Old Dec 21, 2011, 10:15 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Originally Posted by ApexAero View Post
http://www.hobbypeople.net/index.php...ne-covers.html
http://www.hobbypeople.net/index.php...et-squall.html
They're there, you just have to be patient and search dude!
No plastic canopy right now BTW.
Thanks but they actyally pulled the listing for the plastic parts so not much hope there.
MRGTX is offline Find More Posts by MRGTX
Old Dec 21, 2011, 02:42 PM
kinghelichopter is offline
Find More Posts by kinghelichopter
unbreakable ? give it to me !
kinghelichopter's Avatar
Joined Oct 2010
Originally Posted by lowkeylaidback View Post
Picked up a unit on Black friday, after reading more of this thread I see there were problems with the stock fan, is this still an issue, thanks.
a mate of mine flies the stock 4s version , im impressed with both the performance and the flight times , he gets almost a minute more than my het set up using the same batteries , so okl the hett is a little faster and vertical performance is better but the flight times suffer
dave
kinghelichopter is offline Find More Posts by kinghelichopter
Old Jan 03, 2012, 09:15 AM
choopi is offline
Find More Posts by choopi
choopi's Avatar
New Brunswick
Joined Feb 2006
Originally Posted by MRGTX View Post
I am trying to find a shipping estimate to the United States of A...but they want me to register before I can even add it to my cart?
EDIT:
OK... made up a bunch of fake info so I could register...
Kit: $56 USD! Not bad..
EMS Shipping $53 USD. They're joking, right?
Are you serious?
... Yep you were serious! Outrageous!
choopi is offline Find More Posts by choopi
Old Jan 03, 2012, 11:26 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
EDIT:
That is what it costs to send a big box across the globe with Express mail
MegaTesla is offline Find More Posts by MegaTesla
Old Jan 04, 2012, 03:23 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I haven't modified mine. It is a stock 3 cell lipo powered version, but I did get the vector thrust unit to stick on the back. It flies great. But with three cells if you get it into a high alpha slow speed mode, it doesn't have enough power to pull out of it. Thus if you are too close to the ground, you wind up making a controlled landing like that as you can't get the nose down to fly out of it. But it sure does a wicked buzz saw like effect for the roll rate. Too fast to count.
earlwb is offline Find More Posts by earlwb
Old Jan 06, 2012, 06:50 AM
Joined Oct 2010
sorry its taken so long to get the photos of my scoop up apex but here they are ,i think there is around 150mm extra length on the scoop , its angled up to make a better skid for landings , the inlet is 100mmx 30mm wide
Old Jan 06, 2012, 07:34 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Yea man, the lower profile should give better aerodynamics! Did you run a thrust tube?
I'm jealous of your checkering ability!
Tom
ApexAero is offline Find More Posts by ApexAero
Old Jan 06, 2012, 12:28 PM
PaulDaniel is offline
Find More Posts by PaulDaniel
Joined Sep 2007
Squall
Since we're doing show and tell here, I thought I'd share some pictures of my nearly completed Squall. Stock set up but I decided to go a different route in the color. Blue paint is Cyrlon H2O and the graphics just vinyl. From what I've read the bottoms can get beat up so I added some plastic toward the front of the inlet and did some beefing up a bit inside but now enough to disrupt the airflow. I might end up putting a bit more on the bottom. Also thinking a using a control horn on the nose. Thoughts?
PaulDaniel is offline Find More Posts by PaulDaniel
Old Jan 06, 2012, 02:00 PM
Joined Oct 2010
now that does look nice
the scoop tends to catch if your landing on grass , one of the guys at the club has a carbon rod that runs from the lip of the scoop to just behind the nose it acts a little like a skid it helps but not completely stops the scoop from digging in , if your running the 4s set up bring your cog a little forward than the book says . and be careful if there is little wind as they land fast ..lol...
dave
Old Jan 06, 2012, 02:06 PM
Joined Oct 2010
apex , no thrust tube just yet , its on my list to do !
the checkers are done by a friend of mine , cut from vinyl
dave
Old Jan 06, 2012, 05:19 PM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
On top, but you painted the bottom didn't you?
P.D. nice blue hue! If you're light weight its easy enough to swoop in at low speed then nose up and let the butt touch first with the throttle. Don't try to skid it in on grass or you'll go home in a few pieces. Me? I lay on a sheet of cling wrap then layup a couple layers of carbon cloth, let set, pop off and trim to shape with siczors and glue on with RTV to the bottom for a skid pad on black top. (most of the time)
Old Jan 08, 2012, 08:57 AM
Joined Oct 2010
i wish i could paint the checkers but the ones on the bottom are the vinyl ones , the top are made from plumbers aluminium tape
dave
Old Jan 09, 2012, 12:35 PM
yucafrita is offline
Find More Posts by yucafrita
USA, FL, Doral
Joined Jul 2006
VT or not VT?
I just got a Squall on sale and I wonder If I should build it with the VT or without...a friend who had one one told that after installing the VT the plane
was way slower.....
Opinions?
yucafrita is offline Find More Posts by yucafrita
Old Jan 09, 2012, 01:19 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
do u want speed or aerobatics? is yours 4cell? imo tv is no good on the 3's version . and it does cut down thrust and speed.
chuck.
chas650r is offline Find More Posts by chas650r
Old Jan 09, 2012, 01:22 PM
chas650r is offline
chuck
santa barbara, CA
Joined May 2009
apex, what are u using for the resin in the c/f layup?
chuck.
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
