Old Jul 09, 2011, 12:09 PM
gapple12 is offline
Find More Posts by gapple12
gapple12's Avatar
Joined May 2009
Originally Posted by ApexAero View Post
I'm thinking another Speed Squall. Presently the open exhaust has well over 200mph efflux so when it gets squeezed to 50-53mm opening it ought to be close to ?
Sounds awesome.
gapple12 is offline Find More Posts by gapple12
Old Jul 09, 2011, 04:30 PM
Robert Stinson is online now
Find More Posts by Robert Stinson
Ahhgh! Not ANOTHER new plane!
Robert Stinson's Avatar
San Diego, CA
Joined Dec 2001
another color scheme
Put mine together this week, painted it, flew it twice...cool! Pure stock with a 4S 2200mah 35C Hyperion pack. In-flight pictures in a while.
Robert Stinson is online now Find More Posts by Robert Stinson
Old Jul 10, 2011, 10:12 PM
obrieri is offline
Find More Posts by obrieri
Riley O'Brien
obrieri's Avatar
Waverly, NE
Joined Jul 2008
Does anyone have programming instructions for the esc that comes with the hp squall? A dozen or so local guys got these and one of the escs doesn't work with 4s(motor just makes a clicking sound) but works with 3s. If the esc can be programmer to fix it that would be very helpful. If not we have to cut the belly off and replace the esc.
obrieri is offline Find More Posts by obrieri
Old Jul 10, 2011, 10:41 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
That's probably because the Squall was the 3S version.
Prof100 is offline Find More Posts by Prof100
Old Jul 10, 2011, 10:43 PM
chas650r is offline
Find More Posts by chas650r
chuck
santa barbara, CA
Joined May 2009
well i cant help u but the c/s dept at hobby people are some of the best i have ever dealt with , i would try them.
chas650r is offline Find More Posts by chas650r
Old Jul 10, 2011, 10:52 PM
obrieri is offline
Riley O'Brien
obrieri's Avatar
Waverly, NE
Joined Jul 2008
They are all the hp version. Says so on the esc also. Seems like the timing is wrong.
Old Jul 10, 2011, 10:54 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Sounds like it's time to call Hobby People.
Old Jul 10, 2011, 11:06 PM
obrieri is offline
Riley O'Brien
obrieri's Avatar
Waverly, NE
Joined Jul 2008
I gave him an extra esc I had. He'll call them about it...just thought maybe there would be a timing setting in the esc.
Old Jul 10, 2011, 11:26 PM
jhanda is offline
Find More Posts by jhanda
Lincoln, NE
Joined Oct 2003
It goes into programming mode if I power it up with the stick at full throttle but no idea what the beeps mean. It would be sweet if I could find a way to fix this without having to tear into my bellypan. Any idea if the phase 3 esc is a rebranded something else or do they make their own?
jhanda is offline Find More Posts by jhanda
Old Jul 13, 2011, 10:09 PM
gapple12 is offline
gapple12's Avatar
Joined May 2009
Alright, been flying the snot out of my stock Squall and want some more speed. Is there a direct motor replacement that will bolt to the stock fan that will give me more power? I made the mistake of gluing my fan in real good. I also want to stick with the G4 4cell packs I have now. Any ideas?
Old Jul 14, 2011, 12:16 AM
topher is offline
Find More Posts by topher
denver colorado
Joined Jan 2004
The het 2w20 is an awsome motor. I ran it in the stock fan for quite a while. Eventually though I upgraded to the het 6904 fan wich makes more power and the sweetest jet sound ever!
topher is offline Find More Posts by topher
Old Jul 14, 2011, 09:25 AM
gapple12 is offline
gapple12's Avatar
Joined May 2009
Ok, I will look into that motor. Is there a different adapter I need when changing motors but keeping the same fan? Thanks for your help.....
Old Jul 14, 2011, 10:21 AM
gapple12 is offline
gapple12's Avatar
Joined May 2009
Well, I'm thinking I need to find a way to replace the fan as well. I'm sure I can get it out, so I'm going to upgrade the fan and motor. I'm thinking the Typhoon EDF-2W-20 700W motor and either the HET unit 6904 or WeMoTec 480 mini fan. Will the 70mm fit well since the old was a 64mm fan? I will need to upgrade the ESC as well, thinking a Turnigy plush 60 or 80 ?
Old Jul 14, 2011, 12:07 PM
gapple12 is offline
gapple12's Avatar
Joined May 2009
OK, found a combo deal. What you guys think?
http://www.ejf.com/index.php?main_pa...ce57e28bd4d222
Will the 70mm fit fine or will I have to mod it ?
Old Jul 14, 2011, 02:04 PM
topher is offline
denver colorado
Joined Jan 2004
Thats a great setup. Pulls about 50 amps so that esc will handle it no problem. You will have to do a little sanding to fit the fan but its no big deal. The fan comes with a detachable inlet ring. I didn,t use the ring so not too much sanding to fit the unit. My squall does about 110-115 mph with this setup. 4 minutes WOT with a gens ace 4s 3300. You will love it!
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 08:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 01:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 10:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 07:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 04:23 PM
