Joined Dec 2004
The planking of the second side is done in the same manner as the first side, starting with the first diagonal planks front edge on frame #F4 at the shear, and on #F5 at the chine. Again the planking will proceed butting and gluing the planks as before, all the way to the transom and then forward to the stem post, with the planking laying over the end grain of the first sides planking.
Once the second side has been planked, trim and block sand the planking flush at the stem post with the side of the first sides planking.
Joined Dec 2004
To start the bottom planking we mark the frame work on the keel at frame #F4 and at the chines at #F5. The sub planking will be done in the same manner as the side planking, but all the planking will butt joint on the center line of the keel.
This will mean that each plank must be marked were it crosses the center line of the keel and then angle cut with an Xacto knife for the butt joint.
| Thread Tools | |
| Question 54" Century Sea Maid | 68Brick | Scale Boats | 7 | Jan 06, 2007 10:44 PM |
| Pica 1/6th scale Mustang | dumbthumbs | Aircraft - Fuel - Airplanes (FS/W) | 0 | Dec 20, 2004 10:00 AM |
| WTB 1/6th scale P38 retracts | airmcn_3 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Oct 26, 2004 09:56 AM |
| 1/6th Scale Nitro Lotus with .21 Thunder Tiger | biff_40 | Cars - Cars and Parts (FS/W) | 2 | Jul 17, 2003 12:52 PM |
