This thread is privately moderated by kobkobico, who may elect to delete unwanted replies.
Old Jun 22, 2009, 10:46 AM
kobkobico is offline
Find More Posts by kobkobico
Lucid Dreamer
kobkobico's Avatar
USA, CA, Temecula
Joined Jul 2005
My First Kit/Scratchbuild
After many micro RTF, I started getting bored always getting something completely made for me. I thought it was time to move on and make something myself for a change. I have been messing around with planes for over four years now, so I figured I could make something that resembled a plane, and perhaps even flew if I was lucky enough. I managed to do just that with this plane, which can fly surprisingly well! The wing is from a Guilow's Fairchild 24 kit, but the rest is my personal creation. All out weight is kind of on the heavy side. It is just shy of 5 oz with a wingspan of about 24". As such, it's no glider. Cutting the power is a sure way to bring it down, and fast. Otherwise, the small 10 gram brushless gives it more than enough power, and flight time ranges from about 5-7 minutes on a 350 mah battery. It isn't a duration flier, but is good enough for me. Up in the air (no pictures unfortunately, as I've been flying early in the morning solo and can't multitask that way!) it looks very neat, especially in the early morning when just a trickle of light can pass through the wings giving it a ghostly effect. I thought it was going to look like an ugly flying stick... but personally I think it looks cute. But, well, I made it so that's a heck of a bias! In the air, it is quite stable, though it doesn't appreciate the wind too much. Something is up with the way I built it, causing it to yaw to the left with up elevator and to the right with down elevator. Personally I just manually compensate without even a second thought, though this may annoy some (remember, I flew so many little RTF I got used to some strange flying habits, like my Wowee Dragonfly preferring left to right turns, AA Sport with a spiral dive, etc.) Also, cutting power in a climb is a big no-no. It leads to a leftward spiral dive which is difficult to recover from. Interestingly, otherwise stalls are mild with power on, so I just play safe with keeping a little throttle on at all times. It flies somewhat fast, being heavy, but not too fast. I would say just the right speed actually. In a dive without throttle, it can't get too fast, which I attribute to the incidence on the wings dragging it back. On full throttle it can climb fairly well, and I felt safe coming in for some close flybys as I could get out of them in an "emergency" situation very quick.
As a secondary result of over-strengthening (the first being weight), it is naturally quite durable. I have never had a good landing (it likes to nose in) and have tipped it over multiple times in ground handling tests. However, the covering is not the slightest bit scratched, and everything looks great. Heck, in the first test flight I cut the power in a climb and it did the spiral dive thing, from at least 25 feet, straight into asphalt. The wing popped off the joint, but nothing else happened, save a couple stripped servos. Well, enough chit-chat, time for some pics.
P.S. In the pictures on the bed the wing was not attached. The support wasn't glued on that loosely.
Scratchbuilt RC Plane Flight (0 min 28 sec)
kobkobico is offline Find More Posts by kobkobico
Build Log Building a SA CAP 232 - my first kit and build mrm1 Beginner Training Area (Aircraft-Electric) 242 Nov 14, 2008 10:18 PM
My first kit C170Beauty Scale Kit/Scratch Built 3 Aug 20, 2005 12:18 PM
Covering my first Kit plane??? babenson The Builders Workshop 6 May 01, 2005 08:48 AM
My first kit cap232flyer16 Fuel Plane Talk 4 Aug 05, 2004 04:55 PM
My first foamy scratchbuild...Fokker Dr1 Highlander Foamies (Kits) 3 Dec 21, 2003 12:02 AM
