Old May 26, 2010, 01:44 PM
relaxr is online now
Find More Posts by relaxr
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Finally - I managed to make a video of my HET-Squall! The crushing sound of the winds prevents a doppler, Bummer. But thats some speed
http://www.rcgroups.com/forums/showt...5#post15177356
Enjoy
markus
relaxr is online now Find More Posts by relaxr
Old Jun 09, 2010, 11:17 PM
icy_wind500 is offline
Find More Posts by icy_wind500
icy_wind500's Avatar
Camperdown, Sydney
Joined May 2009
Mine is finally done ! Painted and glassed, it's very heavy at 28.7oz with a 4s pack, it's seem really hard to balance on the CG I got it on 60mm as suggested in the manual. Will have photos coming up soon!
icy_wind500 is offline Find More Posts by icy_wind500
Old Jun 10, 2010, 06:23 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
28.7oz
Thats still pretty light at just under 2# The 60mm is good for a start with a stock frame but you may need to go more nose weight for the maiden by a few mm.
ApexAero is offline Find More Posts by ApexAero
Old Jun 10, 2010, 07:36 AM
Camperdown, Sydney
Joined May 2009
I had my first flight today ! It wasnt as fast as the F-16 (I've used the electronics off my crashed F-16) but the roll rate is scary...it rolls like a drill...and I'm only using 50% dual rate.
One problem I have while doing the glassing is that the glass dont like to go around corners, I get a few air bubbles trapped at the wingtip
nevertheless its one the best jet I've ever flown
Old Jun 10, 2010, 05:45 PM
DiabloKid is offline
Find More Posts by DiabloKid
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
hey Squallers!
I am using a Hoffman motor in a 6904 and I notice when I spin the motor by hand I get some resistance when it reaches a certain point. Is this normal? Or do I have a bum motor. Nothing appears to be touching as far as the fan in the shroud
DiabloKid is offline Find More Posts by DiabloKid
Old Jun 10, 2010, 06:10 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Originally Posted by DiabloKid View Post
hey Squallers!
Check the end of the motor and see if the wire is discolored. Also do you have the right programming on the esc?
Pete
hole digger is offline Find More Posts by hole digger
Old Jun 10, 2010, 08:11 PM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
Pete
Pete
this is a NIB motor that I just mounted and have not even soldered the bullet connectors too!
Old Jun 10, 2010, 08:31 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Any debris inside the can it may have picked up off the bench DK ?
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 10, 2010, 09:32 PM
hole digger
Joined Aug 2002
If it is new it can't be burned. Check the inside as best you can to see if the magnets picked anything up.
Old Jun 10, 2010, 10:16 PM
daneflyer is offline
Find More Posts by daneflyer
daneflyer's Avatar
United States, CO, Centennial
Joined Jan 2010
Hi hole digger,
I like your avatar! Is that the hobby lobby F4d? Can't wait to get back home and finish putting together my second ford. (a dead elevon servo put an end to the first) I ordered a Don's wicked motor 4800Kv and the EDO fan to put in this one. My son has one too and I really enjoy flying together. It really looks good without the gear, but I like to take off and land too much to remove mine.
Fly safe!
Dan
daneflyer is offline Find More Posts by daneflyer
Old Jun 11, 2010, 11:02 PM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
just double checked, all clear but I noticed the click/rubbing sound as I torque down the bolt on the spinner. I attached some pics to show what I believe it is
Old Jun 12, 2010, 01:19 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
If you remove those screws and turn the motor by itself does it still do it?
Or only when you mount the impeller shaft - which means you are pushing it too far onto the motor shaft and it is hitting the screws/motor mount.
Old Jun 12, 2010, 01:04 PM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
there is no rubbing with the motor out, I am pretty sure I am tightening it down too much but I dont know how much torque/tension these screws need to make it secure enough to mount?
Old Jun 12, 2010, 02:30 PM
giddyuperic is offline
Find More Posts by giddyuperic
giddyuperic's Avatar
USA, CA, Riverside
Hey guys sorry about the off topic can anyone tell me how to get dents or a little crushed part of a wing corner out of foam please ?????????
giddyuperic is offline Find More Posts by giddyuperic
Old Jun 12, 2010, 03:10 PM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
The screws are either too long and hitting the internal rotor....try shorter screws or use a couple of washers. you want the screws tight and use loctight if possible. It is also possible the rotor is down on the shaft and hitting the screws also....
Many say you can get dings and stuff out by dipping it in hot water....
mjdee14 is offline Find More Posts by mjdee14
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
