Old Aug 16, 2010, 05:06 PM
tbird911 is offline
Find More Posts by tbird911
I added lift to my stable!
tbird911's Avatar
Knoxville, TN
Joined Feb 2007
Starting the build with a couple of questions . . .
Hi Guys,
Here's the plan:
1. 3S version bought- pulling out the "guts" and adding some aftermarket stuff
2. Adding Full BellyPan, extension, esc fairing from Gary
3. Adding 1/2a control dubro horns and 2mm threaded rods and metal clevis(s)
4. Added HET 2904 w/ 2W-20 motor
5. Added HET 75A ESC
6. Adding emax digital MG servos
7. Adding 3.2mm cf rods running from battery try to nose and up each delta wing from aft to front.
8. Using 4S3000mah 35c or 4S2650 mah 40c batteries
Look ok? Thought about just brusing on some West Systems Resin straight to the foam without the cloth? Need to program the HET 75A for any special setup? Any last minute tips or suggestions?
Thanks all,
I'll try and document as I go . .
Tbird911
tbird911 is offline Find More Posts by tbird911
Old Aug 16, 2010, 07:18 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Maybe lightly sand and fill the mating surfaces and use an old credit card to spread the epoxy like a squeegee, use a folded paper tower and carefully blend the stroke marks. Better yet ad bubbs to the epoxy. Micro balloons @ 50/50 per volume would require some finish sanding but be really nice.
ApexAero is offline Find More Posts by ApexAero
Old Aug 16, 2010, 07:29 PM
tbird911 is offline
tbird911's Avatar
Knoxville, TN
Joined Feb 2007
Sounds good . . .
I think when you say epoxy, in my case we're talking about the West Systems 105 resin. I assume that adding the bubs adds volume when the material sets up and then it can be sanded down and used to shape, even out and contour where the surfaces have dents, pits or join. Right?
So, now that we have the "top coat", what adhesive works best for actually building the plane, joing the wings etc? I always wondered what the best solution is for applying 5-7 minute epoxy to the pieces (wings in this case) that are being joined. Once you mixe the two solutions together and stir, are you guys using some sort of swabs or brushes or? to distribute the stuff to the two joing pieces? How does Gorilla Glue stack up against the competition in being used for joining the wings versus regular 5-7 mintue epoxy?
Old Aug 17, 2010, 12:25 AM
oldpilot is offline
Find More Posts by oldpilot
oldpilot's Avatar
Australia, NSW, Mona Vale
Joined May 2002
Don't use West System Epoxy straight onto the foam.
It's like coating ice cream with that liquid chocolate stuff. A good blow on the surface and it will dent and flake. Besides it's heavy.
.5oz glasscloth set in WBPU is much more protective, is lighter and can be lightly sanded to a super finish which can be painted without any primer coat.
I speak from experience. (Don't ask me how I know)
Paddy.
oldpilot is offline Find More Posts by oldpilot
Old Aug 17, 2010, 07:32 AM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Haven't taken the time to experiment with the GG. Go with what you got if you don't want to spend more. The bubbs and poxy will glue your wings well. Use a .10 cent flux brush from soldering supplies to brush the stuff lightly on both surfaces, all the corners etc. Line up the bottom edges perfict and masking tape in position, wipe off the ooze with a paper towel and alchohol and wait an hour. If you go with wpbu to finish use a foam brush, clean up with water. Don't worry about what you finish with as it will all crack eventually when applied to foam. Try to get some carbon rod for fuse and wing spars. This time around I simply brushed on wpbu sanded tween coats for a tougher finish. The only glassing done is on the tunnel for the dreaded landing flop.
Just remember it your plane, you can finish it any way you want, it just hurts more when It's number is up. (ask me how I know) My suggestion is simply, build it, fly it, and if you like how it performs then imediately order another one and start building a back up.
Old Aug 17, 2010, 10:21 AM
tbird911 is offline
tbird911's Avatar
Knoxville, TN
Joined Feb 2007
Thanks for the great info . . .
