Old Oct 11, 2009, 03:32 AM
sj. is offline
sj.
Find More Posts by sj.
sj.
Cornwall, UK
Joined Apr 2007
Originally Posted by Dizz
Had my first go at some Doppler analysis this evening. I recorded 17 speed runs in one flight today, 8 have proved usable (I need to hold the line longer after passing the mic). It has averaged out at a straight and level speed of 85.5mph +/- 2mph. Am using Tornado 4S 2500mAh 4S packs and they are only getting luke warm. From how much it took to recharge I estimate that it can only be drawing about 27Amps flat out in the air.
Pete
Dizz
I'm guessing you too got yours from Totem and you're on the new LP fan rotor. I'd guess that I'm getting the same as you. Have you noticed a significant drop off from the origional fan?
sj
sj. is offline Find More Posts by sj.
Old Oct 11, 2009, 04:21 AM
tailslide5_0 is offline
Find More Posts by tailslide5_0
Hangar queen hoarder
tailslide5_0's Avatar
Denver, CO
Joined Jul 2006
Originally Posted by gundamnitpete
i couldn't find it on thier site, do you have a link?
Well they had it the other day, they must have stopped carrying it. Sorry
tailslide5_0 is offline Find More Posts by tailslide5_0
Old Oct 11, 2009, 01:48 PM
natterjak is offline
Find More Posts by natterjak
Asks too many questions
natterjak's Avatar
Berkshire, UK
Joined Nov 2005
Guys, your opinion please on the HET 3W-15 motor with HET 6904 fan in a Squall! with 4S 2500mAh 20C lipos? How would this compare to the HET 3W motor?
I'm wondering what current a 3W-15 with 6904 would produce and whether it will be pushing the lipos too hard?
natterjak is offline Find More Posts by natterjak
Old Oct 11, 2009, 03:07 PM
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
I'm stickin' with the original plan.
ARC 28-58-1
6s
DS-30
Just haven't gotten to building it yet. If I rush it, It won't be as fast.
One Six Right is offline Find More Posts by One Six Right
Old Oct 11, 2009, 03:17 PM
Dizz is offline
Find More Posts by Dizz
Dizz's Avatar
Brixham, Devon, England
Joined Jun 2004
Originally Posted by sj.
Dizz
sj
I did indeed sj, but its the replacement 3 blade reduced diameter HP one. I'm a bit disappointed with the performance now, definitely not as much thrust in the air as the few flights I had on the old impeller. Only just >1 T:W now leaving little in hand to help get out of trouble, as I found out on the second flight yesterday doing some high alfa stuff: glad I was at 3 mistakes high because it took 2 1/2 to mush out of the twisty-turny-tumbling thing I got into I didnt manage any flying today, but the Squall is in the car just in case I get the chance on the way home after work this week.
Pete
Dizz is offline Find More Posts by Dizz
Old Oct 11, 2009, 04:53 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Okay, I wanna add some lead to mine, and go 6S
Same setup as One Six Right..
Xpress.. is offline Find More Posts by Xpress..
Old Oct 11, 2009, 07:17 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
ARC 28-58-1= $90
Suppo 200 amp= $67
6S 30C 3200's= 115
Het 6904 (brake it in soft)=$35
i love my 28-58-1
gundamnitpete is offline Find More Posts by gundamnitpete
Old Oct 11, 2009, 07:21 PM
Team White Llama!
all i can find is the 2W-15, which is the "2W". it's a 3S motor, i doubt it would survive on 4S, and if it did it would pull around 100 amps.
If you want to go RIGHT to the limit of your current lipos, a 2W-20 would work, but it would pull the max C rating from your packs, so if you held it full throttle the whole flight they'd come down HOT.
a 3W would be a little better, lower amps draw and power, but easier on your batteries.
Old Oct 11, 2009, 07:43 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Does anyone have any real numbers on thrust and watts on the replacement fan vs the old one?
Shadrack is offline Find More Posts by Shadrack
Old Oct 11, 2009, 08:20 PM
Denver, CO
Joined Jul 2006
The HET 3w-15 is the same thing as a 3w, they're better known as just the 3w.
Old Oct 11, 2009, 09:40 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
ARC 28-58-1= $90
Suppo 200 amp= $67
6S 30C 3200's= 115
i love my 28-58-1
Would i need to use a thrust tube, or would stock work?
I need a ballistic missile.. with wings..
Old Oct 11, 2009, 09:55 PM
Team White Llama!
stock would work, but a thrust tube will always increase performance (and taylor it to what you want).
the 28-58-1 is some serious power, if your serious about a high power setup, i suggest an ARC 28-47-1 and 6904 fan. THis will be about 1200-1300 watts on 4S. roughly 90 amps depending on timing
The 28-47-1 is $60
suppo 100amp=$40
XPS 4S 3200 30C= $80, or you could run two 4S 2200 30C's in parallel for a 4S 4400 30C, which could handle the power.
your looking at 130 mph, maybe more if you use a thrust tube down to 80%
Old Oct 11, 2009, 09:56 PM
another MONSTER ?
Valencia, CA
Make your own thrust tube. 70-75% FSA. That'll make it ballistic. Test your amp draw before you fly it. It won't have as much thrust for the launch.
http://www.pulserate.com/
Old Oct 11, 2009, 11:41 PM
Xpress.. is offline
Xpress..'s Avatar
Joined Oct 2007
^Yeah, the launch is one thing I had worries about. Looks like I'd need to use a bungee launch, but just how i'm supposed to mount a hook to the plane without ripping the foam out...
Old Oct 11, 2009, 11:54 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Use 1" square piece of plywood with Z bend piece of 1/8" wire piece embedded into the block with epoxy. Fit the component into a whole you cut into the foam if you want to make it look like it belongs there.
Prof100 is online now Find More Posts by Prof100
Discussion Popular EDF Jets - Phase 3 Fantom - HobbyLobby - Firebird EZ-400 Foamy EDFs 127 Aug 02, 2012 07:47 AM
Sold EDF Unit from Phase 3 F16 $10 Shipped typhoonmaster Aircraft - Electric - Jets (FS/W) 1 Mar 15, 2009 12:27 PM
Discussion EDF vibration, Phase 3 EF-16 Friedclutch Foamy EDFs 5 Jul 16, 2008 09:23 PM
Discussion New EDF from BP hobbies Lance Nordby Electric Ducted Fan Jet Talk 3 Nov 11, 2006 06:38 PM
Alert New EDF From Great Planes netmechanic Electric Ducted Fan Jet Talk 5 Feb 19, 2006 03:23 PM
