Old Oct 02, 2010, 03:59 PM
designer,builder,flyer
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
2 to 2.5lb depending on battery. One six right's rat rod is about 3+lb on 7s
My #1 green lantern used a vt, het 6904/85amp esc and 3000 4s was glassed with wbpu and rustolium right at 2+ lb flew well till Rx probs.
ApexAero is offline Find More Posts by ApexAero
Old Oct 02, 2010, 05:19 PM
Uh Oh......
Moleman rc's Avatar
United Kingdom, Peterborough
Joined Sep 2008
Thanks for the quick reply i think i'm going to be looking at around about the same weight possiby a bit less. Using a 252gram lipo HET 6904 fan unit and 1w30 motor
Moleman rc is offline Find More Posts by Moleman rc
Old Oct 02, 2010, 06:21 PM
oldpilot's Avatar
Australia, NSW, Katoomba
Joined May 2002
Originally Posted by MADISONMaster View Post
TMF Delta (squall) vidéo
(freewing 70mm B2839 3000Kv - 4S/2200 30C TGY)
Battery management with QUANUM telemetry (1870mAh used for this flight (85%) for the first and 1750mAh for the second)
http://www.youtube.com/watch?v=Mlk_iZgBihk
http://www.youtube.com/watch?v=3f6vRLl0hIw
MADISONMaster
Your 90deg out of phase vids gave me a crick in the neck.
In the words of the old Andrews sisters song "Straighten up and fly right".
oldpilot is offline Find More Posts by oldpilot
Old Oct 02, 2010, 08:54 PM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
TMF Delta (squall) vidéo (5 min 12 sec)
TMF Delta (squall) vidéo 2 (4 min 44 sec)
MADISONMaster
Nice but run the raw video through Windows Moviemaker and rotate it 90 degrees.
Prof100 is offline Find More Posts by Prof100
Old Oct 03, 2010, 03:03 AM
MADISONMaster's Avatar
France, Bourgogne, Saint-Usage
Joined Jun 2010
Yes I have progress to make the videos - I'll fix that
http://www.youtube.com/v/Q2EVrZJZAoI...olor2=0x6b8ab6
TMF DELTA 3 (4 min 58 sec)
Exuse me for the evils of head
MADISONMaster
MADISONMaster is offline Find More Posts by MADISONMaster
Old Oct 03, 2010, 08:10 AM
Prof100's Avatar
Joined Jul 2007
Very good. My neck feels better already.
Old Oct 04, 2010, 06:45 PM
fly the pants off it!
lando211's Avatar
Joined Jan 2009
hey guys just got me a squall 4cell on order and just wanted to dive in to the thread. I just wanted to ask a few questions that I am sure have been answered a few times already. So did they fix the problem with the fan units that would explode in a dive? and last any mods I should do during the build? I will be running stock. Thanks
lando211 is offline Find More Posts by lando211
Old Oct 04, 2010, 10:26 PM
Eagan, MN
Joined Sep 2010
I run clear packing tape along all the leading edges, as well as the bottom belly pan / intake. There is a fiberglass replacement belly pan that is openable which would be nice. However if this is your first one I wouldn't put that much money or work into it.
Reinforce the front base of the bellypan with something strong. I used some modelling plywood. While ugly it is very effective.
Start with CG at least 5mm forward of their suggested CG. Have someone else throw it for you that knows how to throw. Roll is incredibly sensitive!
I am running at minimum control surfaces and still 30% travel on my dual rates!
When landing keep pulling back on the elevator so that it lands at the slowest possible speed. You should be in a fairly high alpha when it finally lays down in the grass. It takes a lot to stall this plane. You can build up a wire nose-wheel skid if you like. When the belly touches down it causes the nose to lawn-dart into the ground. If you provide a 1.5" skid it will allow the plane to slide a little without digging in.
bastian74 is offline Find More Posts by bastian74
Old Oct 04, 2010, 11:37 PM
giddyuperic's Avatar
USA, CA, Riverside
Hello Guys and Gals I have a brand NIB squall just sitting here. I would like to trade it for the F-16 NIB each person pays their own shipping fair? I can send phots if you like. Thank you for your time Eric so cal
giddyuperic is offline Find More Posts by giddyuperic
Old Oct 04, 2010, 11:48 PM
ApexAero's Avatar
Joined Aug 2008
A 252g batt? Two things with that motor, you better have a 125 esc and you better have at minimum a 30C pack of at least 3300 for 3.5min of flight. A batt that weighs 252g would last 25 sec with that motor. I have one nib if anyone wants it.
Old Oct 05, 2010, 05:48 PM
USA, FL, Doral
Joined Jul 2006
Can you please clarify your dual rates?
are running 70% of 100% or 30% of 100% on aileron rates?
yucafrita is offline Find More Posts by yucafrita
Old Oct 05, 2010, 08:36 PM
Eagan, MN
Joined Sep 2010
Well I would certainly start out at the suggested values. Mine was nowhere near trim at first, if I had small throws I probably couldn't have even flown straight. So I mechanically trimmed it, then threw it again, trimmed it, then lowered my rates to suit me. It does not take a lot once it's trimmed out.
Old Oct 05, 2010, 11:09 PM
Master of Nothing!!!
ginsu1797's Avatar
Orange county
Joined Nov 2002
I think he meant 30% expo on low rates?
ginsu1797 is offline Find More Posts by ginsu1797
Old Oct 06, 2010, 02:42 AM
Paris - France
Joined Jul 2008
I think that for Take Off you need normal rate because speed is low and flight controls are not very effective: there is no propeller blowing them.
Then you can select dual rate, once you got some speed.
Gildas is offline Find More Posts by Gildas
Old Oct 08, 2010, 01:46 PM
Will fly for food
Maryland
Joined Sep 2004
BTW the 4S version is on sale this weekend for $99.99.
Pinecone is offline Find More Posts by Pinecone
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
