Old Nov 03, 2011, 02:59 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
agreed, 80-90 . ~90 w/ a good 40c.
chas650r is offline Find More Posts by chas650r
Old Nov 10, 2011, 12:57 PM
kinghelichopter is offline
Find More Posts by kinghelichopter
unbreakable ? give it to me !
kinghelichopter's Avatar
Joined Oct 2010
number two ready for the maiden flight
the set up is HET 6904 fan unit , with typhoon 2w-20 motor , turnigy 3000mAh 35c batteries
kinghelichopter is offline Find More Posts by kinghelichopter
Old Nov 10, 2011, 04:17 PM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
I had to put on my sun glasses too! WoW thats bright! Did you ad a thrust tube or leave it stock?
ApexAero is online now Find More Posts by ApexAero
Old Nov 14, 2011, 01:32 PM
Joined Oct 2010
its just stock for now , had one of the blades come off the fan on the third flight , not sure just what happened the whole of the impeller was off the motor and one blade had gone so dont know what went first the blade of the impeller came off the motor shaft .
new one ordered had to order a whole new fan unit as i cant find anywhere to order just the impeller over here in the UK
dave
Old Nov 14, 2011, 10:27 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Yup thats a bummer, been there too! You gotta crank the snot out of the Het collets.
Sometimes I wipe locktite on the fingers of the collet
Old Nov 15, 2011, 01:48 AM
Joined Oct 2010
thanks for the tip , ill give it a go on the new one
dave
Old Nov 26, 2011, 04:24 PM
Joined Oct 2010
the spot landing winner !!!
Old Nov 27, 2011, 01:30 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Success I take it? Nice scoop extention!
Old Dec 02, 2011, 08:16 AM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
New to this model
Picked one up from Hobby People, the 4s version for 69.00 on the Black friday sale.
I have a couple of questions before I build it, first the fan and motor
I want to use this fan;
Change Sun 10 blade 70mm
http://www.pw-rc.com/product_info.ph...oducts_id/2481
with either this motor
Dynam Meteor motor
http://www.nitroplanes.com/60p-014-bm2826-kv3000.html
I have two of these
or this motor
Sapac 2842d 4s motor 3200kv
I have one of these
and these servos
9G EXI Digital Metal Gear Servo D213F
http://www.hobbypartz.com/9gexidimeges.html
oh yeah 120 amp esc
Sky Lipo 4s 40c 3000mAh batteries
I will be coating most of the plane with Finishing epoxy, using 1 dram epoxy with 1 dram of hardener mixed with 1/2 dram of 91% alcohol to thin is out a little and help it lay down smoother. This I have tried before and like the results.
Please give me your thoughts.
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Dec 02, 2011, 02:52 PM
Joined Oct 2010
sorry cant help you with your fan choice or motor as i dont know them ,
just make sure you beef up the inlet scoop a bit as they take quite a bashing on landing.
apex , my scoop was copied from either a post on this thread or on the speed thread some one posted ! works a treat landings are so much better the plane just slides in nice !
the lawn dart was my fault i set the battery in the wrong position and cog was to far back , flew a lovely loop on launch lol
dave
Old Dec 02, 2011, 03:38 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
WBPU works about the same only no mess and water clean up! Plus I like to lightly sand off the mould flowers and fill voids after the first coat. Two coats overall with a foam brush makes a nice sub finish for color. Carbon rods down the belly are a must.
Think about that 3000 kv motor I've been reading the CS 10 blade does better on slightly lower Kv on 4s, good C' rating helps also
King I see you got the scoop!
Old Dec 02, 2011, 03:57 PM
Joined Oct 2010
the scoop is totally cool
i used .6 oz glass cloth and wbpu on mine with a carbon rod under the nose , its well worth the time for the extra strength it gives the airframe
dave
Old Dec 02, 2011, 04:44 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
I'm guessing you added about 10cm for the extention?
Old Dec 03, 2011, 03:15 PM
Joined Oct 2010
yes it must be around that , i'll get some photos and post them up
dave
Old Dec 13, 2011, 10:28 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Guys...does anyone other than Hobby People sell this aircraft?
They don't seem to offer an air-frame only and the kit with motor/fan/esc is too much $ considering I want to run a custom power system.
MRGTX is offline Find More Posts by MRGTX
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
