Old Feb 10, 2010, 10:45 PM
animal acker is offline
Find More Posts by animal acker
polite, cordial gentleman
I just stays, near St. louis
Joined Jul 2008
Those guys are always out of stock. I have been waiting over a month for some lipos I ordered!
animal acker is offline Find More Posts by animal acker
Old Feb 11, 2010, 04:30 AM
Richardmid1 is offline
Find More Posts by Richardmid1
Joined Jan 2010
I guess the hub OD has to be at least 28mm as that is the diameter of the motor can. Hmm.
I was wondering, there is a 1mm ish gap between the blade tips and the inside of the shroud, I presume this is to allow for the blades expanding at high rpm?
Richardmid1 is offline Find More Posts by Richardmid1
Old Feb 11, 2010, 08:56 AM
nieves50 is offline
Find More Posts by nieves50
nananabooboo!!
nieves50's Avatar
United States, OK, Oklahoma City
Joined Mar 2003
Hello guys. Looks like there's enough space in the airframe for (2) 11.1 2200 lipos. I'm contemplating getting one with an RC-Lander 68mm fan unit, runnnig on 6S.
http://www.ejf.com/index.php?main_pa...roducts_id=621
Any thoughts on this? Thanks!
nieves50 is offline Find More Posts by nieves50
Old Feb 11, 2010, 09:15 AM
Joined Jan 2010
Does C of G affect top speed? What is the best C of G for slow flying and hovering? Im currently at 60mm back from where the wings meet the fuse.
Old Feb 11, 2010, 09:25 AM
Joined Jan 2010
More questions! ) Im currently using a 7s 2200mah pack, would I get equall performance from say a 6s 3000mah pack of the same C rating?
Old Feb 11, 2010, 09:51 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Richard, you won't get the same performance on 6S as you do on 7S. A wattmeter is really an important tool and would answer these questions for you.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Feb 11, 2010, 06:11 PM
Joined Jul 2008
Wattmeter, get it. Own it. Use it! Or else burn up stuff. Are you a fireman? Nope?
Get a wattmeter.
Old Feb 11, 2010, 08:02 PM
Texasredrider is offline
Find More Posts by Texasredrider
Mines faster than your's
Texasredrider's Avatar
USA, TX, Houston
Joined Jan 2007
Anybody hear anything about the new Squall! V2?
Texasredrider is offline Find More Posts by Texasredrider
Old Feb 11, 2010, 09:02 PM
DiabloKid is online now
Find More Posts by DiabloKid
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
please dont play with my emotions! I just got on the Squall wagon and now this!? My credit card hates you if this is true
DiabloKid is online now Find More Posts by DiabloKid
Old Feb 12, 2010, 04:55 AM
Joined Jan 2010
A couple of guys at the field have watt meters, ill borrow theirs.
I am going to spray my squall with foam safe paint, only trouble is it gives a mat finish, will this slow the plane down much?
Old Feb 12, 2010, 06:32 AM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
Originally Posted by MegaTesla View Post
I have decided not to limit the throttle range with my Turnigy 2836 3700kv in the 6904 with 4S 3000 40C pack (80A Turnigy esc). It is just too much fun!!
Even with the VT unit it dopplered 105mph today. I'm going to fly that motor until it explodes
I wanted to see what the $16 motor can do, and now I know!!
The motor has continued to impress me. The 6904 shroud on the other hand has suffered a bit. This morning when I was about to release the jet the impeller came off. I'm not sure why as I have tightened it really well. The damage to the inside of the duct is minimal. The shroud however seems to have started melting/cracking where the motor is attached. I'll replace the 2836 with the 3200kv when it arrives.
MegaTesla is offline Find More Posts by MegaTesla
Old Feb 12, 2010, 07:15 AM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
I guess if you want a V2 you gotta build it yourself!
ApexAero is online now Find More Posts by ApexAero
Old Feb 12, 2010, 12:35 PM
GLM is offline
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
That's a beautiful aircraft Apex!
Gary
GLM is offline Find More Posts by GLM
Old Feb 12, 2010, 01:46 PM
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
oops...wrong thread.
One Six Right is offline Find More Posts by One Six Right
Old Feb 12, 2010, 11:29 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Morganmiller bellypan kit
Here you go. I received my bellypan kit from Morgan Mill. The clear plastic is very tough. The black plastic is pretty strong too, but easier to cut.
The black nose section trims quite easily. Make sure you trim the inner section of the upper section so you don't block air flow into the fan.
It takes a couple of pairs of scissors and Dremel to finish the edges.
Prof100 is offline Find More Posts by Prof100
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