What is the easiest way for me to determine where to place the fan unit? I am planning on using either 4s2650 or 4S3600 batteries and have the aftermarket stuff listed above.
Old Aug 18, 2010, 08:19 AM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Do a dry fit and check the balance. The cockpit is fairly long allowing to adjust the batt position.
Old Aug 18, 2010, 07:13 PM
Gildas is offline
Find More Posts by Gildas
Paris - France
Joined Jul 2008
Hello Guys
This plane seems great. It should fly well with the 2w20 I got in my Twister. I think I am going to take the electronics from my Twister to put in the Squall.
I am wondering if this one is the real one from RipMax
Prices seems very low!
http://shop.eflypower.com/shop/views.asp?hw_id=1985
I know it comes only with TV and EDF, but it's cheap.
I am not sure it comes with all the linkages......
What do you think ?
Gildas is offline Find More Posts by Gildas
Old Aug 23, 2010, 02:21 PM
relaxr is offline
Find More Posts by relaxr
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Hi Squallers! Yes after my last flight with my old Squall! on HET2W/6904 (-> I should have pulled earlier . . .) I could not resist, I grabbed 4 weeks later, last saturday a new one. Now a 4s HP with the TV-unit, on 4s 2600 40C hiQ lipos. The upper side is sprayed, the inlet is glassed with mats and PU-coating (the same as WBPU) and afterwards all was painted 3 times with PU-coat. All stock equipment. 780gr AUW. I am happy to maiden it next weekend. Only some CG adjustments and the ride can start Thats after the phase 3 EF 16 the best easy jet foamie - I love those
markus
relaxr is offline Find More Posts by relaxr
Old Aug 23, 2010, 06:11 PM
tbird911 is offline
tbird911's Avatar
Knoxville, TN
Joined Feb 2007
markus
I'm sorry, I didnt understand your post . . .I know you got a new plane , but are you saying the HET 2W/6904 is no good?
Old Aug 23, 2010, 09:05 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I think what he's saying it's a pretty good plane when built to stock specifications.
Prof100 is offline Find More Posts by Prof100
Old Aug 23, 2010, 09:40 PM
tbird911 is offline
tbird911's Avatar
Knoxville, TN
Joined Feb 2007
uh . .oh . .ok . ..
I got that motor and fan waiting to go into a Squal 3S and wondered if he was unhappy. Seems like most people love that combo.
Tbird
Old Aug 23, 2010, 09:42 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Tbird
Tbird-
Your combo is fine. We will have to wait for him to explain what he meant.
Bill
Old Aug 23, 2010, 10:33 PM
retiredVTT is offline
Find More Posts by retiredVTT
Canada's East Coast, "An Ocean Playground"
Joined Apr 2002
.."I should have pulled earlier" ...sounds to me like he did not complete the bottom part of a loop...or something similar..aka..he crashed..!
Bill
retiredVTT is offline Find More Posts by retiredVTT
Old Aug 24, 2010, 01:44 AM
relaxr is offline
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Oh sorry - my message was another. My HET 2W Squall! was fine. The prob is that she "was fine", as I crashed it. From the crash the lipo died and the motor also - never had something like this. Now I built a stock HP Squall! because I have not enough time for a modded one . . . and want to fly immediately.
But as I checked the crashed HET-version I saw that the high Amperes of the 2W (60A) showed some effects. the solder points of the motor wires looked a bit toasted and the area where those passed the fuse showed some melted foam. I think a 2W-20 on 4s with some lower Amperes could be the better way to go.
But now I have to check my new one. What would you speculate the 4s HP to perform in comparison to my old HET 2W driven? Will the speed be significant lower. From calculating it the HET had around 720 W (12Vx60A) - the stock 4s HP should reach around 670W (16Vx42A). The TV unit may waste some watts I believe.
Ah the "I should have pulled earlier" was a (to low) dive, where I didnt manage to pull her up. It crashed on the belly/inlet (another 2 meters and I had rescued it...) , the ESC shot through the plane and the motor was damaged from the impact. A friend said "yes - yes those jets dont get to old".
markus
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 08:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 01:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 10:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 07:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 04:23 PM
