Old Feb 10, 2010, 01:48 PM
DiabloKid is online now
Find More Posts by DiabloKid
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
you guys are too smart for me! Good stuff though
finally ordered mine last night since it was on sale. Got the Hoffman motor here, 6904 en route, esc ready to rock and servos in a box somewhere
last thing to get....batteries! Cant decide, 3600 or 5000 mah. hmm..
DiabloKid is online now Find More Posts by DiabloKid
Old Feb 10, 2010, 02:26 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Diablo, it depends on what you want.
The 3600 will give better flying characteristics, but less full throttle runtime. It would be good if you've got good throttle managment.
The 5K will give you slightly more power, and increased full throttle runtime at the expense of weight. This is your drag racing battery, if you want to burn holes in the sky, this one will do it for you.
Hope that helps!
gundamnitpete is offline Find More Posts by gundamnitpete
Old Feb 10, 2010, 02:29 PM
GLM is offline
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Originally Posted by One Six Right View Post
Gary,
Can I ask why you didn't make the extended inlet 90-100%FSA.
Not too much trouble to make a seconde proto, is it? Try them both and see which which one you like better. This one is about 4 1/2" longer than stock.
Just a thought.
Gary
Thanks Air - glad I saved you all that work.
Hi One Six,
Beautiful Work!
Several reasons,
A major reason was to create an inlet that could drastically reduce the landing impact and damage suffered on pretty much all Squall landing attempts. With it - you can land with more speed.
Aesthetics -, it just felt and looked right to bring the lip of the inlet forward in a straight extrusion.
My numbers:
2.718 x 3.14 = 8.534 sq. in.
.945 x 3.14 = 2.967
5.567 sq. in. = 69mm fan minus impeller
3.250 x 1.750 (actual opening between intake lip edges) = 5.687 sq.in.
5.567 x 90% = 5.010 FSA
5.567 x 95% = 5.288 FSA
5.567 x 100% = 5.567 FSA
Given the longer distance the air has to travel (5) and the need for more intake air in strenuous maneuvers, 5.687 or plus 4% seems about right.
So if Im not crazy, or the coffee hasnt kicked in yet I think Im fairly close.
This from the www.JetHanger.com
http://www.jethangar.com/Ducted%20Fans/df.html#rules
For the purists Im going to put up on my web page an unfolded pattern for the interior duct. Those who wish to create one out of 3mm Depron, mylar or any flexible sheet goods, can find it there. I just have to figure out how to do it with my web page software...
Or if you have a wrecked Squall save the foam intake bits and make one from that.
Youll find that it will tuck in nicely at the rear of the lip and butt into the existing lip of the stock foam pan.
http://morganmill.com/RC/rc-site-10-7-08_032.htm
Thanks for asking!
Cheers!
Gary
GLM is offline Find More Posts by GLM
Old Feb 10, 2010, 02:56 PM
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
I guess it just looks bigger than it really is.
One Six Right is offline Find More Posts by One Six Right
Old Feb 10, 2010, 03:27 PM
Richardmid1 is offline
Find More Posts by Richardmid1
Joined Jan 2010
Im using the HET 3 blade fan which has a smaller hub than the 4 blade.
Richardmid1 is offline Find More Posts by Richardmid1
Old Feb 10, 2010, 05:10 PM
another MONSTER ?
Valencia, CA
Which ever is larger, the Hub, or the Motor Housing O.D., is what what you want to use along with the I.D. of the shroud Housing, to determine the FSA.
Shroud I.D. area...............xx
minus.......................... -
Motor Hsg O.D. area..........xx
.................................._____
100% fan swept area........ xx
Old Feb 10, 2010, 05:31 PM
Team White Llama!
It doesn't it just has a harder taper on the front of the hub (more sharp).
Old Feb 10, 2010, 05:49 PM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
Hope that helps!
when has something you stated not helped me?
the easy answer for me is buy 2 of each to mix it up
30C enough?
Old Feb 10, 2010, 06:16 PM
Team White Llama!
30C on the 5000 is good, but if you've got the wild beast, the 3600 might want to be 40C.
A 30c 3600 could handle short bursts of it, but it's not gonna be happy
Old Feb 10, 2010, 06:27 PM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
Sorry to jump in, but does anyone know the weight of the bare foam parts? I tried searching, and browsed through most of the 3000+posts but didnt see anything.
Dylwad is offline Find More Posts by Dylwad
Old Feb 10, 2010, 07:27 PM
oldpilot is offline
Find More Posts by oldpilot
oldpilot's Avatar
Australia, NSW, Mona Vale
Joined May 2002
212 gm (7.13oz) That includes the plastic nosecone,tailcone and canopy.
158 gm (5.57oz) Foam parts only
oldpilot is offline Find More Posts by oldpilot
Old Feb 10, 2010, 07:53 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Hi One Six,
Beautiful Work!
Several reasons,
My numbers:
.945 x 3.14 = 2.967
Thanks for asking!
Cheers!
Gary
Gary,
Great upgrade to the Squall. You have my order for complete kit. Keep up the good work.
Bill
Prof100 is offline Find More Posts by Prof100
Old Feb 10, 2010, 07:57 PM
Dylwad is offline
Dylwad's Avatar
Joined Jun 2002
Perfect, thank you!
Old Feb 10, 2010, 09:44 PM
animal acker is offline
Find More Posts by animal acker
polite, cordial gentleman
I just stays, near St. louis
Joined Jul 2008
30C enough?
I have the storm in my plane with a 4000mah 40C and I like it, I also have some 3000mah of the same and when I give it the juice she goes wee-uh wee-uh, and the battery starts to say uncle. As usuale Pete is right.
animal acker is offline Find More Posts by animal acker
Old Feb 10, 2010, 10:42 PM
CAP 232-aholic
DiabloKid's Avatar
Centreville, VA
Joined Jan 2003
thank you kindly for the info sir. I might just go 5000 and be happy with that. Also HK has those in stock
the 4000's are not in stock at either HK or HP
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
