Old Jan 13, 2012, 10:17 AM
yucafrita is offline
Find More Posts by yucafrita
USA, FL, Doral
Joined Jul 2006
Thanks for the replies!
I'm going to build it stock 4s, but since I want to install the VT unit in the future, think Im going to get some metal gear servos...just in case.
yucafrita is offline Find More Posts by yucafrita
Old Feb 22, 2012, 04:40 PM
jimbogreek is offline
Find More Posts by jimbogreek
Certified Prop Nut
jimbogreek's Avatar
Charleston, SC
Joined Mar 2010
replacing the fan blade
message deleted by author
jimbogreek is offline Find More Posts by jimbogreek
Old Feb 23, 2012, 11:42 AM
BalsaBob is offline
Find More Posts by BalsaBob
Massachusetts
Joined Jan 2002
4s2650 ok ?
Hi Guys, Just starting my build. I happen to already have two (2) 4S 2650's ..... are they a good option ..... or is a smaller battery a better option ? Thanks. Bob
BalsaBob is offline Find More Posts by BalsaBob
Old Feb 23, 2012, 12:39 PM
retiredVTT is offline
Find More Posts by retiredVTT
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
..that's the size I run in my Squall. I'm using the setup from the Habu...Eflite BL15 Delta fan and motor. Works well, just watch the flight time and be ready to land after four minutes. 4S 3000's will allow another minute.
Bill
retiredVTT is offline Find More Posts by retiredVTT
Old Feb 23, 2012, 01:08 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
i like smaller w/ the stock set up but if u already have them, they will work.
chas650r is offline Find More Posts by chas650r
Old Feb 23, 2012, 01:09 PM
BalsaBob is offline
Massachusetts
Joined Jan 2002
Squall VT
I will be utilizing the VT in my Squall. Is flying a plane like this where the VT is engaged/enabled at all times much different thana setup where the VT nozzle can be turned on/off by a switch ..... as needed/wanted ? Thanks. Bob
Old Feb 26, 2012, 07:48 PM
menksters is offline
Find More Posts by menksters
United States, TX, Montgomery
Joined Aug 2006
wow!?
Over 300 pages here so could someone please let me know what the speed is of this model using stock setup? Thanks, donnie
menksters is offline Find More Posts by menksters
Old Feb 26, 2012, 11:13 PM
cleatis is offline
Find More Posts by cleatis
willfly4$
cleatis's Avatar
United States, MS, Bay St Louis
Joined Apr 2005
Really slow.
Lol, just kidding, I didn't Doppler mine stock but then again I did have a 3300 4 cell in it and it was really struggling to fly with the stock power system.
cleatis is offline Find More Posts by cleatis
Old Feb 27, 2012, 04:59 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Here's some inspiration!
1_30.wmv (0 min 4 sec)
ApexAero is offline Find More Posts by ApexAero
Old Feb 28, 2012, 09:02 PM
le fou is offline
Find More Posts by le fou
United States, OH, Cuyahoga Falls
Joined Apr 2006
hello everybody,
I am putting my squall together, stock 4 cells. Did you change the tape hinge on the rudder and ailerons? Did you use CA hinges instead?
thanks,
Le fou
le fou is offline Find More Posts by le fou
Old Feb 28, 2012, 11:21 PM
Joined Apr 2002
Originally Posted by le fou View Post
hello everybody,
thanks,
Le fou
...Yes on the ailerons...and will do the rudder before flying this year, as it's showing signs of becoming loose with just the tape.
I still use tape OVER the installed ca hinges, (I believe I epoxied them in), to close any gap.
Bill
Old Mar 09, 2012, 10:12 PM
NDS777 is offline
Find More Posts by NDS777
USA, AZ, Chandler
Joined Oct 2010
I've been reading thru this massive thread and it seems the nose tends to break off on landing. Where does it snap? Would cutting it off and making it magnetically attached, like on a Stryker q, be beneficial?
NDS777 is offline Find More Posts by NDS777
Old Mar 09, 2012, 10:21 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
No, just reinforce with some CF tubes.
Prof100 is offline Find More Posts by Prof100
Old Mar 10, 2012, 07:32 AM
Timewarp is offline
Find More Posts by Timewarp
Life is simple Eat, Sleep, Fly
Timewarp's Avatar
Germany, RP, Kaiserslautern
Joined Oct 2011
Squall Rocking in flight.
Hi.
I have my throws set like the book recommends for sport flight, using a 20% EXPO and I have the plane balanced at the recommended CG and I have the vectored thrust unit installed, now for the life of me I can not figure out why the plane likes to rock side to side while in flight. All control surfaces are aligned ect. does anyone have any tips or recommendations?
Timewarp is offline Find More Posts by Timewarp
Old Mar 10, 2012, 12:55 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
does it do this in dead calm conditions? 20% is not much expo for something as roll sensitive as this . we use 40-60 % depending on travel . of coarse if it does this w/ no control input in dead calm , expo has nothing to do w/ it. possible lose linkages?
chuck.
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
