here for flying (Autumn) but it'll start going downhill in the next month or so.
I think a mate (who has already built two but later sold) is about to commit to a airframe from Efly as well.
Old May 02, 2012, 12:56 PM
Joined Oct 2010
we have four models flying in our club , think they are addictive !! keep us posted about your progress .
dave (hoping for better weather soon )
Old May 07, 2012, 08:14 AM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
Squall Mk2
Well ordered my replacement Squall tonight (my first one flat spinned to death (here) a while ago ).
Anyway this new one is going to have the Morgan RC belly extension and reinforcements (ordered tonight as well).
One of my friends pointed out that with the Morgan RC extended belly; it should be able to penetrate the ground even further when I spin it to death!!!!
Anyway this one's also gonna have a 4S setup with a Wemo Fan and HET 2W20 (to help ground penetration ).
Can't wait to get back into some EDF flat spins and high alphas!!!
Old May 10, 2012, 02:37 PM
PaulDaniel is offline
Find More Posts by PaulDaniel
Joined Sep 2007
Help with launch
Hey guys, need some help. Today had a friend of mine hand launch my Squall. Had about 1/2 throttle. Nice even toss but it pitched straight up. Jumped on the elevator and thought maybe I could fly out of it but even then it pitched up. I have balanced it per instructions. What am I missing? To me it seems tail heavy. I have slight up on the elevons.
PaulDaniel is offline Find More Posts by PaulDaniel
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
